# # ChangeLog for trunk/doc/expgui2.html # # Generated by Trac 1.0.13 # Nov 29, 2021 7:00:53 AM Fri, 04 Dec 2009 23:08:21 GMT toby [568] * trunk/doc/expgui2.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:07:38 GMT toby [526] * trunk/doc/expgui2.html (modified) # on 2002/01/22 21:12:22, toby did: reference coordinate import ... Fri, 04 Dec 2009 23:07:18 GMT toby [506] * trunk/doc/expgui2.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:06:26 GMT toby [454] * trunk/doc/expgui2.html (modified) # on 2001/10/14 05:32:26, toby did: .EXP coord import Fri, 04 Dec 2009 23:05:41 GMT toby [409] * trunk/doc/expgui2.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:04:17 GMT toby [332] * trunk/doc/expgui2.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:03:54 GMT toby [309] * trunk/doc/expgui2.html (modified) # on 2000/10/12 21:15:58, toby did: optional EXPTOOL output add ... Fri, 04 Dec 2009 23:03:38 GMT toby [293] * trunk/doc/expgui2.html (modified) # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:03:26 GMT toby [281] * trunk/doc/expgui2.html (modified) # on 2000/09/25 20:07:22, toby did: Add CIF import documentation Fri, 04 Dec 2009 23:03:14 GMT toby [269] * trunk/doc/expgui2.html (modified) # on 2000/08/21 19:27:43, toby did: describe coordinate import ... Fri, 04 Dec 2009 23:03:04 GMT toby [259] * trunk/doc/expgui2.html (modified) # on 2000/08/04 19:25:35, toby did: document atom xform/global set Fri, 04 Dec 2009 23:02:49 GMT toby [245] * trunk/doc/expgui2.html (modified) # on 2000/07/28 20:17:40, toby did: note sort on header Fri, 04 Dec 2009 23:02:23 GMT toby [219] * trunk/doc/expgui2.html (added) # on 2000/07/03 21:41:08, toby did: Phase Pane
