# # ChangeLog for trunk/doc/expgui1.html # # Generated by Trac 1.0.13 # May 6, 2021 10:53:34 AM Sun, 28 Mar 2010 14:19:30 GMT toby [971] * trunk/doc/debug_tcltk.html (modified) * trunk/doc/excledt.html (modified) * trunk/doc/expgui.html (modified) * trunk/doc/expgui0.html (modified) * trunk/doc/expgui1.html (modified) * trunk/doc/expgui2.html (modified) * trunk/doc/expgui3.html (modified) * trunk/doc/expgui4.html (modified) * trunk/doc/expgui5.html (modified) * trunk/doc/expgui6.html (modified) * trunk/doc/expgui7.html (modified) * trunk/doc/expgui_Unix_readme.html (modified) * trunk/doc/expgui_Win_readme.html (modified) * trunk/doc/expgui_cfg.html (modified) * trunk/doc/expgui_intro.html (modified) * trunk/doc/expguic.html (modified) * trunk/doc/expguierr.html (modified) * trunk/doc/gsas2cif.html (modified) * trunk/doc/liveplot.html (modified) * trunk/doc/osx.html (modified) * trunk/doc/revlog.html (modified) * trunk/doc/win_old_notes.html (modified) * trunk/doc/wishlist.html (modified) change web pages to html Fri, 04 Dec 2009 23:14:35 GMT toby [930] * trunk/addcmds.tcl (modified) * trunk/atomcons.tcl (modified) * trunk/browsecif.tcl (modified) * trunk/cif2fxye.tcl (modified) * trunk/cifselect.tcl (modified) * trunk/doc/debug_tcltk.html (modified) * trunk/doc/excledt.html (modified) * trunk/doc/expgui.html (modified) * trunk/doc/expgui0.html (modified) * trunk/doc/expgui1.html (modified) * trunk/doc/expgui2.html (modified) * trunk/doc/expgui3.html (modified) * trunk/doc/expgui4.html (modified) * trunk/doc/expgui5.html (modified) * trunk/doc/expgui6.html (modified) * trunk/doc/expgui7.html (modified) * trunk/doc/expgui_Unix_readme.html (modified) * trunk/doc/expgui_Win_readme.html (modified) * trunk/doc/expgui_cfg.html (modified) * trunk/doc/expgui_intro.html (modified) * trunk/doc/expguic.html (modified) * trunk/doc/expguierr.html (modified) * trunk/doc/gsas2cif.html (modified) * trunk/doc/liveplot.html (modified) * trunk/doc/osx.html (modified) * trunk/doc/win_old_notes.html (modified) * trunk/doc/wishlist.html (modified) * trunk/dumpexp.tcl (modified) * trunk/dumpprof.tcl (modified) * trunk/excledt.tcl (modified) * trunk/exclinit.tcl (modified) * trunk/expgui (modified) * trunk/expgui_zip.bat (modified) * trunk/export_cif.tcl (modified) * trunk/export_drawxtl.tcl (modified) * trunk/export_example.example (modified) * trunk/export_shelx.tcl (modified) * trunk/export_spf.tcl (modified) * trunk/export_xml.tcl (modified) * trunk/export_xtl.tcl (modified) * trunk/fillcif.tcl (modified) * trunk/graceexport.tcl (modified) * trunk/gsascmds.tcl (modified) * trunk/gsasmenu.tcl (modified) * trunk/gsasnowt.bat (modified) * trunk/gsastcl.bat (modified) * trunk/import_cell.tcl (modified) * trunk/import_cif.tcl (modified) * trunk/import_gsas.tcl (modified) * trunk/import_spf.tcl (modified) * trunk/import_xtl.tcl (modified) * trunk/instedit.tcl (modified) * trunk/liveplot (modified) * trunk/liveplot_FoxExport.tcl (modified) * trunk/lstview (modified) * trunk/mkdictindex.tcl (modified) * trunk/notebook.tcl (modified) * trunk/odf.tcl (modified) * trunk/opts.tcl (modified) * trunk/orient.tcl (modified) * trunk/profcons.tcl (modified) * trunk/readexp.tcl (modified) * trunk/readinst.tcl (modified) * trunk/spacegrp.ref (modified) * trunk/tutorial1/index.html (modified) * trunk/tutorial1/nickel1.html (modified) * trunk/tutorial1/nickel2.html (modified) * trunk/tutorial1/nickel3.html (modified) * trunk/tutorial1/nickel4.html (modified) * trunk/tutorial1/nickel5.html (modified) * trunk/tutorial1/nickel6.html (modified) * trunk/tutorial1/nickel7.html (modified) * trunk/tutorial1/nickel8.html (modified) * trunk/tutorial1/nickel9.html (modified) * trunk/tutorial1/nickelnotes.html (modified) * trunk/tutorial2/garnet1.html (modified) * trunk/tutorial2/garnet2.html (modified) * trunk/tutorial2/garnet3.html (modified) * trunk/tutorial2/garnet4.html (modified) * trunk/tutorial2/garnet5.html (modified) * trunk/tutorial2/garnet6.html (modified) * trunk/tutorial2/garnet7.html (modified) * trunk/tutorial2/garnet8.html (modified) * trunk/tutorial2/garnet9.html (modified) * trunk/tutorial2/index.html (modified) * trunk/tutorial3/alumina0.html (modified) * trunk/tutorial3/alumina1.html (modified) * trunk/tutorial3/alumina10.html (modified) * trunk/tutorial3/alumina11.html (modified) * trunk/tutorial3/alumina2.html (modified) * trunk/tutorial3/alumina3.html (modified) * trunk/tutorial3/alumina4.html (modified) * trunk/tutorial3/alumina5.html (modified) * trunk/tutorial3/alumina6.html (modified) * trunk/tutorial3/alumina7.html (modified) * trunk/tutorial3/alumina8.html (modified) * trunk/tutorial3/alumina9.html (modified) * trunk/tutorial3/index.html (modified) * trunk/widplt (modified) rcs:* properties removed Fri, 04 Dec 2009 23:13:12 GMT toby [855] * trunk/doc/expgui1.html (modified) # on 2005/12/16 00:39:30, toby did: pane --> panel Fri, 04 Dec 2009 23:08:20 GMT toby [567] * trunk/doc/expgui1.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:07:17 GMT toby [505] * trunk/doc/expgui1.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:05:33 GMT toby [401] * trunk/doc/expgui1.html (modified) # on 2001/06/29 18:20:12, toby did: major expansion -- explain page ... Fri, 04 Dec 2009 23:04:16 GMT toby [331] * trunk/doc/expgui1.html (modified) # on 2000/10/18 00:11:17, toby did: fixup formatting Fri, 04 Dec 2009 23:03:37 GMT toby [292] * trunk/doc/expgui1.html (modified) # on 2000/10/03 23:28:06, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:03:17 GMT toby [272] * trunk/doc/expgui1.html (modified) # on 2000/08/21 19:36:29, toby did: pretty up page with table of links Fri, 04 Dec 2009 23:02:22 GMT toby [218] * trunk/doc/expgui1.html (added) # on 2000/07/03 21:41:08, toby did: Least Squares (LS) Controls Pane
