# # ChangeLog for trunk/doc/expgui_cfg.html # # Generated by Trac 1.0.13 # May 11, 2021 12:40:44 PM Sun, 28 Mar 2010 14:19:30 GMT toby [971] * trunk/doc/debug_tcltk.html (modified) * trunk/doc/excledt.html (modified) * trunk/doc/expgui.html (modified) * trunk/doc/expgui0.html (modified) * trunk/doc/expgui1.html (modified) * trunk/doc/expgui2.html (modified) * trunk/doc/expgui3.html (modified) * trunk/doc/expgui4.html (modified) * trunk/doc/expgui5.html (modified) * trunk/doc/expgui6.html (modified) * trunk/doc/expgui7.html (modified) * trunk/doc/expgui_Unix_readme.html (modified) * trunk/doc/expgui_Win_readme.html (modified) * trunk/doc/expgui_cfg.html (modified) * trunk/doc/expgui_intro.html (modified) * trunk/doc/expguic.html (modified) * trunk/doc/expguierr.html (modified) * trunk/doc/gsas2cif.html (modified) * trunk/doc/liveplot.html (modified) * trunk/doc/osx.html (modified) * trunk/doc/revlog.html (modified) * trunk/doc/win_old_notes.html (modified) * trunk/doc/wishlist.html (modified) change web pages to html Wed, 03 Mar 2010 15:27:00 GMT toby [935] * trunk/doc/expgui_cfg.html (modified) * trunk/expgui (modified) * trunk/gsascmds.tcl (modified) * trunk/import_cif.tcl (modified) EXPGUI: * Implement routine to locate window where user wants (see ... Fri, 04 Dec 2009 23:14:35 GMT toby [930] * trunk/addcmds.tcl (modified) * trunk/atomcons.tcl (modified) * trunk/browsecif.tcl (modified) * trunk/cif2fxye.tcl (modified) * trunk/cifselect.tcl (modified) * trunk/doc/debug_tcltk.html (modified) * trunk/doc/excledt.html (modified) * trunk/doc/expgui.html (modified) * trunk/doc/expgui0.html (modified) * trunk/doc/expgui1.html (modified) * trunk/doc/expgui2.html (modified) * trunk/doc/expgui3.html (modified) * trunk/doc/expgui4.html (modified) * trunk/doc/expgui5.html (modified) * trunk/doc/expgui6.html (modified) * trunk/doc/expgui7.html (modified) * trunk/doc/expgui_Unix_readme.html (modified) * trunk/doc/expgui_Win_readme.html (modified) * trunk/doc/expgui_cfg.html (modified) * trunk/doc/expgui_intro.html (modified) * trunk/doc/expguic.html (modified) * trunk/doc/expguierr.html (modified) * trunk/doc/gsas2cif.html (modified) * trunk/doc/liveplot.html (modified) * trunk/doc/osx.html (modified) * trunk/doc/win_old_notes.html (modified) * trunk/doc/wishlist.html (modified) * trunk/dumpexp.tcl (modified) * trunk/dumpprof.tcl (modified) * trunk/excledt.tcl (modified) * trunk/exclinit.tcl (modified) * trunk/expgui (modified) * trunk/expgui_zip.bat (modified) * trunk/export_cif.tcl (modified) * trunk/export_drawxtl.tcl (modified) * trunk/export_example.example (modified) * trunk/export_shelx.tcl (modified) * trunk/export_spf.tcl (modified) * trunk/export_xml.tcl (modified) * trunk/export_xtl.tcl (modified) * trunk/fillcif.tcl (modified) * trunk/graceexport.tcl (modified) * trunk/gsascmds.tcl (modified) * trunk/gsasmenu.tcl (modified) * trunk/gsasnowt.bat (modified) * trunk/gsastcl.bat (modified) * trunk/import_cell.tcl (modified) * trunk/import_cif.tcl (modified) * trunk/import_gsas.tcl (modified) * trunk/import_spf.tcl (modified) * trunk/import_xtl.tcl (modified) * trunk/instedit.tcl (modified) * trunk/liveplot (modified) * trunk/liveplot_FoxExport.tcl (modified) * trunk/lstview (modified) * trunk/mkdictindex.tcl (modified) * trunk/notebook.tcl (modified) * trunk/odf.tcl (modified) * trunk/opts.tcl (modified) * trunk/orient.tcl (modified) * trunk/profcons.tcl (modified) * trunk/readexp.tcl (modified) * trunk/readinst.tcl (modified) * trunk/spacegrp.ref (modified) * trunk/tutorial1/index.html (modified) * trunk/tutorial1/nickel1.html (modified) * trunk/tutorial1/nickel2.html (modified) * trunk/tutorial1/nickel3.html (modified) * trunk/tutorial1/nickel4.html (modified) * trunk/tutorial1/nickel5.html (modified) * trunk/tutorial1/nickel6.html (modified) * trunk/tutorial1/nickel7.html (modified) * trunk/tutorial1/nickel8.html (modified) * trunk/tutorial1/nickel9.html (modified) * trunk/tutorial1/nickelnotes.html (modified) * trunk/tutorial2/garnet1.html (modified) * trunk/tutorial2/garnet2.html (modified) * trunk/tutorial2/garnet3.html (modified) * trunk/tutorial2/garnet4.html (modified) * trunk/tutorial2/garnet5.html (modified) * trunk/tutorial2/garnet6.html (modified) * trunk/tutorial2/garnet7.html (modified) * trunk/tutorial2/garnet8.html (modified) * trunk/tutorial2/garnet9.html (modified) * trunk/tutorial2/index.html (modified) * trunk/tutorial3/alumina0.html (modified) * trunk/tutorial3/alumina1.html (modified) * trunk/tutorial3/alumina10.html (modified) * trunk/tutorial3/alumina11.html (modified) * trunk/tutorial3/alumina2.html (modified) * trunk/tutorial3/alumina3.html (modified) * trunk/tutorial3/alumina4.html (modified) * trunk/tutorial3/alumina5.html (modified) * trunk/tutorial3/alumina6.html (modified) * trunk/tutorial3/alumina7.html (modified) * trunk/tutorial3/alumina8.html (modified) * trunk/tutorial3/alumina9.html (modified) * trunk/tutorial3/index.html (modified) * trunk/widplt (modified) rcs:* properties removed Fri, 04 Dec 2009 23:13:54 GMT toby [896] * trunk/doc/expgui_cfg.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:44 GMT toby [886] * trunk/doc/expgui_cfg.html (modified) # on 2007/01/17 04:38:58, toby did: remove NIST web exit hijacks & ... Fri, 04 Dec 2009 23:13:19 GMT toby [862] * trunk/doc/expgui_cfg.html (modified) # on 2005/12/16 00:42:42, toby did: pane --> panel Fri, 04 Dec 2009 23:12:30 GMT toby [814] * trunk/doc/expgui_cfg.html (modified) # on 2004/09/28 22:41:37, toby did: word tweaking Fri, 04 Dec 2009 23:11:08 GMT toby [735] * trunk/doc/expgui_cfg.html (modified) # on 2003/08/11 19:37:34, toby did: exit LANL Fri, 04 Dec 2009 23:10:39 GMT toby [706] * trunk/doc/expgui_cfg.html (modified) # on 2003/05/22 22:05:22, toby did: change to GSAS.CONFIG for Windows Fri, 04 Dec 2009 23:10:14 GMT toby [681] * trunk/doc/expgui_cfg.html (modified) # on 2003/04/10 22:26:27, toby did: fix localconfig reference Fri, 04 Dec 2009 23:08:27 GMT toby [574] * trunk/doc/expgui_cfg.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:08:03 GMT toby [550] * trunk/doc/expgui_cfg.html (modified) # on 2002/01/23 20:00:50, toby did: clean up font references Fri, 04 Dec 2009 23:07:36 GMT toby [524] * trunk/doc/expgui_cfg.html (modified) # on 2002/01/22 21:08:12, toby did: add coordinate export section ... Fri, 04 Dec 2009 23:07:24 GMT toby [512] * trunk/doc/expgui_cfg.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:06:33 GMT toby [461] * trunk/doc/expgui_cfg.html (modified) # on 2001/10/18 23:17:12, toby did: update archiving Fri, 04 Dec 2009 23:05:55 GMT toby [423] * trunk/doc/expgui_cfg.html (modified) # on 2001/09/04 22:13:06, toby did: describe how to override the ... Fri, 04 Dec 2009 23:05:42 GMT toby [410] * trunk/doc/expgui_cfg.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:04:57 GMT toby [365] * trunk/doc/expgui_cfg.html (modified) # on 2000/12/22 21:14:32, toby did: document new option: autoraise ... Fri, 04 Dec 2009 23:04:32 GMT toby [347] * trunk/doc/expgui_cfg.html (modified) # on 2000/11/21 21:21:57, toby did: doc how to change fonts Fri, 04 Dec 2009 23:04:23 GMT toby [338] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:03:59 GMT toby [314] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output Fri, 04 Dec 2009 23:03:52 GMT toby [307] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on ... Fri, 04 Dec 2009 23:03:44 GMT toby [299] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:03:27 GMT toby [282] * trunk/doc/expgui_cfg.html (modified) # on 2000/09/25 20:07:22, toby did: Add CIF import documentation Fri, 04 Dec 2009 23:03:15 GMT toby [270] * trunk/doc/expgui_cfg.html (modified) # on 2000/08/21 19:33:31, toby did: describe coordinate import ... Fri, 04 Dec 2009 23:01:08 GMT toby [144] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:01:07 GMT toby [143] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/17 20:27:05, toby did: major edit Fri, 04 Dec 2009 23:00:38 GMT toby [114] * trunk/doc/expgui_cfg.html (modified) # on 1999/10/11 20:27:13, toby did: Customization examples Fri, 04 Dec 2009 23:00:29 GMT toby [105] * trunk/doc/expgui_cfg.html (modified) # on 1999/09/09 21:00:32, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:05 GMT toby [81] * trunk/doc/expgui_cfg.html (modified) # on 1999/04/08 20:39:33, toby did: Add new liveplot features refer ... Fri, 04 Dec 2009 22:59:51 GMT toby [67] * trunk/doc/expgui_cfg.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:24 GMT toby [42] * trunk/doc/expgui_cfg.html (modified) # on 1999/01/21 18:51:38, toby did: typo Fri, 04 Dec 2009 22:59:23 GMT toby [41] * trunk/doc/expgui_cfg.html (modified) # on 1999/01/21 18:30:17, toby did: 1st draft done Fri, 04 Dec 2009 22:59:18 GMT toby [36] * trunk/doc/expgui_cfg.html (added) # on 1999/01/20 21:33:38, toby did: Initial revision
