# # ChangeLog for trunk # # Generated by Trac 1.0.13 # Jun 17, 2025 10:38:12 AM Fri, 04 Dec 2009 23:14:20 GMT toby [920] * trunk/addcmds.tcl (modified) # on 2008/06/30 23:51:43, toby did: fix bug on ImportPhase with 1 ... Fri, 04 Dec 2009 23:14:19 GMT toby [919] * trunk/doc/expguic.html (modified) # on 2008/04/15 17:31:53, toby did: formatting doc new Prompt after ... Fri, 04 Dec 2009 23:14:18 GMT toby [918] * trunk/widplt (modified) # on 2008/04/15 17:30:45, toby did: do not load widply_ files for absplt Fri, 04 Dec 2009 23:14:17 GMT toby [917] * trunk/profcons.tcl (modified) # on 2008/04/15 17:30:18, toby did: macro recording Fri, 04 Dec 2009 23:14:16 GMT toby [916] * trunk/orient.tcl (modified) # on 2008/04/15 17:29:50, toby did: macro recording Fri, 04 Dec 2009 23:14:15 GMT toby [915] * trunk/odf.tcl (modified) # on 2008/04/15 17:29:26, toby did: macro recording Fri, 04 Dec 2009 23:14:14 GMT toby [914] * trunk/lstview (modified) # on 2008/04/15 17:26:54, toby did: implement new capability as ... Fri, 04 Dec 2009 23:14:13 GMT toby [913] * trunk/liveplot (modified) # on 2008/04/15 17:25:56, toby did: add comment (bkgedit not macro ... Fri, 04 Dec 2009 23:14:12 GMT toby [912] * trunk/instedit.tcl (modified) # on 2008/04/15 17:24:40, toby did: new button to import ... Fri, 04 Dec 2009 23:14:11 GMT toby [911] * trunk/gsasmenu.tcl (modified) # on 2008/04/15 17:24:01, toby did: macro menu Fri, 04 Dec 2009 23:14:10 GMT toby [910] * trunk/gsascmds.tcl (modified) # on 2008/04/15 17:20:39, toby did: macro recording implement ... Fri, 04 Dec 2009 23:14:09 GMT toby [909] * trunk/export_shelx.tcl (modified) # on 2008/04/15 17:20:08, toby did: fix occupancy for macromolec input Fri, 04 Dec 2009 23:14:08 GMT toby [908] * trunk/expgui (modified) # on 2008/04/15 17:15:53, toby did: macro recording implement ... Fri, 04 Dec 2009 23:14:06 GMT toby [907] * trunk/excledt.tcl (modified) # on 2008/04/15 17:12:02, toby did: fix child window parentage ... Fri, 04 Dec 2009 23:14:04 GMT toby [906] * trunk/atomcons.tcl (modified) # on 2008/04/15 17:10:13, toby did: macro commands Fri, 04 Dec 2009 23:14:03 GMT toby [905] * trunk/addcmds.tcl (modified) # on 2008/04/15 16:55:46, toby did: major revision for macro ... Fri, 04 Dec 2009 23:14:02 GMT toby [904] * trunk/gsastcl.bat (added) # on 2007/04/01 03:53:08, toby did: run GSAS routines with a wait ... Fri, 04 Dec 2009 23:14:01 GMT toby [903] * trunk/gsasnowt.bat (added) # on 2007/04/01 03:53:08, toby did: run GSAS routines with no prompt ... Fri, 04 Dec 2009 23:14:00 GMT toby [902] * trunk/doc/wishlist.html (modified) # on 2007/01/25 22:58:38, toby did: remove @nist addresses Fri, 04 Dec 2009 23:13:59 GMT toby [901] * trunk/doc/osx.html (modified) # on 2007/01/25 22:57:44, toby did: rename directory Fri, 04 Dec 2009 23:13:58 GMT toby [900] * trunk/doc/expguierr.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:57 GMT toby [899] * trunk/doc/expgui_Win_readme.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:56 GMT toby [898] * trunk/doc/expgui_Unix_readme.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:55 GMT toby [897] * trunk/doc/expgui_intro.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:54 GMT toby [896] * trunk/doc/expgui_cfg.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:53 GMT toby [895] * trunk/doc/expgui.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:52 GMT toby [894] * trunk/doc/osx.html (modified) # on 2007/01/25 22:20:32, toby did: Add NIST header Fri, 04 Dec 2009 23:13:51 GMT toby [893] * trunk/doc/osx.html (modified) # on 2007/01/25 22:18:16, toby did: major revision Fri, 04 Dec 2009 23:13:50 GMT toby [892] * trunk/doc/wishlist.html (modified) # on 2007/01/17 04:47:00, toby did: remove NIST web exit hijacks ... Fri, 04 Dec 2009 23:13:49 GMT toby [891] * trunk/doc/osx.html (modified) # on 2007/01/17 04:45:37, toby did: remove NIST web exit hijacks Fri, 04 Dec 2009 23:13:48 GMT toby [890] * trunk/doc/liveplot.html (modified) # on 2007/01/17 04:44:31, toby did: remove NIST web exit hijacks ... Fri, 04 Dec 2009 23:13:47 GMT toby [889] * trunk/doc/gsas2cif.html (modified) # on 2007/01/17 04:41:24, toby did: remove NIST web exit hijacks Fri, 04 Dec 2009 23:13:46 GMT toby [888] * trunk/doc/expgui_Win_readme.html (modified) # on 2007/01/17 04:41:04, toby did: remove NIST web exit hijacks & ... Fri, 04 Dec 2009 23:13:45 GMT toby [887] * trunk/doc/expgui_Unix_readme.html (modified) # on 2007/01/17 04:40:18, toby did: remove NIST web exit hijacks & ... Fri, 04 Dec 2009 23:13:44 GMT toby [886] * trunk/doc/expgui_cfg.html (modified) # on 2007/01/17 04:38:58, toby did: remove NIST web exit hijacks & ... Fri, 04 Dec 2009 23:13:43 GMT toby [885] * trunk/doc/expgui.html (modified) # on 2007/01/17 04:37:21, toby did: remove NIST web exit hijacks ... Fri, 04 Dec 2009 23:13:42 GMT toby [884] * trunk/expgui (modified) # on 2007/01/17 04:21:56, toby did: warn on windows comspec problem ... Fri, 04 Dec 2009 23:13:41 GMT toby [883] * trunk/graceexport.tcl (modified) # on 2006/07/31 18:28:43, toby did: missing tickmarks (new BLT ... Fri, 04 Dec 2009 23:13:40 GMT toby [882] * trunk/expgui (modified) # on 2006/04/30 23:15:41, toby did: Indicate a new release Fri, 04 Dec 2009 23:13:39 GMT toby [881] * trunk/liveplot (modified) # on 2006/04/30 23:13:59, toby did: remove last of background ... Fri, 04 Dec 2009 23:13:38 GMT toby [880] * trunk/gsasmenu.tcl (modified) # on 2006/04/30 23:10:59, toby did: Add gsas2map into menus Fri, 04 Dec 2009 23:13:37 GMT toby [879] * trunk/gsasmenu.tcl (modified) # on 2006/03/29 04:07:45, toby did: Add mustrplot to 2nd menu Fri, 04 Dec 2009 23:13:35 GMT toby [878] * trunk/instedit.tcl (modified) # on 2006/03/29 03:54:37, toby did: support profile editing (& grab ... Fri, 04 Dec 2009 23:13:34 GMT toby [877] * trunk/gsasmenu.tcl (modified) # on 2006/03/29 03:53:16, toby did: remove now obsolete tofnorm; add ... Fri, 04 Dec 2009 23:13:33 GMT toby [876] * trunk/gsascmds.tcl (modified) # on 2006/03/29 03:52:11, toby did: Associate profile names with ... Fri, 04 Dec 2009 23:13:32 GMT toby [875] * trunk/dumpprof.tcl (modified) # on 2006/03/29 03:50:00, toby did: return diffractometer constants ... Fri, 04 Dec 2009 23:13:31 GMT toby [874] * trunk/addcmds.tcl (modified) # on 2006/03/29 03:47:44, toby did: Allow use of d-min or Q-max when ... Fri, 04 Dec 2009 23:13:30 GMT toby [873] * trunk/expgui (modified) # on 2006/03/29 03:45:35, toby did: Mark release Fri, 04 Dec 2009 23:13:29 GMT toby [872] * trunk/gsasmenu.tcl (modified) # on 2006/02/22 02:28:43, toby did: add seqgsas & seqplot to menus & ... Fri, 04 Dec 2009 23:13:28 GMT toby [871] * trunk/doc/wishlist.html (modified) # on 2006/02/22 01:47:15, toby did: update 1.78 Fri, 04 Dec 2009 23:13:27 GMT toby [870] * trunk/gsascmds.tcl (modified) # on 2006/02/22 01:45:29, toby did: Recompute Multiplicities prior ... Fri, 04 Dec 2009 23:13:26 GMT toby [869] * trunk/liveplot (modified) # on 2006/02/22 00:31:31, toby did: bkgfit: prevent use of more than ... Fri, 04 Dec 2009 23:13:25 GMT toby [868] * trunk/instedit.tcl (modified) # on 2006/02/22 00:29:58, toby did: no significant changes -- allow ... Fri, 04 Dec 2009 23:13:24 GMT toby [867] * trunk/gsascmds.tcl (modified) # on 2006/02/22 00:28:44, toby did: Allow composition to work on ... Fri, 04 Dec 2009 23:13:23 GMT toby [866] * trunk/expgui (modified) # on 2006/02/22 00:23:25, toby did: Plug GSAS on window head Make ... Fri, 04 Dec 2009 23:13:22 GMT toby [865] * trunk/addcmds.tcl (modified) # on 2006/02/22 00:18:37, toby did: fix bug in 2theta max for ... Fri, 04 Dec 2009 23:13:21 GMT toby [864] * trunk/doc/expgui_Win_readme.html (modified) # on 2005/12/16 00:44:34, toby did: make compatible with new GSAS -- ... Fri, 04 Dec 2009 23:13:20 GMT toby [863] * trunk/doc/wishlist.html (modified) # on 2005/12/16 00:44:08, toby did: misc updates Fri, 04 Dec 2009 23:13:19 GMT toby [862] * trunk/doc/expgui_cfg.html (modified) # on 2005/12/16 00:42:42, toby did: pane --> panel Fri, 04 Dec 2009 23:13:18 GMT toby [861] * trunk/doc/expgui7.html (modified) # on 2005/12/16 00:42:32, toby did: pane --> panel Fri, 04 Dec 2009 23:13:17 GMT toby [860] * trunk/doc/expgui6.html (modified) # on 2005/12/16 00:42:19, toby did: pane --> panel Fri, 04 Dec 2009 23:13:16 GMT toby [859] * trunk/doc/expgui5.html (modified) # on 2005/12/16 00:42:02, toby did: pane --> panel Fri, 04 Dec 2009 23:13:15 GMT toby [858] * trunk/doc/expgui4.html (modified) # on 2005/12/16 00:41:46, toby did: pane --> panel Fri, 04 Dec 2009 23:13:14 GMT toby [857] * trunk/doc/expgui3.html (modified) # on 2005/12/16 00:41:16, toby did: pane --> panel Fri, 04 Dec 2009 23:13:13 GMT toby [856] * trunk/doc/expgui2.html (modified) # on 2005/12/16 00:40:23, toby did: pane --> panel document origin ... Fri, 04 Dec 2009 23:13:12 GMT toby [855] * trunk/doc/expgui1.html (modified) # on 2005/12/16 00:39:30, toby did: pane --> panel Fri, 04 Dec 2009 23:13:11 GMT toby [854] * trunk/doc/expgui.html (modified) # on 2005/12/16 00:38:52, toby did: pane --> panel Fri, 04 Dec 2009 23:13:10 GMT toby [853] * trunk/addcmds.tcl (modified) # on 2005/12/16 00:36:40, toby did: make spacegroup search case ... Fri, 04 Dec 2009 23:13:09 GMT toby [852] * trunk/readexp.tcl (modified) # on 2005/09/13 17:44:33, toby did: fix buggy EXP create routine Fri, 04 Dec 2009 23:13:08 GMT toby [851] * trunk/dumpexp.tcl (modified) # on 2005/09/12 23:35:50, toby did: add package require code & new ... Fri, 04 Dec 2009 23:13:07 GMT toby [850] * trunk/readexp.tcl (modified) # on 2005/09/12 23:34:24, toby did: change formatting of ODF records ... Fri, 04 Dec 2009 23:13:06 GMT toby [849] * trunk/addcmds.tcl (modified) # on 2005/09/12 23:34:05, toby did: add missing proc Fri, 04 Dec 2009 23:13:05 GMT toby [848] * trunk/expgui (modified) # on 2005/09/07 21:32:23, toby did: tag for new EXPGUI release Fri, 04 Dec 2009 23:13:04 GMT toby [847] * trunk/addcmds.tcl (modified) # on 2005/09/07 21:30:07, toby did: Add origin 1 --> origin 2 xform ... Fri, 04 Dec 2009 23:13:03 GMT toby [846] * trunk/export_drawxtl.tcl (modified) # on 2005/09/07 21:26:38, toby did: fix use of delete window ... Fri, 04 Dec 2009 23:13:02 GMT toby [845] * trunk/doc/osx.html (modified) # on 2005/09/07 21:16:07, toby did: minor updates Fri, 04 Dec 2009 23:13:00 GMT toby [844] * trunk/doc/expgui_intro.html (modified) # on 2005/09/07 21:15:00, toby did: editorial comments Fri, 04 Dec 2009 23:12:59 GMT toby [843] * trunk/readexp.tcl (modified) # on 2005/03/24 21:59:06, toby did: new validreal support LS Band ... Fri, 04 Dec 2009 23:12:58 GMT toby [842] * trunk/profcons.tcl (modified) # on 2005/03/24 21:57:52, toby did: profile type 5 (RBVD) Fri, 04 Dec 2009 23:12:57 GMT toby [841] * trunk/gsascmds.tcl (modified) # on 2005/03/24 21:54:28, toby did: add defs for function #5 (thanks ... Fri, 04 Dec 2009 23:12:56 GMT toby [840] * trunk/orient.tcl (modified) # on 2005/03/24 21:53:50, toby did: change designation of preferred ... Fri, 04 Dec 2009 23:12:55 GMT toby [839] * trunk/widplt (modified) # on 2005/03/24 21:52:39, toby did: support function #5 (thanks RBVD) Fri, 04 Dec 2009 23:12:54 GMT toby [838] * trunk/expgui (modified) # on 2005/03/24 21:45:48, toby did: fix up resize for OS X add LS ... Fri, 04 Dec 2009 23:12:53 GMT toby [837] * trunk/lstview (modified) # on 2005/03/24 21:43:24, toby did: fix bug in save options Add ... Fri, 04 Dec 2009 23:12:52 GMT toby [836] * trunk/export_drawxtl.tcl (modified) # on 2005/03/24 21:40:23, toby did: major revision Allow arrow ... Fri, 04 Dec 2009 23:12:51 GMT toby [835] * trunk/doc/osx.html (modified) # on 2005/02/09 21:48:52, toby did: cleanup Fri, 04 Dec 2009 23:12:50 GMT toby [834] * trunk/doc/expgui.html (modified) # on 2005/02/09 21:48:18, toby did: download link Fri, 04 Dec 2009 23:12:49 GMT toby [833] * trunk/doc/expgui5.html (modified) # on 2005/02/09 21:47:28, toby did: new feature: blank out shft & ... Fri, 04 Dec 2009 23:12:48 GMT toby [832] * trunk/doc/wishlist.html (modified) # on 2005/02/09 21:47:06, toby did: updates Fri, 04 Dec 2009 23:12:47 GMT toby [831] * trunk/doc/expgui_intro.html (modified) # on 2005/02/09 21:46:35, toby did: download links Fri, 04 Dec 2009 23:12:46 GMT toby [830] * trunk/readexp.tcl (modified) # on 2004/11/17 14:20:26, toby did: fix unformatted date -- belt & ... Fri, 04 Dec 2009 23:12:45 GMT toby [829] * trunk/doc/expgui_Unix_readme.html (modified) # on 2004/10/05 22:58:19, toby did: size change Fri, 04 Dec 2009 23:12:44 GMT toby [828] * trunk/doc/debug_tcltk.html (modified) # on 2004/10/05 22:57:30, toby did: missing zoom stack add BWidget ... Fri, 04 Dec 2009 23:12:43 GMT toby [827] * trunk/exclinit.tcl (modified) # on 2004/10/04 20:29:52, toby did: remove diffvec (not used) Fri, 04 Dec 2009 23:12:42 GMT toby [826] * trunk/liveplot (modified) # on 2004/10/04 20:29:36, toby did: redo vector access Fri, 04 Dec 2009 23:12:41 GMT toby [825] * trunk/excledt.tcl (modified) # on 2004/10/04 20:28:29, toby did: remove unused diffvec redo ... Fri, 04 Dec 2009 23:12:40 GMT toby [824] * trunk/orient.tcl (modified) # on 2004/10/04 16:21:09, toby did: remove non-BWidget code Fri, 04 Dec 2009 23:12:39 GMT toby [823] * trunk/expgui (modified) # on 2004/10/04 16:20:26, toby did: Require BWidget (remove ... Fri, 04 Dec 2009 23:12:38 GMT toby [822] * trunk/odf.tcl (modified) # on 2004/10/04 16:11:47, toby did: BWidget is now required Fri, 04 Dec 2009 23:12:37 GMT toby [821] * trunk/doc/expgui_Win_readme.html (modified) # on 2004/09/30 15:24:29, toby did: fix file name
