# # ChangeLog for trunk/doc/liveplot.html # # Generated by Trac 1.0.13 # Jun 16, 2021 10:28:56 PM Fri, 04 Dec 2009 23:11:24 GMT toby [751] * trunk/doc/liveplot.html (modified) # on 2003/11/13 17:31:03, toby did: revise to remove info about ... Fri, 04 Dec 2009 23:10:43 GMT toby [710] * trunk/doc/liveplot.html (modified) # on 2003/05/22 22:07:46, toby did: change to GSAS.CONFIG for Windows Fri, 04 Dec 2009 23:09:49 GMT toby [656] * trunk/doc/liveplot.html (modified) # on 2002/10/24 19:26:20, toby did: .csv plotting Fri, 04 Dec 2009 23:08:33 GMT toby [580] * trunk/doc/liveplot.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:08:05 GMT toby [552] * trunk/doc/liveplot.html (modified) # on 2002/01/23 20:00:50, toby did: clean up font references Fri, 04 Dec 2009 23:07:32 GMT toby [520] * trunk/doc/liveplot.html (modified) # on 2002/01/22 21:02:55, toby did: l-s in BKGEDT & support for ... Fri, 04 Dec 2009 23:07:30 GMT toby [518] * trunk/doc/liveplot.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:06:54 GMT toby [482] * trunk/doc/liveplot.html (modified) # on 2001/10/31 20:13:17, toby did: new shortcuts: next histogram ... Fri, 04 Dec 2009 23:06:36 GMT toby [464] * trunk/doc/liveplot.html (modified) # on 2001/10/18 23:17:12, toby did: new key bindings for reflection ... Fri, 04 Dec 2009 23:06:11 GMT toby [439] * trunk/doc/liveplot.html (modified) # on 2001/09/25 23:16:11, toby did: better integrate into ... Fri, 04 Dec 2009 23:06:05 GMT toby [433] * trunk/doc/liveplot.html (modified) # on 2001/09/04 23:04:23, toby did: cleanup html select ... Fri, 04 Dec 2009 23:05:38 GMT toby [406] * trunk/doc/liveplot.html (modified) # on 2001/06/29 18:34:32, toby did: document bkgedit add cumulative ... Fri, 04 Dec 2009 23:05:18 GMT toby [386] * trunk/doc/liveplot.html (added) # on 2001/05/11 04:15:34, toby did: LIVEPLOT documentation
