# # ChangeLog for trunk/doc/expgui6.html # # Generated by Trac 1.0.13 # Jan 25, 2022 6:12:46 AM Fri, 04 Dec 2009 23:08:25 GMT toby [572] * trunk/doc/expgui6.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:07:33 GMT toby [521] * trunk/doc/expgui6.html (modified) # on 2002/01/22 21:05:10, toby did: MM constraints Fri, 04 Dec 2009 23:07:22 GMT toby [510] * trunk/doc/expgui6.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:04:45 GMT toby [356] * trunk/doc/expgui6.html (modified) # on 2000/11/27 21:10:45, toby did: define XYZU+-F Fri, 04 Dec 2009 23:04:31 GMT toby [346] * trunk/doc/expgui6.html (modified) # on 2000/11/21 21:21:57, toby did: use beige for neg contraints Fri, 04 Dec 2009 23:04:21 GMT toby [336] * trunk/doc/expgui6.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:03:57 GMT toby [312] * trunk/doc/expgui6.html (modified) # on 2000/10/12 21:15:58, toby did: add anchors & more text for ... Fri, 04 Dec 2009 23:03:42 GMT toby [297] * trunk/doc/expgui6.html (modified) # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:03:21 GMT toby [276] * trunk/doc/expgui6.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:02:51 GMT toby [247] * trunk/doc/expgui6.html (modified) # on 2000/07/28 20:20:03, toby did: document profile constraints Fri, 04 Dec 2009 23:02:27 GMT toby [223] * trunk/doc/expgui6.html (added) # on 2000/07/03 21:41:08, toby did: Constraints pane
