# # ChangeLog for trunk/doc/expgui_cfg.html # # Generated by Trac 1.0.13 # Dec 8, 2021 1:34:03 AM Fri, 04 Dec 2009 23:08:27 GMT toby [574] * trunk/doc/expgui_cfg.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:08:03 GMT toby [550] * trunk/doc/expgui_cfg.html (modified) # on 2002/01/23 20:00:50, toby did: clean up font references Fri, 04 Dec 2009 23:07:36 GMT toby [524] * trunk/doc/expgui_cfg.html (modified) # on 2002/01/22 21:08:12, toby did: add coordinate export section ... Fri, 04 Dec 2009 23:07:24 GMT toby [512] * trunk/doc/expgui_cfg.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:06:33 GMT toby [461] * trunk/doc/expgui_cfg.html (modified) # on 2001/10/18 23:17:12, toby did: update archiving Fri, 04 Dec 2009 23:05:55 GMT toby [423] * trunk/doc/expgui_cfg.html (modified) # on 2001/09/04 22:13:06, toby did: describe how to override the ... Fri, 04 Dec 2009 23:05:42 GMT toby [410] * trunk/doc/expgui_cfg.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:04:57 GMT toby [365] * trunk/doc/expgui_cfg.html (modified) # on 2000/12/22 21:14:32, toby did: document new option: autoraise ... Fri, 04 Dec 2009 23:04:32 GMT toby [347] * trunk/doc/expgui_cfg.html (modified) # on 2000/11/21 21:21:57, toby did: doc how to change fonts Fri, 04 Dec 2009 23:04:23 GMT toby [338] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting Fri, 04 Dec 2009 23:03:59 GMT toby [314] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output Fri, 04 Dec 2009 23:03:52 GMT toby [307] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/04 20:39:22, toby did: document expgui(bkgcolor1) on ... Fri, 04 Dec 2009 23:03:44 GMT toby [299] * trunk/doc/expgui_cfg.html (modified) # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:03:27 GMT toby [282] * trunk/doc/expgui_cfg.html (modified) # on 2000/09/25 20:07:22, toby did: Add CIF import documentation Fri, 04 Dec 2009 23:03:15 GMT toby [270] * trunk/doc/expgui_cfg.html (modified) # on 2000/08/21 19:33:31, toby did: describe coordinate import ... Fri, 04 Dec 2009 23:01:08 GMT toby [144] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:01:07 GMT toby [143] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/17 20:27:05, toby did: major edit Fri, 04 Dec 2009 23:00:38 GMT toby [114] * trunk/doc/expgui_cfg.html (modified) # on 1999/10/11 20:27:13, toby did: Customization examples Fri, 04 Dec 2009 23:00:29 GMT toby [105] * trunk/doc/expgui_cfg.html (modified) # on 1999/09/09 21:00:32, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:05 GMT toby [81] * trunk/doc/expgui_cfg.html (modified) # on 1999/04/08 20:39:33, toby did: Add new liveplot features refer ... Fri, 04 Dec 2009 22:59:51 GMT toby [67] * trunk/doc/expgui_cfg.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:24 GMT toby [42] * trunk/doc/expgui_cfg.html (modified) # on 1999/01/21 18:51:38, toby did: typo Fri, 04 Dec 2009 22:59:23 GMT toby [41] * trunk/doc/expgui_cfg.html (modified) # on 1999/01/21 18:30:17, toby did: 1st draft done Fri, 04 Dec 2009 22:59:18 GMT toby [36] * trunk/doc/expgui_cfg.html (added) # on 1999/01/20 21:33:38, toby did: Initial revision
