# # ChangeLog for trunk/doc/expgui.html # # Generated by Trac 1.0.13 # Aug 3, 2021 11:27:54 AM Fri, 04 Dec 2009 23:14:35 GMT toby [930] * trunk/addcmds.tcl (modified) * trunk/atomcons.tcl (modified) * trunk/browsecif.tcl (modified) * trunk/cif2fxye.tcl (modified) * trunk/cifselect.tcl (modified) * trunk/doc/debug_tcltk.html (modified) * trunk/doc/excledt.html (modified) * trunk/doc/expgui.html (modified) * trunk/doc/expgui0.html (modified) * trunk/doc/expgui1.html (modified) * trunk/doc/expgui2.html (modified) * trunk/doc/expgui3.html (modified) * trunk/doc/expgui4.html (modified) * trunk/doc/expgui5.html (modified) * trunk/doc/expgui6.html (modified) * trunk/doc/expgui7.html (modified) * trunk/doc/expgui_Unix_readme.html (modified) * trunk/doc/expgui_Win_readme.html (modified) * trunk/doc/expgui_cfg.html (modified) * trunk/doc/expgui_intro.html (modified) * trunk/doc/expguic.html (modified) * trunk/doc/expguierr.html (modified) * trunk/doc/gsas2cif.html (modified) * trunk/doc/liveplot.html (modified) * trunk/doc/osx.html (modified) * trunk/doc/win_old_notes.html (modified) * trunk/doc/wishlist.html (modified) * trunk/dumpexp.tcl (modified) * trunk/dumpprof.tcl (modified) * trunk/excledt.tcl (modified) * trunk/exclinit.tcl (modified) * trunk/expgui (modified) * trunk/expgui_zip.bat (modified) * trunk/export_cif.tcl (modified) * trunk/export_drawxtl.tcl (modified) * trunk/export_example.example (modified) * trunk/export_shelx.tcl (modified) * trunk/export_spf.tcl (modified) * trunk/export_xml.tcl (modified) * trunk/export_xtl.tcl (modified) * trunk/fillcif.tcl (modified) * trunk/graceexport.tcl (modified) * trunk/gsascmds.tcl (modified) * trunk/gsasmenu.tcl (modified) * trunk/gsasnowt.bat (modified) * trunk/gsastcl.bat (modified) * trunk/import_cell.tcl (modified) * trunk/import_cif.tcl (modified) * trunk/import_gsas.tcl (modified) * trunk/import_spf.tcl (modified) * trunk/import_xtl.tcl (modified) * trunk/instedit.tcl (modified) * trunk/liveplot (modified) * trunk/liveplot_FoxExport.tcl (modified) * trunk/lstview (modified) * trunk/mkdictindex.tcl (modified) * trunk/notebook.tcl (modified) * trunk/odf.tcl (modified) * trunk/opts.tcl (modified) * trunk/orient.tcl (modified) * trunk/profcons.tcl (modified) * trunk/readexp.tcl (modified) * trunk/readinst.tcl (modified) * trunk/spacegrp.ref (modified) * trunk/tutorial1/index.html (modified) * trunk/tutorial1/nickel1.html (modified) * trunk/tutorial1/nickel2.html (modified) * trunk/tutorial1/nickel3.html (modified) * trunk/tutorial1/nickel4.html (modified) * trunk/tutorial1/nickel5.html (modified) * trunk/tutorial1/nickel6.html (modified) * trunk/tutorial1/nickel7.html (modified) * trunk/tutorial1/nickel8.html (modified) * trunk/tutorial1/nickel9.html (modified) * trunk/tutorial1/nickelnotes.html (modified) * trunk/tutorial2/garnet1.html (modified) * trunk/tutorial2/garnet2.html (modified) * trunk/tutorial2/garnet3.html (modified) * trunk/tutorial2/garnet4.html (modified) * trunk/tutorial2/garnet5.html (modified) * trunk/tutorial2/garnet6.html (modified) * trunk/tutorial2/garnet7.html (modified) * trunk/tutorial2/garnet8.html (modified) * trunk/tutorial2/garnet9.html (modified) * trunk/tutorial2/index.html (modified) * trunk/tutorial3/alumina0.html (modified) * trunk/tutorial3/alumina1.html (modified) * trunk/tutorial3/alumina10.html (modified) * trunk/tutorial3/alumina11.html (modified) * trunk/tutorial3/alumina2.html (modified) * trunk/tutorial3/alumina3.html (modified) * trunk/tutorial3/alumina4.html (modified) * trunk/tutorial3/alumina5.html (modified) * trunk/tutorial3/alumina6.html (modified) * trunk/tutorial3/alumina7.html (modified) * trunk/tutorial3/alumina8.html (modified) * trunk/tutorial3/alumina9.html (modified) * trunk/tutorial3/index.html (modified) * trunk/widplt (modified) rcs:* properties removed Fri, 04 Dec 2009 23:13:53 GMT toby [895] * trunk/doc/expgui.html (modified) # on 2007/01/25 22:56:52, toby did: Remove @nist addresses Fri, 04 Dec 2009 23:13:43 GMT toby [885] * trunk/doc/expgui.html (modified) # on 2007/01/17 04:37:21, toby did: remove NIST web exit hijacks ... Fri, 04 Dec 2009 23:13:11 GMT toby [854] * trunk/doc/expgui.html (modified) # on 2005/12/16 00:38:52, toby did: pane --> panel Fri, 04 Dec 2009 23:12:50 GMT toby [834] * trunk/doc/expgui.html (modified) # on 2005/02/09 21:48:18, toby did: download link Fri, 04 Dec 2009 23:12:27 GMT toby [811] * trunk/doc/expgui.html (modified) # on 2004/09/28 22:39:24, toby did: add anchor Fri, 04 Dec 2009 23:11:40 GMT toby [766] * trunk/doc/expgui.html (modified) # on 2004/01/12 19:41:52, toby did: add OSX ref Fri, 04 Dec 2009 23:11:05 GMT toby [732] * trunk/doc/expgui.html (modified) # on 2003/08/11 19:36:17, toby did: exit LANL Fri, 04 Dec 2009 23:10:37 GMT toby [704] * trunk/doc/expgui.html (modified) # on 2003/05/22 22:05:22, toby did: Document INSTEDIT Fri, 04 Dec 2009 23:09:08 GMT toby [615] * trunk/doc/expgui.html (modified) # on 2002/07/18 20:27:39, toby did: new tutorial Fri, 04 Dec 2009 23:09:04 GMT toby [611] * trunk/doc/expgui.html (modified) # on 2002/07/18 20:01:41, toby did: add gsas2cif reference Fri, 04 Dec 2009 23:08:18 GMT toby [565] * trunk/doc/expgui.html (modified) # on 2002/04/12 19:49:04, toby did: remove identification stuff Fri, 04 Dec 2009 23:08:00 GMT toby [547] * trunk/doc/expgui.html (modified) # on 2002/01/23 19:59:05, toby did: thanks John! Fri, 04 Dec 2009 23:07:35 GMT toby [523] * trunk/doc/expgui.html (modified) # on 2002/01/22 21:06:17, toby did: ABSPLT improve utility section ... Fri, 04 Dec 2009 23:07:15 GMT toby [503] * trunk/doc/expgui.html (modified) # on 2001/12/19 18:55:42, toby did: reformat to match NCNR style Fri, 04 Dec 2009 23:07:09 GMT toby [497] * trunk/doc/expgui.html (modified) # on 2001/12/16 18:17:32, toby did: change GSAS version reference ... Fri, 04 Dec 2009 23:06:28 GMT toby [456] * trunk/doc/expgui.html (modified) # on 2001/10/14 05:33:15, toby did: plug mailing list Fri, 04 Dec 2009 23:06:17 GMT toby [445] * trunk/doc/expgui.html (modified) # on 2001/09/25 23:21:52, toby did: more links Fri, 04 Dec 2009 23:06:08 GMT toby [436] * trunk/doc/expgui.html (modified) # on 2001/09/04 23:07:02, toby did: links to EXCLEDT & BKGEDIT spelling Fri, 04 Dec 2009 23:05:40 GMT toby [408] * trunk/doc/expgui.html (modified) # on 2001/08/24 18:56:53, toby did: updates Fri, 04 Dec 2009 23:04:56 GMT toby [364] * trunk/doc/expgui.html (modified) # on 2000/12/22 21:14:32, toby did: document error highlighting new ... Fri, 04 Dec 2009 23:04:14 GMT toby [329] * trunk/doc/expgui.html (modified) # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup ... Fri, 04 Dec 2009 23:03:36 GMT toby [291] * trunk/doc/expgui.html (modified) # on 2000/10/03 23:27:17, toby did: Add the NIST required ALT= tags ... Fri, 04 Dec 2009 23:02:30 GMT toby [226] * trunk/doc/expgui.html (modified) # on 2000/07/03 21:44:27, toby did: make into multiple pages Fri, 04 Dec 2009 23:02:06 GMT toby [202] * trunk/doc/expgui.html (modified) # on 2000/06/09 03:53:28, toby did: Add Pref Orientation Section ... Fri, 04 Dec 2009 23:01:18 GMT toby [154] * trunk/doc/expgui.html (modified) # on 2000/05/26 14:12:58, toby did: document revised liveplot ... Fri, 04 Dec 2009 23:01:12 GMT toby [148] * trunk/doc/expgui.html (modified) # on 2000/05/18 15:37:38, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:00:39 GMT toby [115] * trunk/doc/expgui.html (modified) # on 1999/10/11 20:27:39, toby did: document "Group Phases Together" ... Fri, 04 Dec 2009 23:00:32 GMT toby [108] * trunk/doc/expgui.html (modified) # on 1999/09/16 15:43:44, toby did: update 2.gif and 3.gif and text ... Fri, 04 Dec 2009 23:00:27 GMT toby [103] * trunk/doc/expgui.html (modified) # on 1999/09/09 20:56:51, toby did: update for new WWW server Fri, 04 Dec 2009 23:00:20 GMT toby [96] * trunk/doc/expgui.html (modified) # on 1999/07/21 18:39:52, toby did: bring to current release make ... Fri, 04 Dec 2009 22:59:50 GMT toby [66] * trunk/doc/expgui.html (modified) # on 1999/03/19 16:58:39, toby did: shift to *.ncnr.nist.gov, new ... Fri, 04 Dec 2009 22:59:19 GMT toby [37] * trunk/doc/expgui.html (modified) # on 1999/01/20 21:34:11, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:17 GMT toby [35] * trunk/doc/expgui.html (modified) # on 1999/01/20 21:29:37, toby did: *** empty log message *** Fri, 04 Dec 2009 22:59:08 GMT toby [26] * trunk/doc/expgui.html (modified) # on 1999/01/13 04:36:53, toby did: move cd command later change ... Fri, 04 Dec 2009 22:59:05 GMT toby [24] * trunk/doc (added) * trunk/doc/expgui.html (added) # on 1999/01/11 04:58:27, toby did: Initial revision
