# # ChangeLog for trunk/doc/expgui2.html # # Generated by Trac 1.0.13 # May 14, 2021 11:09:58 PM Fri, 04 Dec 2009 23:03:38 GMT toby [293] * trunk/doc/expgui2.html (modified) # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:03:26 GMT toby [281] * trunk/doc/expgui2.html (modified) # on 2000/09/25 20:07:22, toby did: Add CIF import documentation Fri, 04 Dec 2009 23:03:14 GMT toby [269] * trunk/doc/expgui2.html (modified) # on 2000/08/21 19:27:43, toby did: describe coordinate import ... Fri, 04 Dec 2009 23:03:04 GMT toby [259] * trunk/doc/expgui2.html (modified) # on 2000/08/04 19:25:35, toby did: document atom xform/global set Fri, 04 Dec 2009 23:02:49 GMT toby [245] * trunk/doc/expgui2.html (modified) # on 2000/07/28 20:17:40, toby did: note sort on header Fri, 04 Dec 2009 23:02:23 GMT toby [219] * trunk/doc/expgui2.html (added) # on 2000/07/03 21:41:08, toby did: Phase Pane
