# # ChangeLog for trunk # # Generated by Trac 1.0.13 # Jun 17, 2025 9:58:22 AM Fri, 04 Dec 2009 23:05:59 GMT toby [427] * trunk/excledt.tcl (modified) # on 2001/09/04 22:55:55, toby did: larger optional font Fri, 04 Dec 2009 23:05:58 GMT toby [426] * trunk/liveplot (modified) # on 2001/09/04 22:53:53, toby did: set colors/symbols adjust fonts ... Fri, 04 Dec 2009 23:05:57 GMT toby [425] * trunk/opts.tcl (modified) # on 2001/09/04 22:46:08, toby did: Do a better job with BLT graphs Fri, 04 Dec 2009 23:05:56 GMT toby [424] * trunk/excledt.tcl (added) # on 2001/09/04 22:37:09, toby did: Excluded Region and Data Limit Editor Fri, 04 Dec 2009 23:05:55 GMT toby [423] * trunk/doc/expgui_cfg.html (modified) # on 2001/09/04 22:13:06, toby did: describe how to override the ... Fri, 04 Dec 2009 23:05:54 GMT toby [422] * trunk/odf.tcl (modified) # on 2001/09/04 22:11:44, toby did: adjustable fonts Fri, 04 Dec 2009 23:05:53 GMT toby [421] * trunk/gsascmds.tcl (modified) # on 2001/09/04 22:11:06, toby did: adjustable fonts Fri, 04 Dec 2009 23:05:52 GMT toby [420] * trunk/liveplot (modified) # on 2001/09/04 22:09:40, toby did: reset bkgedit zoom Fri, 04 Dec 2009 23:05:51 GMT toby [419] * trunk/expgui (modified) # on 2001/09/04 22:08:10, toby did: adjustable font support Fri, 04 Dec 2009 23:05:50 GMT toby [418] * trunk/atomcons.tcl (modified) # on 2001/09/04 22:07:47, toby did: adjustable fonts Fri, 04 Dec 2009 23:05:49 GMT toby [417] * trunk/opts.tcl (modified) # on 2001/09/04 22:06:41, toby did: adjustable fonts Fri, 04 Dec 2009 23:05:48 GMT toby [416] * trunk/orient.tcl (modified) # on 2001/09/04 22:06:05, toby did: adjustable fonts Fri, 04 Dec 2009 23:05:47 GMT toby [415] * trunk/readexp.tcl (modified) # on 2001/09/04 22:04:24, toby did: excluded region support bank & ... Fri, 04 Dec 2009 23:05:46 GMT toby [414] * trunk/profcons.tcl (modified) # on 2001/09/04 22:03:57, toby did: adjustable fonts Fri, 04 Dec 2009 23:05:45 GMT toby [413] * trunk/addcmds.tcl (modified) # on 2001/09/04 22:01:55, toby did: adjust font Fri, 04 Dec 2009 23:05:44 GMT toby [412] * trunk/doc/expguierr.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:43 GMT toby [411] * trunk/doc/expgui_intro.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:42 GMT toby [410] * trunk/doc/expgui_cfg.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:41 GMT toby [409] * trunk/doc/expgui2.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:40 GMT toby [408] * trunk/doc/expgui.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:39 GMT toby [407] * trunk/doc/wishlist.html (modified) # on 2001/08/24 18:56:30, toby did: updated Fri, 04 Dec 2009 23:05:38 GMT toby [406] * trunk/doc/liveplot.html (modified) # on 2001/06/29 18:34:32, toby did: document bkgedit add cumulative ... Fri, 04 Dec 2009 23:05:37 GMT toby [405] * trunk/doc/expguic.html (modified) # on 2001/06/29 18:29:04, toby did: liveplot links Fri, 04 Dec 2009 23:05:36 GMT toby [404] * trunk/doc/expguic.html (modified) # on 2001/06/29 18:28:04, toby did: add archived files access Fri, 04 Dec 2009 23:05:35 GMT toby [403] * trunk/doc/expgui7.html (modified) # on 2001/06/29 18:26:19, toby did: relabel "forward" button Fri, 04 Dec 2009 23:05:34 GMT toby [402] * trunk/doc/expgui3.html (modified) # on 2001/06/29 18:23:57, toby did: Add bkgedit button description Fri, 04 Dec 2009 23:05:33 GMT toby [401] * trunk/doc/expgui1.html (modified) # on 2001/06/29 18:20:12, toby did: major expansion -- explain page ... Fri, 04 Dec 2009 23:05:32 GMT toby [400] * trunk/liveplot (modified) # on 2001/06/29 18:10:45, toby did: Major revision: add bkgedit ... Fri, 04 Dec 2009 23:05:31 GMT toby [399] * trunk/expgui (modified) # on 2001/06/29 18:06:31, toby did: Add Marquardt, convergence, ... Fri, 04 Dec 2009 23:05:30 GMT toby [398] * trunk/gsascmds.tcl (modified) # on 2001/06/29 18:03:32, toby did: Add bkgedit command Fri, 04 Dec 2009 23:05:29 GMT toby [397] * trunk/gsasmenu.tcl (modified) # on 2001/06/29 18:00:06, toby did: add bkgedit program Fri, 04 Dec 2009 23:05:28 GMT toby [396] * trunk/readexp.tcl (modified) # on 2001/06/29 17:54:33, toby did: brace expr's for better speed ... Fri, 04 Dec 2009 23:05:27 GMT toby [395] * trunk/expgui (modified) # on 2001/05/23 20:11:12, toby did: use ... Fri, 04 Dec 2009 23:05:26 GMT toby [394] * trunk/addcmds.tcl (modified) # on 2001/05/23 20:06:32, toby did: Use TOF-min for default when ... Fri, 04 Dec 2009 23:05:25 GMT toby [393] * trunk/gsascmds.tcl (modified) # on 2001/05/23 20:02:11, toby did: allow help pages to be found on ... Fri, 04 Dec 2009 23:05:24 GMT toby [392] * trunk/gsascmds.tcl (modified) # on 2001/05/11 18:35:14, toby did: test histograms before sending ... Fri, 04 Dec 2009 23:05:23 GMT toby [391] * trunk/liveplot (modified) # on 2001/05/11 18:32:34, toby did: Add support for WIF David's ... Fri, 04 Dec 2009 23:05:22 GMT toby [390] * trunk/expgui (modified) # on 2001/05/11 16:18:58, toby did: change in location of PGPLOT ... Fri, 04 Dec 2009 23:05:21 GMT toby [389] * trunk/atomcons.tcl (modified) # on 2001/05/11 16:17:36, toby did: Change max constrained atoms to 500 Fri, 04 Dec 2009 23:05:20 GMT toby [388] * trunk/gsascmds.tcl (modified) # on 2001/05/11 16:10:22, toby did: button to display gzip'ed input ... Fri, 04 Dec 2009 23:05:19 GMT toby [387] * trunk/readexp.tcl (modified) # on 2001/05/11 16:09:08, toby did: accomodate gzip'ed input files ... Fri, 04 Dec 2009 23:05:18 GMT toby [386] * trunk/doc/liveplot.html (added) # on 2001/05/11 04:15:34, toby did: LIVEPLOT documentation Fri, 04 Dec 2009 23:05:17 GMT toby [385] * trunk/expgui (modified) # on 2001/04/17 22:51:20, toby did: Use CR/LF format files on all ... Fri, 04 Dec 2009 23:05:16 GMT toby [384] * trunk/gsascmds.tcl (modified) # on 2001/04/17 22:49:47, toby did: revise tk_dialog to MyMessage ... Fri, 04 Dec 2009 23:05:15 GMT toby [383] * trunk/addcmds.tcl (modified) # on 2001/04/17 22:46:55, toby did: revise tk_dialog to MyMessage ... Fri, 04 Dec 2009 23:05:14 GMT toby [382] * trunk/gsasmenu.tcl (modified) # on 2001/04/17 22:45:54, toby did: use same spelling for geometry ... Fri, 04 Dec 2009 23:05:13 GMT toby [381] * trunk/readexp.tcl (modified) # on 2001/04/17 22:44:59, toby did: revise to use CR/LF for all platforms Fri, 04 Dec 2009 23:05:12 GMT toby [380] * trunk/gsascmds.tcl (modified) # on 2001/04/16 21:27:22, toby did: fix overwrite problem widen ... Fri, 04 Dec 2009 23:05:11 GMT toby [379] * trunk/addcmds.tcl (modified) # on 2001/04/16 21:25:33, toby did: Add atom sort feature Fri, 04 Dec 2009 23:05:10 GMT toby [378] * trunk/addcmds.tcl (modified) # on 2001/04/03 19:16:41, toby did: fix bug: if error occurs in ... Fri, 04 Dec 2009 23:05:09 GMT toby [377] * trunk/import_cif.tcl (modified) # on 2001/04/03 19:13:29, toby did: support cifs w/o ... Fri, 04 Dec 2009 23:05:08 GMT toby [376] * trunk/readexp.tcl (modified) # on 2001/04/03 19:10:54, toby did: TEMPORARY FIX: for SGI use old ... Fri, 04 Dec 2009 23:05:07 GMT toby [375] * trunk/doc/wishlist.html (modified) # on 2001/02/26 19:52:54, toby did: more stuff to do Fri, 04 Dec 2009 23:05:06 GMT toby [374] * trunk/doc/expgui_Win_readme.html (modified) # on 2001/02/26 19:52:54, toby did: long name warning Fri, 04 Dec 2009 23:05:05 GMT toby [373] * trunk/readexp.tcl (modified) # on 2001/02/26 19:37:17, toby did: Change EPHAS (Fobs extraction) ... Fri, 04 Dec 2009 23:05:04 GMT toby [372] * trunk/profcons.tcl (modified) # on 2001/02/22 18:28:06, toby did: fix weird bug? Fri, 04 Dec 2009 23:05:03 GMT toby [371] * trunk/lstview (modified) # on 2000/12/22 21:31:48, toby did: show sample font sizes Fri, 04 Dec 2009 23:05:02 GMT toby [370] * trunk/gsascmds.tcl (modified) # on 2000/12/22 21:31:48, toby did: produce error message in DISAGL ... Fri, 04 Dec 2009 23:05:01 GMT toby [369] * trunk/doc/expguierr.html (modified) # on 2000/12/22 21:14:32, toby did: expand descriptions new ... Fri, 04 Dec 2009 23:05:00 GMT toby [368] * trunk/doc/expguic.html (modified) # on 2000/12/22 21:14:32, toby did: expand archive documentation to ... Fri, 04 Dec 2009 23:04:59 GMT toby [367] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/12/22 21:14:32, toby did: minor edits, recommend tcl 8.2 now Fri, 04 Dec 2009 23:04:58 GMT toby [366] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/12/22 21:14:32, toby did: Tcl/Tk test section revised Fri, 04 Dec 2009 23:04:57 GMT toby [365] * trunk/doc/expgui_cfg.html (modified) # on 2000/12/22 21:14:32, toby did: document new option: autoraise ... Fri, 04 Dec 2009 23:04:56 GMT toby [364] * trunk/doc/expgui.html (modified) # on 2000/12/22 21:14:32, toby did: document error highlighting new ... Fri, 04 Dec 2009 23:04:55 GMT toby [363] * trunk/widplt (modified) # on 2000/12/22 19:44:07, toby did: fix expload error for DOS format ... Fri, 04 Dec 2009 23:04:54 GMT toby [362] * trunk/liveplot (modified) # on 2000/12/22 19:44:07, toby did: Implement autoraise detect ... Fri, 04 Dec 2009 23:04:53 GMT toby [361] * trunk/gsasmenu.tcl (modified) # on 2000/12/22 19:44:07, toby did: make POWPLOT a background program Fri, 04 Dec 2009 23:04:52 GMT toby [360] * trunk/gsascmds.tcl (modified) # on 2000/12/22 19:44:07, toby did: Major reworking of routines to ... Fri, 04 Dec 2009 23:04:51 GMT toby [359] * trunk/expgui (modified) # on 2000/12/22 19:44:07, toby did: add autoiconify option require ... Fri, 04 Dec 2009 23:04:49 GMT toby [358] * trunk/addcmds.tcl (modified) # on 2000/12/22 19:37:02, toby did: fix call to RAWPLOT in data ... Fri, 04 Dec 2009 23:04:47 GMT toby [357] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/12/22 19:17:42, toby did: testing Tcl/Tk FAQ added Fri, 04 Dec 2009 23:04:45 GMT toby [356] * trunk/doc/expgui6.html (modified) # on 2000/11/27 21:10:45, toby did: define XYZU+-F Fri, 04 Dec 2009 23:04:44 GMT toby [355] * trunk/atomcons.tcl (modified) # on 2000/11/27 21:05:56, toby did: define type of XYZU+-F set ... Fri, 04 Dec 2009 23:04:43 GMT toby [354] * trunk/addcmds.tcl (modified) # on 2000/11/27 21:05:56, toby did: line up >10 banks in Hist add ... Fri, 04 Dec 2009 23:04:42 GMT toby [353] * trunk/import_cif.tcl (modified) # on 2000/11/26 17:53:28, toby did: fix grab for choose block window Fri, 04 Dec 2009 23:04:41 GMT toby [352] * trunk/expgui (modified) # on 2000/11/21 21:26:37, toby did: add "open" (same as "expnam") Fri, 04 Dec 2009 23:04:39 GMT toby [351] * trunk/opts.tcl (modified) # on 2000/11/21 21:25:31, toby did: fix font use for customization Fri, 04 Dec 2009 23:04:37 GMT toby [350] * trunk/gsasmenu.tcl (modified) # on 2000/11/21 21:25:31, toby did: fix that geometry is spelled ... Fri, 04 Dec 2009 23:04:35 GMT toby [349] * trunk/atomcons.tcl (modified) # on 2000/11/21 21:23:45, toby did: change appearance of negative ... Fri, 04 Dec 2009 23:04:33 GMT toby [348] * trunk/doc/wishlist.html (modified) # on 2000/11/21 21:21:57, toby did: more ideas Fri, 04 Dec 2009 23:04:32 GMT toby [347] * trunk/doc/expgui_cfg.html (modified) # on 2000/11/21 21:21:57, toby did: doc how to change fonts Fri, 04 Dec 2009 23:04:31 GMT toby [346] * trunk/doc/expgui6.html (modified) # on 2000/11/21 21:21:57, toby did: use beige for neg contraints Fri, 04 Dec 2009 23:04:30 GMT toby [345] * trunk/doc/wishlist.html (modified) # on 2000/10/23 14:41:11, toby did: more ideas from Lachlan Fri, 04 Dec 2009 23:04:29 GMT toby [344] * trunk/doc/wishlist.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:28 GMT toby [343] * trunk/doc/expguierr.html (modified) # on 2000/10/18 00:11:17, toby did: move utilites organize Fri, 04 Dec 2009 23:04:27 GMT toby [342] * trunk/doc/expguic.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:26 GMT toby [341] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:25 GMT toby [340] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:24 GMT toby [339] * trunk/doc/expgui_intro.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:23 GMT toby [338] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:22 GMT toby [337] * trunk/doc/expgui7.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:21 GMT toby [336] * trunk/doc/expgui6.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:20 GMT toby [335] * trunk/doc/expgui5.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:19 GMT toby [334] * trunk/doc/expgui4.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:18 GMT toby [333] * trunk/doc/expgui3.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:17 GMT toby [332] * trunk/doc/expgui2.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:16 GMT toby [331] * trunk/doc/expgui1.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:15 GMT toby [330] * trunk/doc/expgui0.html (modified) # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup ... Fri, 04 Dec 2009 23:04:14 GMT toby [329] * trunk/doc/expgui.html (modified) # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup ... Fri, 04 Dec 2009 23:04:13 GMT toby [328] * trunk/gsascmds.tcl (modified) # on 2000/10/18 00:03:58, toby did: Major change in order of ...
