# # ChangeLog for trunk/doc # # Generated by Trac 1.0.13 # Mar 7, 2021 2:55:50 AM Fri, 04 Dec 2009 23:07:28 GMT toby [516] * trunk/doc/expguic.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:27 GMT toby [515] * trunk/doc/expgui_Win_readme.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:26 GMT toby [514] * trunk/doc/expgui_Unix_readme.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:25 GMT toby [513] * trunk/doc/expgui_intro.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:24 GMT toby [512] * trunk/doc/expgui_cfg.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:23 GMT toby [511] * trunk/doc/expgui7.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:22 GMT toby [510] * trunk/doc/expgui6.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:21 GMT toby [509] * trunk/doc/expgui5.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:20 GMT toby [508] * trunk/doc/expgui4.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:19 GMT toby [507] * trunk/doc/expgui3.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:18 GMT toby [506] * trunk/doc/expgui2.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:17 GMT toby [505] * trunk/doc/expgui1.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:16 GMT toby [504] * trunk/doc/expgui0.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:15 GMT toby [503] * trunk/doc/expgui.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:14 GMT toby [502] * trunk/doc/excledt.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:09 GMT toby [497] * trunk/doc/expgui.html (modified) # on 2001/12/16 18:17:32, toby did: change GSAS version reference ... Fri, 04 Dec 2009 23:07:08 GMT toby [496] * trunk/doc/wishlist.html (modified) # on 2001/12/16 18:16:37, toby did: note showing .EXP status Fri, 04 Dec 2009 23:07:07 GMT toby [495] * trunk/doc/expguierr.html (modified) # on 2001/12/16 18:15:31, toby did: liveplot: explain the "FORTRAN" error Fri, 04 Dec 2009 23:06:58 GMT toby [486] * trunk/doc/wishlist.html (modified) # on 2001/11/07 19:02:53, toby did: new release (1.51) Fri, 04 Dec 2009 23:06:54 GMT toby [482] * trunk/doc/liveplot.html (modified) # on 2001/10/31 20:13:17, toby did: new shortcuts: next histogram ... Fri, 04 Dec 2009 23:06:53 GMT toby [481] * trunk/doc/excledt.html (modified) # on 2001/10/31 20:12:15, toby did: major revision for in-line routine Fri, 04 Dec 2009 23:06:37 GMT toby [465] * trunk/doc/wishlist.html (modified) # on 2001/10/18 23:17:12, toby did: updates Fri, 04 Dec 2009 23:06:36 GMT toby [464] * trunk/doc/liveplot.html (modified) # on 2001/10/18 23:17:12, toby did: new key bindings for reflection ... Fri, 04 Dec 2009 23:06:35 GMT toby [463] * trunk/doc/expguierr.html (modified) # on 2001/10/18 23:17:12, toby did: update archiving Fri, 04 Dec 2009 23:06:34 GMT toby [462] * trunk/doc/expguic.html (modified) # on 2001/10/18 23:17:12, toby did: update archiving Fri, 04 Dec 2009 23:06:33 GMT toby [461] * trunk/doc/expgui_cfg.html (modified) # on 2001/10/18 23:17:12, toby did: update archiving Fri, 04 Dec 2009 23:06:28 GMT toby [456] * trunk/doc/expgui.html (modified) # on 2001/10/14 05:33:15, toby did: plug mailing list Fri, 04 Dec 2009 23:06:27 GMT toby [455] * trunk/doc/wishlist.html (modified) # on 2001/10/14 05:32:26, toby did: .EXP coord import Fri, 04 Dec 2009 23:06:26 GMT toby [454] * trunk/doc/expgui2.html (modified) # on 2001/10/14 05:32:26, toby did: .EXP coord import Fri, 04 Dec 2009 23:06:18 GMT toby [446] * trunk/doc/expgui7.html (modified) # on 2001/09/25 23:22:48, toby did: better web sequencing Fri, 04 Dec 2009 23:06:17 GMT toby [445] * trunk/doc/expgui.html (modified) # on 2001/09/25 23:21:52, toby did: more links Fri, 04 Dec 2009 23:06:16 GMT toby [444] * trunk/doc/expgui3.html (modified) # on 2001/09/25 23:21:11, toby did: dummy histogram support Setting ... Fri, 04 Dec 2009 23:06:15 GMT toby [443] * trunk/doc/expgui_Unix_readme.html (modified) # on 2001/09/25 23:20:06, toby did: old GSAS warning new EXPTOOL Fri, 04 Dec 2009 23:06:14 GMT toby [442] * trunk/doc/expgui_Win_readme.html (modified) # on 2001/09/25 23:18:12, toby did: new GSAS website new EXPTOOL ... Fri, 04 Dec 2009 23:06:13 GMT toby [441] * trunk/doc/expguic.html (modified) # on 2001/09/25 23:17:30, toby did: updates Fri, 04 Dec 2009 23:06:12 GMT toby [440] * trunk/doc/expguierr.html (modified) # on 2001/09/25 23:16:40, toby did: document EXCLEDT and Dummy ... Fri, 04 Dec 2009 23:06:11 GMT toby [439] * trunk/doc/liveplot.html (modified) # on 2001/09/25 23:16:11, toby did: better integrate into ... Fri, 04 Dec 2009 23:06:10 GMT toby [438] * trunk/doc/wishlist.html (modified) # on 2001/09/25 23:15:31, toby did: update and shorten Fri, 04 Dec 2009 23:06:09 GMT toby [437] * trunk/doc/excledt.html (modified) # on 2001/09/25 23:13:18, toby did: improved Fri, 04 Dec 2009 23:06:08 GMT toby [436] * trunk/doc/expgui.html (modified) # on 2001/09/04 23:07:02, toby did: links to EXCLEDT & BKGEDIT spelling Fri, 04 Dec 2009 23:06:07 GMT toby [435] * trunk/doc/expgui3.html (modified) # on 2001/09/04 23:06:17, toby did: spelling Data Range & Excluded ... Fri, 04 Dec 2009 23:06:06 GMT toby [434] * trunk/doc/excledt.html (added) # on 2001/09/04 23:05:49, toby did: Describes EXCLEDT Fri, 04 Dec 2009 23:06:05 GMT toby [433] * trunk/doc/liveplot.html (modified) # on 2001/09/04 23:04:23, toby did: cleanup html select ... Fri, 04 Dec 2009 23:06:04 GMT toby [432] * trunk/doc/wishlist.html (modified) # on 2001/09/04 23:03:56, toby did: updated Fri, 04 Dec 2009 23:05:55 GMT toby [423] * trunk/doc/expgui_cfg.html (modified) # on 2001/09/04 22:13:06, toby did: describe how to override the ... Fri, 04 Dec 2009 23:05:44 GMT toby [412] * trunk/doc/expguierr.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:43 GMT toby [411] * trunk/doc/expgui_intro.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:42 GMT toby [410] * trunk/doc/expgui_cfg.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:41 GMT toby [409] * trunk/doc/expgui2.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:40 GMT toby [408] * trunk/doc/expgui.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:05:39 GMT toby [407] * trunk/doc/wishlist.html (modified) # on 2001/08/24 18:56:30, toby did: updated Fri, 04 Dec 2009 23:05:38 GMT toby [406] * trunk/doc/liveplot.html (modified) # on 2001/06/29 18:34:32, toby did: document bkgedit add cumulative ... Fri, 04 Dec 2009 23:05:37 GMT toby [405] * trunk/doc/expguic.html (modified) # on 2001/06/29 18:29:04, toby did: liveplot links Fri, 04 Dec 2009 23:05:36 GMT toby [404] * trunk/doc/expguic.html (modified) # on 2001/06/29 18:28:04, toby did: add archived files access Fri, 04 Dec 2009 23:05:35 GMT toby [403] * trunk/doc/expgui7.html (modified) # on 2001/06/29 18:26:19, toby did: relabel "forward" button Fri, 04 Dec 2009 23:05:34 GMT toby [402] * trunk/doc/expgui3.html (modified) # on 2001/06/29 18:23:57, toby did: Add bkgedit button description Fri, 04 Dec 2009 23:05:33 GMT toby [401] * trunk/doc/expgui1.html (modified) # on 2001/06/29 18:20:12, toby did: major expansion -- explain page ... Fri, 04 Dec 2009 23:05:18 GMT toby [386] * trunk/doc/liveplot.html (added) # on 2001/05/11 04:15:34, toby did: LIVEPLOT documentation Fri, 04 Dec 2009 23:05:07 GMT toby [375] * trunk/doc/wishlist.html (modified) # on 2001/02/26 19:52:54, toby did: more stuff to do Fri, 04 Dec 2009 23:05:06 GMT toby [374] * trunk/doc/expgui_Win_readme.html (modified) # on 2001/02/26 19:52:54, toby did: long name warning Fri, 04 Dec 2009 23:05:01 GMT toby [369] * trunk/doc/expguierr.html (modified) # on 2000/12/22 21:14:32, toby did: expand descriptions new ... Fri, 04 Dec 2009 23:05:00 GMT toby [368] * trunk/doc/expguic.html (modified) # on 2000/12/22 21:14:32, toby did: expand archive documentation to ... Fri, 04 Dec 2009 23:04:59 GMT toby [367] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/12/22 21:14:32, toby did: minor edits, recommend tcl 8.2 now Fri, 04 Dec 2009 23:04:58 GMT toby [366] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/12/22 21:14:32, toby did: Tcl/Tk test section revised Fri, 04 Dec 2009 23:04:57 GMT toby [365] * trunk/doc/expgui_cfg.html (modified) # on 2000/12/22 21:14:32, toby did: document new option: autoraise ... Fri, 04 Dec 2009 23:04:56 GMT toby [364] * trunk/doc/expgui.html (modified) # on 2000/12/22 21:14:32, toby did: document error highlighting new ... Fri, 04 Dec 2009 23:04:47 GMT toby [357] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/12/22 19:17:42, toby did: testing Tcl/Tk FAQ added Fri, 04 Dec 2009 23:04:45 GMT toby [356] * trunk/doc/expgui6.html (modified) # on 2000/11/27 21:10:45, toby did: define XYZU+-F Fri, 04 Dec 2009 23:04:33 GMT toby [348] * trunk/doc/wishlist.html (modified) # on 2000/11/21 21:21:57, toby did: more ideas Fri, 04 Dec 2009 23:04:32 GMT toby [347] * trunk/doc/expgui_cfg.html (modified) # on 2000/11/21 21:21:57, toby did: doc how to change fonts Fri, 04 Dec 2009 23:04:31 GMT toby [346] * trunk/doc/expgui6.html (modified) # on 2000/11/21 21:21:57, toby did: use beige for neg contraints Fri, 04 Dec 2009 23:04:30 GMT toby [345] * trunk/doc/wishlist.html (modified) # on 2000/10/23 14:41:11, toby did: more ideas from Lachlan Fri, 04 Dec 2009 23:04:29 GMT toby [344] * trunk/doc/wishlist.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:28 GMT toby [343] * trunk/doc/expguierr.html (modified) # on 2000/10/18 00:11:17, toby did: move utilites organize Fri, 04 Dec 2009 23:04:27 GMT toby [342] * trunk/doc/expguic.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:26 GMT toby [341] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:25 GMT toby [340] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:24 GMT toby [339] * trunk/doc/expgui_intro.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:23 GMT toby [338] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:04:22 GMT toby [337] * trunk/doc/expgui7.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:21 GMT toby [336] * trunk/doc/expgui6.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:20 GMT toby [335] * trunk/doc/expgui5.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:19 GMT toby [334] * trunk/doc/expgui4.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:18 GMT toby [333] * trunk/doc/expgui3.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:17 GMT toby [332] * trunk/doc/expgui2.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:16 GMT toby [331] * trunk/doc/expgui1.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:04:15 GMT toby [330] * trunk/doc/expgui0.html (modified) # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup ... Fri, 04 Dec 2009 23:04:14 GMT toby [329] * trunk/doc/expgui.html (modified) # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup ... Fri, 04 Dec 2009 23:04:02 GMT toby [317] * trunk/doc/wishlist.html (modified) # on 2000/10/12 21:15:58, toby did: *** empty log message *** Fri, 04 Dec 2009 23:04:01 GMT toby [316] * trunk/doc/expguierr.html (added) # on 2000/10/12 21:15:58, toby did: A listing of informational, ... Fri, 04 Dec 2009 23:04:00 GMT toby [315] * trunk/doc/expguic.html (modified) # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output Fri, 04 Dec 2009 23:03:59 GMT toby [314] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output Fri, 04 Dec 2009 23:03:58 GMT toby [313] * trunk/doc/expgui7.html (modified) # on 2000/10/12 21:15:58, toby did: add anchors for on-line help Fri, 04 Dec 2009 23:03:57 GMT toby [312] * trunk/doc/expgui6.html (modified) # on 2000/10/12 21:15:58, toby did: add anchors & more text for ... Fri, 04 Dec 2009 23:03:56 GMT toby [311] * trunk/doc/expgui5.html (modified) # on 2000/10/12 21:15:58, toby did: add anchors & more text for ... Fri, 04 Dec 2009 23:03:55 GMT toby [310] * trunk/doc/expgui3.html (modified) # on 2000/10/12 21:15:58, toby did: add anchors & more text for ... Fri, 04 Dec 2009 23:03:54 GMT toby [309] * trunk/doc/expgui2.html (modified) # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output add ... Fri, 04 Dec 2009 23:03:53 GMT toby [308] * trunk/doc/wishlist.html (modified) # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on ... Fri, 04 Dec 2009 23:03:52 GMT toby [307] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on ... Fri, 04 Dec 2009 23:03:47 GMT toby [302] * trunk/doc/wishlist.html (modified) # on 2000/10/03 23:28:06, toby did: update to reflect latest changes
