source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @28   12 years toby # on 1999/01/13 05:02:47, toby did: redo loadexp so that page does not …
(edit) @27   12 years toby # on 1999/01/13 04:40:02, toby did: minor changes document "Override …
(edit) @26   12 years toby # on 1999/01/13 04:36:53, toby did: move cd command later change …
(edit) @25   12 years toby # on 1999/01/11 04:59:32, toby did: Initial revision
(edit) @24   12 years toby # on 1999/01/11 04:58:27, toby did: Initial revision
(edit) @23   12 years toby # on 1999/01/09 20:15:17, toby did: minor wording
(edit) @22   12 years toby # on 1999/01/07 04:45:54, toby did: remove compressprog -- not used …
(edit) @21   12 years toby # on 1999/01/07 04:43:03, toby did: misc fixes: set working directory …
(edit) @20   12 years toby # on 1999/01/06 04:15:12, toby did: Many changes so that expgui …
(edit) @19   12 years toby # on 1999/01/06 04:06:41, toby did: add createexp to create an EXP …
(edit) @18   12 years toby # on 1999/01/06 04:03:06, toby did: Initial revision
(edit) @17   12 years toby # on 1999/01/06 04:03:01, toby did: Initial revision
(edit) @16   12 years toby # on 1999/01/01 18:34:49, toby did: add tcl_version < 8.0 error add …
(edit) @15   12 years toby # on 1999/01/01 18:30:08, toby did: add existsexp, delexp, exphistory …
(edit) @14   12 years toby # on 1998/12/31 13:10:07, toby did: move scale to "scaling" (prev …
(edit) @13   12 years toby # on 1998/12/28 02:34:29, toby did: fix bug -- set print option as 0 …
(edit) @12   12 years toby # on 1998/12/28 02:33:30, toby did: minor fixes comment out …
(edit) @11   12 years toby # on 1998/12/26 22:03:38, toby did: Initial revision
(edit) @10   12 years toby # on 1998/12/26 22:03:11, toby did: Initial revision
(edit) @9   12 years toby # on 1998/11/23 20:35:13, toby did: Initial revision
(edit) @8   12 years toby # on 1998/11/23 20:06:43, toby did: Fix revision
(edit) @7   12 years toby # on 1998/11/23 19:38:02, toby did: Fix Revision bug Change name to LSTVIEW
(edit) @6   12 years toby # on 1998/11/23 19:34:03, toby did: Bug for cycles > 999 fixed Added …
(edit) @5   12 years toby # on 1998/11/23 17:57:08, toby did: Initial revision
(edit) @4   12 years toby # on 1998/11/23 17:48:34, toby did: Initial revision
(add) @3   12 years toby created by rcs2svn
Note: See TracRevisionLog for help on using the revision log.
