source: trunk/doc
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @403   12 years toby # on 2001/06/29 18:26:19, toby did: relabel "forward" button
(edit) @402   12 years toby # on 2001/06/29 18:23:57, toby did: Add bkgedit button description
(edit) @401   12 years toby # on 2001/06/29 18:20:12, toby did: major expansion -- explain page …
(edit) @386   12 years toby # on 2001/05/11 04:15:34, toby did: LIVEPLOT documentation
(edit) @375   12 years toby # on 2001/02/26 19:52:54, toby did: more stuff to do
(edit) @374   12 years toby # on 2001/02/26 19:52:54, toby did: long name warning
(edit) @369   12 years toby # on 2000/12/22 21:14:32, toby did: expand descriptions new sections …
(edit) @368   12 years toby # on 2000/12/22 21:14:32, toby did: expand archive documentation to …
(edit) @367   12 years toby # on 2000/12/22 21:14:32, toby did: minor edits, recommend tcl 8.2 now
(edit) @366   12 years toby # on 2000/12/22 21:14:32, toby did: Tcl/Tk? test section revised
(edit) @365   12 years toby # on 2000/12/22 21:14:32, toby did: document new option: autoraise in …
(edit) @364   12 years toby # on 2000/12/22 21:14:32, toby did: document error highlighting new …
(edit) @357   12 years toby # on 2000/12/22 19:17:42, toby did: testing Tcl/Tk? FAQ added
(edit) @356   12 years toby # on 2000/11/27 21:10:45, toby did: define XYZU+-F
(edit) @348   12 years toby # on 2000/11/21 21:21:57, toby did: more ideas
(edit) @347   12 years toby # on 2000/11/21 21:21:57, toby did: doc how to change fonts
(edit) @346   12 years toby # on 2000/11/21 21:21:57, toby did: use beige for neg contraints
(edit) @345   12 years toby # on 2000/10/23 14:41:11, toby did: more ideas from Lachlan
(edit) @344   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @343   12 years toby # on 2000/10/18 00:11:17, toby did: move utilites organize
(edit) @342   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @341   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @340   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @339   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @338   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @337   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @336   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @335   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @334   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @333   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @332   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @331   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @330   12 years toby # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup …
(edit) @329   12 years toby # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup …
(edit) @317   12 years toby # on 2000/10/12 21:15:58, toby did: * empty log message *
(edit) @316   12 years toby # on 2000/10/12 21:15:58, toby did: A listing of informational, …
(edit) @315   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output
(edit) @314   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output
(edit) @313   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors for on-line help
(edit) @312   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @311   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @310   12 years toby # on 2000/10/12 21:15:58, toby did: add anchors & more text for …
(edit) @309   12 years toby # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output add …
(edit) @308   12 years toby # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on …
(edit) @307   12 years toby # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on …
(edit) @302   12 years toby # on 2000/10/03 23:28:06, toby did: update to reflect latest changes
(edit) @301   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @300   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @299   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @298   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @297   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @296   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @295   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @294   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @293   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @292   12 years toby # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags to …
(edit) @291   12 years toby # on 2000/10/03 23:27:17, toby did: Add the NIST required ALT= tags to …
(edit) @282   12 years toby # on 2000/09/25 20:07:22, toby did: Add CIF import documentation
(edit) @281   12 years toby # on 2000/09/25 20:07:22, toby did: Add CIF import documentation
(edit) @279   12 years toby # on 2000/08/21 19:37:35, toby did: pretty up page with a table of links
(edit) @278   12 years toby # on 2000/08/21 19:37:09, toby did: pretty up page with table of links
(edit) @277   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @276   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @275   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @274   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @273   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @272   12 years toby # on 2000/08/21 19:36:29, toby did: pretty up page with table of links
(edit) @271   12 years toby # on 2000/08/21 19:35:43, toby did: update to reflect current progress
(edit) @270   12 years toby # on 2000/08/21 19:33:31, toby did: describe coordinate import routine …
(edit) @269   12 years toby # on 2000/08/21 19:27:43, toby did: describe coordinate import …
(edit) @260   12 years toby # on 2000/08/04 19:26:00, toby did: document phase flags
(edit) @259   12 years toby # on 2000/08/04 19:25:35, toby did: document atom xform/global set
(edit) @258   12 years toby # on 2000/08/04 19:24:50, toby did: expand "shortcut" discussion
(edit) @257   12 years toby # on 2000/08/04 19:24:21, toby did: sort by occ.
(edit) @256   12 years toby # on 2000/08/04 19:23:57, toby did: update with latest
(edit) @248   12 years toby # on 2000/07/28 20:27:10, toby did: note latest
(edit) @247   12 years toby # on 2000/07/28 20:20:03, toby did: document profile constraints
(edit) @246   12 years toby # on 2000/07/28 20:18:20, toby did: document change in profile button
(edit) @245   12 years toby # on 2000/07/28 20:17:40, toby did: note sort on header
(edit) @244   12 years toby # on 2000/07/28 20:16:33, toby did: document ODF
(edit) @243   12 years toby # on 2000/07/28 20:15:14, toby did: add CCP14 mirrors for gsas dist.
(edit) @242   12 years toby # on 2000/07/28 20:15:14, toby did: pretty it up
(edit) @241   12 years toby # on 2000/07/28 20:14:41, toby did: new additions andf ideas
(edit) @226   12 years toby # on 2000/07/03 21:44:27, toby did: make into multiple pages
(edit) @225   12 years toby # on 2000/07/03 21:43:33, toby did: Menu Contents
(edit) @224   12 years toby # on 2000/07/03 21:41:08, toby did: Preferential Orientation Pane
(edit) @223   12 years toby # on 2000/07/03 21:41:08, toby did: Constraints pane
(edit) @222   12 years toby # on 2000/07/03 21:41:08, toby did: Profile pane
(edit) @221   12 years toby # on 2000/07/03 21:41:08, toby did: Scaling pane
(edit) @220   12 years toby # on 2000/07/03 21:41:08, toby did: Histogram pane
(edit) @219   12 years toby # on 2000/07/03 21:41:08, toby did: Phase Pane
(edit) @218   12 years toby # on 2000/07/03 21:41:08, toby did: Least Squares (LS) Controls Pane
(edit) @217   12 years toby # on 2000/07/03 21:41:08, toby did: template
(edit) @216   12 years toby # on 2000/07/03 21:36:05, toby did: add more environment space
(edit) @215   12 years toby # on 2000/07/03 21:35:33, toby did: add multiplicity
(edit) @214   12 years toby # on 2000/06/09 04:27:36, toby did: Pref orientation in whats new
(edit) @213   12 years toby # on 2000/06/09 04:04:56, toby did: Whats happening in EXPGUI
(edit) @203   12 years toby # on 2000/06/09 03:54:23, toby did: Update to reflect new GSAS kit, …
(edit) @202   12 years toby # on 2000/06/09 03:53:28, toby did: Add Pref Orientation Section …
(edit) @178   12 years toby # on 2000/06/01 02:42:49, toby did: add tutorial reference
Note: See TracRevisionLog for help on using the revision log.
