# # ChangeLog for trunk/doc # # Generated by Trac 1.0.13 # Apr 11, 2021 7:29:57 AM Fri, 04 Dec 2009 23:03:27 GMT toby [282] * trunk/doc/expgui_cfg.html (modified) # on 2000/09/25 20:07:22, toby did: Add CIF import documentation Fri, 04 Dec 2009 23:03:26 GMT toby [281] * trunk/doc/expgui2.html (modified) # on 2000/09/25 20:07:22, toby did: Add CIF import documentation Fri, 04 Dec 2009 23:03:24 GMT toby [279] * trunk/doc/expgui0.html (modified) # on 2000/08/21 19:37:35, toby did: pretty up page with a table of links Fri, 04 Dec 2009 23:03:23 GMT toby [278] * trunk/doc/expguic.html (modified) # on 2000/08/21 19:37:09, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:22 GMT toby [277] * trunk/doc/expgui7.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:21 GMT toby [276] * trunk/doc/expgui6.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:20 GMT toby [275] * trunk/doc/expgui5.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:19 GMT toby [274] * trunk/doc/expgui4.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:18 GMT toby [273] * trunk/doc/expgui3.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:17 GMT toby [272] * trunk/doc/expgui1.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:03:16 GMT toby [271] * trunk/doc/wishlist.html (modified) # on 2000/08/21 19:35:43, toby did: update to reflect current progress Fri, 04 Dec 2009 23:03:15 GMT toby [270] * trunk/doc/expgui_cfg.html (modified) # on 2000/08/21 19:33:31, toby did: describe coordinate import ... Fri, 04 Dec 2009 23:03:14 GMT toby [269] * trunk/doc/expgui2.html (modified) # on 2000/08/21 19:27:43, toby did: describe coordinate import ... Fri, 04 Dec 2009 23:03:05 GMT toby [260] * trunk/doc/expgui3.html (modified) # on 2000/08/04 19:26:00, toby did: document phase flags Fri, 04 Dec 2009 23:03:04 GMT toby [259] * trunk/doc/expgui2.html (modified) # on 2000/08/04 19:25:35, toby did: document atom xform/global set Fri, 04 Dec 2009 23:03:03 GMT toby [258] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/08/04 19:24:50, toby did: expand "shortcut" discussion Fri, 04 Dec 2009 23:03:02 GMT toby [257] * trunk/doc/expguic.html (modified) # on 2000/08/04 19:24:21, toby did: sort by occ. Fri, 04 Dec 2009 23:03:01 GMT toby [256] * trunk/doc/wishlist.html (modified) # on 2000/08/04 19:23:57, toby did: update with latest Fri, 04 Dec 2009 23:02:52 GMT toby [248] * trunk/doc/expgui_intro.html (modified) # on 2000/07/28 20:27:10, toby did: note latest Fri, 04 Dec 2009 23:02:51 GMT toby [247] * trunk/doc/expgui6.html (modified) # on 2000/07/28 20:20:03, toby did: document profile constraints Fri, 04 Dec 2009 23:02:50 GMT toby [246] * trunk/doc/expgui5.html (modified) # on 2000/07/28 20:18:20, toby did: document change in profile button Fri, 04 Dec 2009 23:02:49 GMT toby [245] * trunk/doc/expgui2.html (modified) # on 2000/07/28 20:17:40, toby did: note sort on header Fri, 04 Dec 2009 23:02:48 GMT toby [244] * trunk/doc/expgui7.html (modified) # on 2000/07/28 20:16:33, toby did: document ODF Fri, 04 Dec 2009 23:02:47 GMT toby [243] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/07/28 20:15:14, toby did: add CCP14 mirrors for gsas dist. Fri, 04 Dec 2009 23:02:46 GMT toby [242] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/07/28 20:15:14, toby did: pretty it up Fri, 04 Dec 2009 23:02:45 GMT toby [241] * trunk/doc/wishlist.html (modified) # on 2000/07/28 20:14:41, toby did: new additions andf ideas Fri, 04 Dec 2009 23:02:30 GMT toby [226] * trunk/doc/expgui.html (modified) # on 2000/07/03 21:44:27, toby did: make into multiple pages Fri, 04 Dec 2009 23:02:29 GMT toby [225] * trunk/doc/expguic.html (added) # on 2000/07/03 21:43:33, toby did: Menu Contents Fri, 04 Dec 2009 23:02:28 GMT toby [224] * trunk/doc/expgui7.html (added) # on 2000/07/03 21:41:08, toby did: Preferential Orientation Pane Fri, 04 Dec 2009 23:02:27 GMT toby [223] * trunk/doc/expgui6.html (added) # on 2000/07/03 21:41:08, toby did: Constraints pane Fri, 04 Dec 2009 23:02:26 GMT toby [222] * trunk/doc/expgui5.html (added) # on 2000/07/03 21:41:08, toby did: Profile pane Fri, 04 Dec 2009 23:02:25 GMT toby [221] * trunk/doc/expgui4.html (added) # on 2000/07/03 21:41:08, toby did: Scaling pane Fri, 04 Dec 2009 23:02:24 GMT toby [220] * trunk/doc/expgui3.html (added) # on 2000/07/03 21:41:08, toby did: Histogram pane Fri, 04 Dec 2009 23:02:23 GMT toby [219] * trunk/doc/expgui2.html (added) # on 2000/07/03 21:41:08, toby did: Phase Pane Fri, 04 Dec 2009 23:02:22 GMT toby [218] * trunk/doc/expgui1.html (added) # on 2000/07/03 21:41:08, toby did: Least Squares (LS) Controls Pane Fri, 04 Dec 2009 23:02:21 GMT toby [217] * trunk/doc/expgui0.html (added) # on 2000/07/03 21:41:08, toby did: template Fri, 04 Dec 2009 23:02:20 GMT toby [216] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/07/03 21:36:05, toby did: add more environment space Fri, 04 Dec 2009 23:02:19 GMT toby [215] * trunk/doc/wishlist.html (modified) # on 2000/07/03 21:35:33, toby did: add multiplicity Fri, 04 Dec 2009 23:02:18 GMT toby [214] * trunk/doc/expgui_intro.html (modified) # on 2000/06/09 04:27:36, toby did: Pref orientation in whats new Fri, 04 Dec 2009 23:02:17 GMT toby [213] * trunk/doc/wishlist.html (added) # on 2000/06/09 04:04:56, toby did: Whats happening in EXPGUI Fri, 04 Dec 2009 23:02:07 GMT toby [203] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/06/09 03:54:23, toby did: Update to reflect new GSAS kit, ... Fri, 04 Dec 2009 23:02:06 GMT toby [202] * trunk/doc/expgui.html (modified) # on 2000/06/09 03:53:28, toby did: Add Pref Orientation Section ... Fri, 04 Dec 2009 23:01:42 GMT toby [178] * trunk/doc/expgui_intro.html (modified) # on 2000/06/01 02:42:49, toby did: add tutorial reference Fri, 04 Dec 2009 23:01:19 GMT toby [155] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/05/26 14:12:58, toby did: complete gsaskit.exe repoint Fri, 04 Dec 2009 23:01:18 GMT toby [154] * trunk/doc/expgui.html (modified) # on 2000/05/26 14:12:58, toby did: document revised liveplot ... Fri, 04 Dec 2009 23:01:12 GMT toby [148] * trunk/doc/expgui.html (modified) # on 2000/05/18 15:37:38, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:01:11 GMT toby [147] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing Fri, 04 Dec 2009 23:01:10 GMT toby [146] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing Fri, 04 Dec 2009 23:01:09 GMT toby [145] * trunk/doc/expgui_intro.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing Fri, 04 Dec 2009 23:01:08 GMT toby [144] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:01:07 GMT toby [143] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/17 20:27:05, toby did: major edit Fri, 04 Dec 2009 23:01:06 GMT toby [142] * trunk/doc/expgui_intro.html (modified) # on 2000/05/17 20:23:13, toby did: cleanup Fri, 04 Dec 2009 23:01:05 GMT toby [141] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/05/17 20:11:07, toby did: cleanup & update Fri, 04 Dec 2009 23:01:04 GMT toby [140] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/05/17 20:09:20, toby did: cleanup & update Fri, 04 Dec 2009 23:00:39 GMT toby [115] * trunk/doc/expgui.html (modified) # on 1999/10/11 20:27:39, toby did: document "Group Phases Together" ... Fri, 04 Dec 2009 23:00:38 GMT toby [114] * trunk/doc/expgui_cfg.html (modified) # on 1999/10/11 20:27:13, toby did: Customization examples Fri, 04 Dec 2009 23:00:33 GMT toby [109] * trunk/doc/expgui_intro.html (modified) # on 1999/09/16 15:44:26, toby did: add version reference to EXPGUI ... Fri, 04 Dec 2009 23:00:32 GMT toby [108] * trunk/doc/expgui.html (modified) # on 1999/09/16 15:43:44, toby did: update 2.gif and 3.gif and text ... Fri, 04 Dec 2009 23:00:31 GMT toby [107] * trunk/doc/expgui_Win_readme.html (modified) # on 1999/09/09 21:00:32, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:30 GMT toby [106] * trunk/doc/expgui_Unix_readme.html (modified) # on 1999/09/09 21:00:32, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:29 GMT toby [105] * trunk/doc/expgui_cfg.html (modified) # on 1999/09/09 21:00:32, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:28 GMT toby [104] * trunk/doc/expgui_intro.html (modified) # on 1999/09/09 20:56:51, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:27 GMT toby [103] * trunk/doc/expgui.html (modified) # on 1999/09/09 20:56:51, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:20 GMT toby [96] * trunk/doc/expgui.html (modified) # on 1999/07/21 18:39:52, toby did: bring to current release make ... Fri, 04 Dec 2009 23:00:19 GMT toby [95] * trunk/doc/expgui_Unix_readme.html (modified) # on 1999/07/21 18:39:20, toby did: exptool updates Fri, 04 Dec 2009 23:00:18 GMT toby [94] * trunk/doc/expgui_intro.html (modified) # on 1999/07/21 16:51:57, toby did: add phase... update Fri, 04 Dec 2009 23:00:05 GMT toby [81] * trunk/doc/expgui_cfg.html (modified) # on 1999/04/08 20:39:33, toby did: Add new liveplot features refer ... Fri, 04 Dec 2009 23:00:04 GMT toby [80] * trunk/doc/expgui_Win_readme.html (modified) # on 1999/04/08 20:37:28, toby did: minor cleanups refer to tcldump ... Fri, 04 Dec 2009 22:59:54 GMT toby [70] * trunk/doc/expgui_Win_readme.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:53 GMT toby [69] * trunk/doc/expgui_Unix_readme.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:52 GMT toby [68] * trunk/doc/expgui_intro.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:51 GMT toby [67] * trunk/doc/expgui_cfg.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:50 GMT toby [66] * trunk/doc/expgui.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:49 GMT toby [65] * trunk/doc/expgui_Win_readme.html (modified) # on 1999/03/19 16:55:10, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:48 GMT toby [64] * trunk/doc/expgui_Unix_readme.html (modified) # on 1999/03/19 16:55:10, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:33 GMT toby [50] * trunk/doc/expgui_Win_readme.html (modified) # on 1999/02/02 17:32:47, toby did: updated -- use .zip for expgui Fri, 04 Dec 2009 22:59:24 GMT toby [42] * trunk/doc/expgui_cfg.html (modified) # on 1999/01/21 18:51:38, toby did: typo Fri, 04 Dec 2009 22:59:23 GMT toby [41] * trunk/doc/expgui_cfg.html (modified) # on 1999/01/21 18:30:17, toby did: 1st draft done Fri, 04 Dec 2009 22:59:22 GMT toby [40] * trunk/doc/expgui_intro.html (modified) # on 1999/01/20 21:35:47, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:21 GMT toby [39] * trunk/doc/expgui_Win_readme.html (modified) # on 1999/01/20 21:35:18, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:20 GMT toby [38] * trunk/doc/expgui_Unix_readme.html (modified) # on 1999/01/20 21:34:54, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:19 GMT toby [37] * trunk/doc/expgui.html (modified) # on 1999/01/20 21:34:11, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:18 GMT toby [36] * trunk/doc/expgui_cfg.html (added) # on 1999/01/20 21:33:38, toby did: Initial revision Fri, 04 Dec 2009 22:59:17 GMT toby [35] * trunk/doc/expgui.html (modified) # on 1999/01/20 21:29:37, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:16 GMT toby [34] * trunk/doc/expgui_Win_readme.html (added) # on 1999/01/20 21:28:23, toby did: Initial revision Fri, 04 Dec 2009 22:59:15 GMT toby [33] * trunk/doc/expgui_Unix_readme.html (added) # on 1999/01/20 21:28:08, toby did: Initial revision Fri, 04 Dec 2009 22:59:08 GMT toby [26] * trunk/doc/expgui.html (modified) # on 1999/01/13 04:36:53, toby did: move cd command later change ... Fri, 04 Dec 2009 22:59:07 GMT toby [25] * trunk/doc/expgui_intro.html (added) # on 1999/01/11 04:59:32, toby did: Initial revision Fri, 04 Dec 2009 22:59:05 GMT toby [24] * trunk/doc (added) * trunk/doc/expgui.html (added) # on 1999/01/11 04:58:27, toby did: Initial revision
