source: trunk
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @114   12 years toby # on 1999/10/11 20:27:13, toby did: Customization examples
(edit) @113   12 years toby # on 1999/10/11 19:49:28, toby did: * empty log message *
(edit) @112   12 years toby # on 1999/10/11 19:48:35, toby did: cleanup multiple histogram …
(edit) @111   12 years toby # on 1999/10/11 19:46:43, toby did: Define expgui(debug)
(edit) @110   12 years toby # on 1999/10/11 19:46:16, toby did: document new global modes ("Group …
(edit) @109   12 years toby # on 1999/09/16 15:44:26, toby did: add version reference to EXPGUI …
(edit) @108   12 years toby # on 1999/09/16 15:43:44, toby did: update 2.gif and 3.gif and text …
(edit) @107   12 years toby # on 1999/09/09 21:00:32, toby did: update for new WWW server
(edit) @106   12 years toby # on 1999/09/09 21:00:32, toby did: update for new WWW server
(edit) @105   12 years toby # on 1999/09/09 21:00:32, toby did: update for new WWW server
(edit) @104   12 years toby # on 1999/09/09 20:56:51, toby did: update for new WWW server
(edit) @103   12 years toby # on 1999/09/09 20:56:51, toby did: update for new WWW server
(edit) @102   12 years toby # on 1999/09/09 19:08:11, toby did: hide grab fail error messages ,
(edit) @101   12 years toby # on 1999/09/09 19:06:45, toby did: fix vrstplot call so that EXP name …
(edit) @100   12 years toby # on 1999/09/09 19:05:54, toby did: correct background window bug …
(edit) @99   12 years toby # on 1999/07/22 20:08:20, toby did: revise for exptool that adds …
(edit) @98   12 years toby # on 1999/07/22 20:07:37, toby did: Fix resize of ShowBigMessage?
(edit) @97   12 years toby # on 1999/07/22 20:04:23, toby did: clear atom box etc when loading an …
(edit) @96   12 years toby # on 1999/07/21 18:39:52, toby did: bring to current release make …
(edit) @95   12 years toby # on 1999/07/21 18:39:20, toby did: exptool updates
(edit) @94   12 years toby # on 1999/07/21 16:51:57, toby did: add phase... update
(edit) @93   12 years toby # on 1999/07/21 16:32:11, toby did: add autoload mode add support for …
(edit) @92   12 years toby # on 1999/07/21 16:29:57, toby did: These routines are used for adding …
(edit) @91   12 years toby # on 1999/07/21 16:22:54, toby did: adopt putontop and afterputontop …
(edit) @90   12 years toby # on 1999/07/21 16:19:34, toby did: fix bug in create blank exp file …
(edit) @89   12 years toby # on 1999/07/21 15:12:53, toby did: fix windows archive error
(edit) @88   12 years toby # on 1999/07/21 15:12:10, toby did: fix error reading R(F2)
(edit) @87   12 years toby # on 1999/04/20 19:22:46, toby did: rearrange order of commands so …
(edit) @86   12 years toby # on 1999/04/08 20:44:22, toby did: Add Id to header
(edit) @85   12 years toby # on 1999/04/08 20:44:22, toby did: Add Id to header
(edit) @84   12 years toby # on 1999/04/08 20:44:22, toby did: Add Id to header
(edit) @83   12 years toby # on 1999/04/08 20:44:22, toby did: define histogram slider to reach …
(edit) @82   12 years toby # on 1999/04/08 20:43:10, toby did: Add Id to top of file
(edit) @81   12 years toby # on 1999/04/08 20:39:33, toby did: Add new liveplot features refer to …
(edit) @80   12 years toby # on 1999/04/08 20:37:28, toby did: minor cleanups refer to tcldump …
(edit) @79   12 years toby # on 1999/04/08 20:33:23, toby did: add tick autoscaling deal with two …
(edit) @78   12 years toby # on 1999/04/06 22:27:03, toby did: add background subtraction adjust …
(edit) @77   12 years toby # on 1999/04/06 21:37:19, toby did: add Id
(edit) @76   12 years toby # on 1999/04/06 21:13:49, toby did: Add peak label dialog; delete …
(edit) @75   12 years toby # on 1999/04/05 18:14:24, toby did: fix BLT element -show/-hide option …
(edit) @74   12 years toby # on 1999/03/30 16:18:11, toby did: Set expnam on command line to …
(edit) @73   12 years toby # on 1999/03/19 17:07:59, toby did: major reworking -- implement …
(edit) @72   12 years toby # on 1999/03/19 17:07:59, toby did: rename file directory routines …
(edit) @71   12 years toby # on 1999/03/19 17:07:59, toby did: bug fixes for reading new .EXP files
(edit) @70   12 years toby # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new liveplot
(edit) @69   12 years toby # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new liveplot
(edit) @68   12 years toby # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new liveplot
(edit) @67   12 years toby # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new liveplot
(edit) @66   12 years toby # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new liveplot
(edit) @65   12 years toby # on 1999/03/19 16:55:10, toby did: * empty log message *
(edit) @64   12 years toby # on 1999/03/19 16:55:10, toby did: * empty log message *
(edit) @63   12 years toby # on 1999/02/22 20:03:00, toby did: save the selected atom list and …
(edit) @62   12 years toby # on 1999/02/19 18:18:23, toby did: cleanup warnings
(edit) @61   12 years toby # on 1999/02/19 18:17:14, toby did: Cleanup warnings
(edit) @60   12 years toby # on 1999/02/19 16:02:23, toby did: * empty log message *
(edit) @59   12 years toby # on 1999/02/19 16:01:46, toby did: Clean up file input dialogs for …
(edit) @58   12 years toby # on 1999/02/19 15:51:21, toby did: Add composition and exp2xtl …
(edit) @57   12 years toby # on 1999/02/18 23:28:46, toby did: Fix U aniso order
(edit) @56   12 years toby # on 1999/02/18 22:50:03, toby did: add space group to phase info
(edit) @55   12 years toby # on 1999/02/18 21:07:19, toby did: Add support for atom multiplicity
(edit) @54   12 years toby # on 1999/02/16 18:37:38, toby did: bug fixed
(edit) @53   12 years toby # on 1999/02/16 18:05:57, toby did: 1. better error messages 2. allow …
(edit) @52   12 years toby # on 1999/02/16 18:03:01, toby did: change comment
(edit) @51   12 years toby # on 1999/02/16 17:44:06, toby did: add vrstplot
(edit) @50   12 years toby # on 1999/02/02 17:32:47, toby did: updated -- use .zip for expgui
(edit) @49   12 years toby # on 1999/02/02 17:28:44, toby did: add label-set
(edit) @48   12 years toby # on 1999/02/02 17:26:27, toby did: fix typo in 1.8 update phase page …
(edit) @47   12 years toby # on 1999/01/25 19:53:04, toby did: fix bug in ChooseExpFil? to allow …
(edit) @46   12 years toby # on 1999/01/21 22:55:47, toby did: move & consolidate sourcing
(edit) @45   12 years toby # on 1999/01/21 22:44:12, toby did: drop arg #2 (get gsasexe from …
(edit) @44   12 years toby # on 1999/01/21 22:42:08, toby did: add SaveOptions? use localconfig & …
(edit) @43   12 years toby # on 1999/01/21 22:22:09, toby did: now 1 arg (get gsasexe from …
(edit) @42   12 years toby # on 1999/01/21 18:51:38, toby did: typo
(edit) @41   12 years toby # on 1999/01/21 18:30:17, toby did: 1st draft done
(edit) @40   12 years toby # on 1999/01/20 21:35:47, toby did: * empty log message *
(edit) @39   12 years toby # on 1999/01/20 21:35:18, toby did: * empty log message *
(edit) @38   12 years toby # on 1999/01/20 21:34:54, toby did: * empty log message *
(edit) @37   12 years toby # on 1999/01/20 21:34:11, toby did: * empty log message *
(edit) @36   12 years toby # on 1999/01/20 21:33:38, toby did: Initial revision
(edit) @35   12 years toby # on 1999/01/20 21:29:37, toby did: * empty log message *
(edit) @34   12 years toby # on 1999/01/20 21:28:23, toby did: Initial revision
(edit) @33   12 years toby # on 1999/01/20 21:28:08, toby did: Initial revision
(edit) @32   12 years toby # on 1999/01/20 20:19:58, toby did: change labels on .EXP select menu
(edit) @31   12 years toby # on 1999/01/20 19:44:43, toby did: remove unused stuff add …
(edit) @30   12 years toby # on 1999/01/20 19:29:10, toby did: use custom file open box allow for …
(edit) @29   12 years toby # on 1999/01/20 19:27:48, toby did: use custom file open box; fix GSAS …
(edit) @28   12 years toby # on 1999/01/13 05:02:47, toby did: redo loadexp so that page does not …
(edit) @27   12 years toby # on 1999/01/13 04:40:02, toby did: minor changes document "Override …
(edit) @26   12 years toby # on 1999/01/13 04:36:53, toby did: move cd command later change …
(edit) @25   12 years toby # on 1999/01/11 04:59:32, toby did: Initial revision
(edit) @24   12 years toby # on 1999/01/11 04:58:27, toby did: Initial revision
(edit) @23   12 years toby # on 1999/01/09 20:15:17, toby did: minor wording
(edit) @22   12 years toby # on 1999/01/07 04:45:54, toby did: remove compressprog -- not used …
(edit) @21   12 years toby # on 1999/01/07 04:43:03, toby did: misc fixes: set working directory …
(edit) @20   12 years toby # on 1999/01/06 04:15:12, toby did: Many changes so that expgui …
(edit) @19   12 years toby # on 1999/01/06 04:06:41, toby did: add createexp to create an EXP …
(edit) @18   12 years toby # on 1999/01/06 04:03:06, toby did: Initial revision
(edit) @17   12 years toby # on 1999/01/06 04:03:01, toby did: Initial revision
(edit) @16   12 years toby # on 1999/01/01 18:34:49, toby did: add tcl_version < 8.0 error add …
(edit) @15   12 years toby # on 1999/01/01 18:30:08, toby did: add existsexp, delexp, exphistory …
Note: See TracRevisionLog for help on using the revision log.
