source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @884   11 years toby # on 2007/01/17 04:21:56, toby did: warn on windows comspec problem …
(edit) @883   11 years toby # on 2006/07/31 18:28:43, toby did: missing tickmarks (new BLT …
(edit) @882   11 years toby # on 2006/04/30 23:15:41, toby did: Indicate a new release
(edit) @881   11 years toby # on 2006/04/30 23:13:59, toby did: remove last of background function …
(edit) @880   11 years toby # on 2006/04/30 23:10:59, toby did: Add gsas2map into menus
(edit) @879   11 years toby # on 2006/03/29 04:07:45, toby did: Add mustrplot to 2nd menu
(edit) @878   11 years toby # on 2006/03/29 03:54:37, toby did: support profile editing (& grab …
(edit) @877   11 years toby # on 2006/03/29 03:53:16, toby did: remove now obsolete tofnorm; add …
(edit) @876   11 years toby # on 2006/03/29 03:52:11, toby did: Associate profile names with term …
(edit) @875   11 years toby # on 2006/03/29 03:50:00, toby did: return diffractometer constants …
(edit) @874   11 years toby # on 2006/03/29 03:47:44, toby did: Allow use of d-min or Q-max when …
(edit) @873   11 years toby # on 2006/03/29 03:45:35, toby did: Mark release
(edit) @872   11 years toby # on 2006/02/22 02:28:43, toby did: add seqgsas & seqplot to menus & …
(edit) @871   11 years toby # on 2006/02/22 01:47:15, toby did: update 1.78
(edit) @870   11 years toby # on 2006/02/22 01:45:29, toby did: Recompute Multiplicities prior to …
(edit) @869   11 years toby # on 2006/02/22 00:31:31, toby did: bkgfit: prevent use of more than …
(edit) @868   11 years toby # on 2006/02/22 00:29:58, toby did: no significant changes -- allow …
(edit) @867   11 years toby # on 2006/02/22 00:28:44, toby did: Allow composition to work on …
(edit) @866   11 years toby # on 2006/02/22 00:23:25, toby did: Plug GSAS on window head Make …
(edit) @865   11 years toby # on 2006/02/22 00:18:37, toby did: fix bug in 2theta max for multiple …
(edit) @864   11 years toby # on 2005/12/16 00:44:34, toby did: make compatible with new GSAS -- …
(edit) @863   11 years toby # on 2005/12/16 00:44:08, toby did: misc updates
(edit) @862   11 years toby # on 2005/12/16 00:42:42, toby did: pane --> panel
(edit) @861   11 years toby # on 2005/12/16 00:42:32, toby did: pane --> panel
(edit) @860   11 years toby # on 2005/12/16 00:42:19, toby did: pane --> panel
(edit) @859   11 years toby # on 2005/12/16 00:42:02, toby did: pane --> panel
(edit) @858   11 years toby # on 2005/12/16 00:41:46, toby did: pane --> panel
(edit) @857   11 years toby # on 2005/12/16 00:41:16, toby did: pane --> panel
(edit) @856   11 years toby # on 2005/12/16 00:40:23, toby did: pane --> panel document origin shift
(edit) @855   11 years toby # on 2005/12/16 00:39:30, toby did: pane --> panel
(edit) @854   11 years toby # on 2005/12/16 00:38:52, toby did: pane --> panel
(edit) @853   11 years toby # on 2005/12/16 00:36:40, toby did: make spacegroup search case …
(edit) @852   11 years toby # on 2005/09/13 17:44:33, toby did: fix buggy EXP create routine
(edit) @851   11 years toby # on 2005/09/12 23:35:50, toby did: add package require code & new …
(edit) @850   11 years toby # on 2005/09/12 23:34:24, toby did: change formatting of ODF records …
(edit) @849   11 years toby # on 2005/09/12 23:34:05, toby did: add missing proc
(edit) @848   11 years toby # on 2005/09/07 21:32:23, toby did: tag for new EXPGUI release
(edit) @847   11 years toby # on 2005/09/07 21:30:07, toby did: Add origin 1 --> origin 2 xform option
(edit) @846   11 years toby # on 2005/09/07 21:26:38, toby did: fix use of delete window …
(edit) @845   11 years toby # on 2005/09/07 21:16:07, toby did: minor updates
(edit) @844   11 years toby # on 2005/09/07 21:15:00, toby did: editorial comments
(edit) @843   11 years toby # on 2005/03/24 21:59:06, toby did: new validreal support LS Band …
(edit) @842   11 years toby # on 2005/03/24 21:57:52, toby did: profile type 5 (RBVD)
(edit) @841   11 years toby # on 2005/03/24 21:54:28, toby did: add defs for function #5 (thanks …
(edit) @840   11 years toby # on 2005/03/24 21:53:50, toby did: change designation of preferred …
(edit) @839   11 years toby # on 2005/03/24 21:52:39, toby did: support function #5 (thanks RBVD)
(edit) @838   11 years toby # on 2005/03/24 21:45:48, toby did: fix up resize for OS X add LS band …
(edit) @837   11 years toby # on 2005/03/24 21:43:24, toby did: fix bug in save options Add unix …
(edit) @836   11 years toby # on 2005/03/24 21:40:23, toby did: major revision Allow arrow colors, …
(edit) @835   11 years toby # on 2005/02/09 21:48:52, toby did: cleanup
(edit) @834   11 years toby # on 2005/02/09 21:48:18, toby did: download link
(edit) @833   11 years toby # on 2005/02/09 21:47:28, toby did: new feature: blank out shft & …
(edit) @832   11 years toby # on 2005/02/09 21:47:06, toby did: updates
(edit) @831   11 years toby # on 2005/02/09 21:46:35, toby did: download links
(edit) @830   11 years toby # on 2004/11/17 14:20:26, toby did: fix unformatted date -- belt & …
(edit) @829   11 years toby # on 2004/10/05 22:58:19, toby did: size change
(edit) @828   11 years toby # on 2004/10/05 22:57:30, toby did: missing zoom stack add BWidget …
(edit) @827   11 years toby # on 2004/10/04 20:29:52, toby did: remove diffvec (not used)
(edit) @826   11 years toby # on 2004/10/04 20:29:36, toby did: redo vector access
(edit) @825   11 years toby # on 2004/10/04 20:28:29, toby did: remove unused diffvec redo vector …
(edit) @824   11 years toby # on 2004/10/04 16:21:09, toby did: remove non-BWidget code
(edit) @823   11 years toby # on 2004/10/04 16:20:26, toby did: Require BWidget (remove …
(edit) @822   11 years toby # on 2004/10/04 16:11:47, toby did: BWidget is now required
(edit) @821   11 years toby # on 2004/09/30 15:24:29, toby did: fix file name
(edit) @820   11 years toby # on 2004/09/30 15:23:52, toby did: extensive revision for new packages
(edit) @819   11 years toby # on 2004/09/30 15:23:05, toby did: note new packaging & installation notes
(edit) @818   11 years toby # on 2004/09/29 20:52:57, toby did: grammar
(edit) @817   11 years toby # on 2004/09/28 23:47:35, toby did: up to 1.74
(edit) @816   11 years toby # on 2004/09/28 22:43:44, toby did: up to 1.72
(edit) @815   11 years toby # on 2004/09/28 22:42:54, toby did: ideas on debugging Tcl/Tk? problems …
(edit) @814   11 years toby # on 2004/09/28 22:41:37, toby did: word tweaking
(edit) @813   11 years toby # on 2004/09/28 22:41:00, toby did: major update; simply install
(edit) @812   11 years toby # on 2004/09/28 22:40:05, toby did: major revision -- explain updates
(edit) @811   11 years toby # on 2004/09/28 22:39:24, toby did: add anchor
(edit) @810   11 years toby # on 2004/09/28 22:34:07, toby did: use WINUTILS if present in place …
(edit) @809   11 years toby # on 2004/09/28 22:31:01, toby did: use winutils or winexec catch …
(edit) @808   11 years toby # on 2004/09/24 18:15:52, toby did: how to install without the installer
(edit) @807   11 years toby # on 2004/09/21 23:14:14, toby did: Export coordinates directly to …
(edit) @806   11 years toby # on 2004/09/20 15:33:00, toby did: force all output to instfile to be …
(edit) @805   11 years toby # on 2004/09/20 15:32:20, toby did: force all output to instfile to be …
(edit) @804   11 years toby # on 2004/09/20 15:31:47, toby did: add "package require Tk" for …
(edit) @803   11 years toby # on 2004/09/20 15:29:14, toby did: force all output to instfile to be …
(edit) @802   11 years toby # on 2004/09/20 15:28:45, toby did: add "package require Tk" for …
(edit) @801   11 years toby # on 2004/09/20 15:28:29, toby did: add "package require Tk" for …
(edit) @800   11 years toby # on 2004/09/20 15:27:45, toby did: >> add "package require Tk" for …
(edit) @799   11 years toby # on 2004/09/20 15:26:54, toby did: add "package require Tk" for …
(edit) @798   11 years toby # on 2004/09/08 14:08:22, toby did: quicky CIF export routine
(edit) @797   11 years toby # on 2004/05/13 23:48:46, toby did: add open console deal with starkit …
(edit) @796   11 years toby # on 2004/05/13 23:48:09, toby did: add open console
(edit) @795   11 years toby # on 2004/05/13 23:44:04, toby did: add open console deal with starkit …
(edit) @794   11 years toby # on 2004/05/13 23:42:30, toby did: open console
(edit) @793   11 years toby # on 2004/05/13 23:38:46, toby did: add new zoom binding
(edit) @792   11 years toby # on 2004/05/04 17:36:44, toby did: fix diffrence from EXPEDT; change …
(edit) @791   11 years toby # on 2004/05/04 17:20:35, toby did: save .EXP before call to bkgedit …
(edit) @790   11 years toby # on 2004/05/04 17:18:41, toby did: fix ipola buttons ("None" was …
(edit) @789   11 years toby # on 2004/04/27 15:52:46, toby did: more new stuff
(edit) @788   11 years toby # on 2004/04/27 15:46:48, toby did: new number only to track other changes
(edit) @787   11 years toby # on 2004/04/27 15:43:17, toby did: new features: obs-calc/sig, plot …
(edit) @786   11 years toby # on 2004/04/27 14:50:34, toby did: updates & OSX
(edit) @785   11 years toby # on 2004/04/27 14:49:32, toby did: document ability to scan zoom …
Note: See TracRevisionLog for help on using the revision log.
