# ChangeLog for trunk/gsascmds.tcl
# Generated by Trac 1.0.13
# Jul 4, 2025 6:09:31 PM
Fri, 04 Dec 2009 23:14:10 GMT toby [910]
	* trunk/gsascmds.tcl (modified)
	# on 2008/04/15 17:20:39, toby did:
	macro recording
	implement ...
Fri, 04 Dec 2009 23:13:33 GMT toby [876]
	# on 2006/03/29 03:52:11, toby did:
	Associate profile names with ...
Fri, 04 Dec 2009 23:13:27 GMT toby [870]
	# on 2006/02/22 01:45:29, toby did:
	Recompute Multiplicities prior ...
Fri, 04 Dec 2009 23:13:24 GMT toby [867]
	# on 2006/02/22 00:28:44, toby did:
	Allow composition to work on ...
Fri, 04 Dec 2009 23:12:57 GMT toby [841]
	# on 2005/03/24 21:54:28, toby did:
	add defs for function #5 (thanks ...
Fri, 04 Dec 2009 23:12:26 GMT toby [810]
	# on 2004/09/28 22:34:07, toby did:
	use WINUTILS if present in place ...
Fri, 04 Dec 2009 23:12:20 GMT toby [805]
	# on 2004/09/20 15:32:20, toby did:
	force all output to instfile to ...
Fri, 04 Dec 2009 23:12:05 GMT toby [791]
	# on 2004/05/04 17:20:35, toby did:
	save .EXP before call to bkgedit ...
Fri, 04 Dec 2009 23:11:57 GMT toby [783]
	# on 2004/04/27 14:12:04, toby did:
	update non-modal dialogs to ...
Fri, 04 Dec 2009 23:11:49 GMT toby [775]
	# on 2004/01/30 00:50:00, toby did:
	Add code to set app/icon in OS X
Fri, 04 Dec 2009 23:11:46 GMT toby [772]
	# on 2004/01/30 00:41:47, toby did:
	update putontop to match new ...
Fri, 04 Dec 2009 23:11:22 GMT toby [749]
	# on 2003/11/13 17:21:17, toby did:
	remove obsolete references to ...
Fri, 04 Dec 2009 23:11:15 GMT toby [742]
	# on 2003/11/05 22:16:55, toby did:
	add mozilla to browser list
	fix ...
Fri, 04 Dec 2009 23:11:04 GMT toby [731]
	# on 2003/08/11 19:28:54, toby did:
	code cleanup -col -> -column
Fri, 04 Dec 2009 23:10:34 GMT toby [701]
	# on 2003/05/22 21:43:32, toby did:
	Workaround for win-XP bug where ...
Fri, 04 Dec 2009 23:10:06 GMT toby [673]
	# on 2003/04/10 22:13:02, toby did:
	implement GRWND startup (Win-9x) ...
Fri, 04 Dec 2009 23:09:58 GMT toby [665]
	# on 2002/12/30 17:14:03, toby did:
	update pleasewait to include ...
Fri, 04 Dec 2009 23:09:30 GMT toby [637]
	# on 2002/08/09 16:40:59, toby did:
	fix table size sync.
	add  ...
Fri, 04 Dec 2009 23:09:26 GMT toby [633]
	# on 2002/07/18 20:51:26, toby did:
	remove iconify from excledt -- ...
Fri, 04 Dec 2009 23:08:59 GMT toby [606]
	# on 2002/07/03 21:04:31, toby did:
	catch invalid .EXP file names
Fri, 04 Dec 2009 23:07:55 GMT toby [542]
	# on 2002/01/22 22:53:34, toby did:
	support absplt in widplt routine ...
Fri, 04 Dec 2009 23:07:03 GMT toby [491]
	# on 2001/12/16 17:31:47, toby did:
	fix fileinfobox error in open ...
Fri, 04 Dec 2009 23:07:02 GMT toby [490]
	# on 2001/11/19 19:50:58, toby did:
	include Rfactors on file lookup
Fri, 04 Dec 2009 23:06:57 GMT toby [485]
	# on 2001/11/07 18:22:57, toby did:
	remove echo in archive
	add get ...
Fri, 04 Dec 2009 23:06:51 GMT toby [479]
	# on 2001/10/31 20:07:41, toby did:
	change excledt to run "in-line"
Fri, 04 Dec 2009 23:06:42 GMT toby [470]
	# on 2001/10/18 23:30:15, toby did:
	fix web page display problem in ...
Fri, 04 Dec 2009 23:06:22 GMT toby [450]
	# on 2001/09/25 23:31:59, toby did:
	Add error highlight into ...
Fri, 04 Dec 2009 23:06:03 GMT toby [431]
	# on 2001/09/04 22:58:36, toby did:
	add excledt
Fri, 04 Dec 2009 23:05:53 GMT toby [421]
	# on 2001/09/04 22:11:06, toby did:
	adjustable fonts
Fri, 04 Dec 2009 23:05:30 GMT toby [398]
	# on 2001/06/29 18:03:32, toby did:
	Add bkgedit command
Fri, 04 Dec 2009 23:05:25 GMT toby [393]
	# on 2001/05/23 20:02:11, toby did:
	allow help pages to be found on ...
Fri, 04 Dec 2009 23:05:24 GMT toby [392]
	# on 2001/05/11 18:35:14, toby did:
	test histograms before sending ...
Fri, 04 Dec 2009 23:05:20 GMT toby [388]
	# on 2001/05/11 16:10:22, toby did:
	button to display gzip'ed input ...
Fri, 04 Dec 2009 23:05:16 GMT toby [384]
	# on 2001/04/17 22:49:47, toby did:
	revise tk_dialog to MyMessage ...
Fri, 04 Dec 2009 23:05:12 GMT toby [380]
	# on 2001/04/16 21:27:22, toby did:
	fix overwrite problem
	widen ...
Fri, 04 Dec 2009 23:05:02 GMT toby [370]
	# on 2000/12/22 21:31:48, toby did:
	produce error message in DISAGL ...
Fri, 04 Dec 2009 23:04:52 GMT toby [360]
	# on 2000/12/22 19:44:07, toby did:
	Major reworking of routines to ...
Fri, 04 Dec 2009 23:04:13 GMT toby [328]
	# on 2000/10/18 00:03:58, toby did:
	Major change in order of ...
Fri, 04 Dec 2009 23:04:10 GMT toby [325]
	# on 2000/10/17 15:20:45, toby did:
	snapshot with revisions for WWW help
Fri, 04 Dec 2009 23:04:09 GMT toby [324]
	# on 2000/10/12 22:12:21, toby did:
	fix html bugs for Windows
Fri, 04 Dec 2009 23:04:07 GMT toby [322]
	# on 2000/10/12 21:36:23, toby did:
	Add www help support
	improve ...
Fri, 04 Dec 2009 23:02:53 GMT toby [249]
	# on 2000/07/28 20:28:25, toby did:
	remove unneeded ref to Win98 for ...
Fri, 04 Dec 2009 23:02:43 GMT toby [239]
	# on 2000/07/20 22:13:40, toby did:
	correct use R settings in  ...
Fri, 04 Dec 2009 23:02:35 GMT toby [231]
	# on 2000/07/06 21:29:24, toby did:
	Add GetProfileTerms, GetLaue, ...
Fri, 04 Dec 2009 23:02:31 GMT toby [227]
	# on 2000/07/03 21:50:35, toby did:
	fix aniso atoms in exp2xtl
Fri, 04 Dec 2009 23:02:05 GMT toby [201]
	# on 2000/06/09 03:52:16, toby did:
	Add warning when PGPLOT font ...
Fri, 04 Dec 2009 23:01:46 GMT toby [182]
	# on 2000/06/01 02:55:03, toby did:
	add concurrent arg to ...
Fri, 04 Dec 2009 23:01:02 GMT toby [138]
	# on 2000/05/17 18:38:55, toby did:
	add force to rename
	add ...
Fri, 04 Dec 2009 23:00:54 GMT toby [130]
	# on 2000/05/16 21:57:44, toby did:
	ignore macromolecular phases ...
Fri, 04 Dec 2009 23:00:43 GMT toby [119]
	# on 1999/11/17 22:02:36, toby did:
	Add routine to delete history ...
Fri, 04 Dec 2009 23:00:26 GMT toby [102]
	# on 1999/09/09 19:08:11, toby did:
	hide grab fail error messages
Fri, 04 Dec 2009 23:00:22 GMT toby [98]
	# on 1999/07/22 20:07:37, toby did:
	Fix resize of ShowBigMessage
Fri, 04 Dec 2009 23:00:15 GMT toby [91]
	# on 1999/07/21 16:22:54, toby did:
	adopt putontop and afterputontop ...
Fri, 04 Dec 2009 23:00:07 GMT toby [83]
	# on 1999/04/08 20:44:22, toby did:
	define histogram slider to reach ...
Fri, 04 Dec 2009 22:59:56 GMT toby [72]
	# on 1999/03/19 17:07:59, toby did:
	rename file directory routines ...
Fri, 04 Dec 2009 22:59:46 GMT toby [62]
	# on 1999/02/19 18:18:23, toby did:
	cleanup warnings
Fri, 04 Dec 2009 22:59:44 GMT toby [60]
	# on 1999/02/19 16:02:23, toby did:
Fri, 04 Dec 2009 22:59:43 GMT toby [59]
	# on 1999/02/19 16:01:46, toby did:
	Clean up file input dialogs for ...
Fri, 04 Dec 2009 22:59:35 GMT toby [52]
	# on 1999/02/16 18:03:01, toby did:
	change comment
Fri, 04 Dec 2009 22:59:30 GMT toby [47]
	# on 1999/01/25 19:53:04, toby did:
	fix bug in ChooseExpFil to allow ...
Fri, 04 Dec 2009 22:59:14 GMT toby [32]
	# on 1999/01/20 20:19:58, toby did:
	change labels on .EXP select menu
Fri, 04 Dec 2009 22:59:11 GMT toby [29]
	# on 1999/01/20 19:27:48, toby did:
	use custom file open box; fix ...
Fri, 04 Dec 2009 22:59:03 GMT toby [22]
	# on 1999/01/07 04:45:54, toby did:
	remove compressprog -- not used
Fri, 04 Dec 2009 22:58:58 GMT toby [17]
	* trunk/gsascmds.tcl (added)
	# on 1999/01/06 04:03:01, toby did:
