source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @679   12 years toby # on 2003/04/10 22:25:03, toby did: autostart GRWND
(edit) @678   12 years toby # on 2003/04/10 22:22:49, toby did: add edit cell doc better formatting
(edit) @677   12 years toby # on 2003/04/10 22:22:32, toby did: more requests
(edit) @676   12 years toby # on 2003/04/10 22:20:43, toby did: new error msg for edit cell
(edit) @675   12 years toby # on 2003/04/10 22:19:24, toby did: use filename rather than arg (why?)
(edit) @674   12 years toby # on 2003/04/10 22:14:21, toby did: more sig figs on small numbers …
(edit) @673   12 years toby # on 2003/04/10 22:13:02, toby did: implement GRWND startup (Win-9x) …
(edit) @672   12 years toby # on 2003/04/10 22:12:41, toby did: fix missing tag
(edit) @671   12 years toby # on 2003/04/10 22:12:18, toby did: change header
(edit) @670   12 years toby # on 2003/04/10 22:03:45, toby did: change header autostart GRWND …
(edit) @669   12 years toby # on 2003/04/10 22:01:33, toby did: change header keep weights (for …
(edit) @668   12 years toby # on 2003/04/10 21:59:03, toby did: leave filenames up for rawplot set …
(edit) @667   12 years toby # on 2003/04/10 21:58:31, toby did: change startup section
(edit) @666   12 years toby # on 2003/04/10 21:55:15, toby did: Major revisions to fix TOF bugs …
(edit) @665   12 years toby # on 2002/12/30 17:14:03, toby did: update pleasewait to include …
(edit) @664   12 years toby # on 2002/12/30 17:00:34, toby did: updated pleasewait implement …
(edit) @663   12 years toby # on 2002/12/30 16:58:18, toby did: new comment; change name of …
(edit) @662   12 years toby # on 2002/12/27 18:25:35, toby did: fix MM read bug
(edit) @661   12 years toby # on 2002/10/31 17:32:06, toby did: trap gsas_config errors & write to …
(edit) @660   12 years toby # on 2002/10/31 17:29:18, toby did: do better job reporting …
(edit) @659   12 years toby # on 2002/10/31 17:28:17, toby did: trap gsas_config errors & write to …
(edit) @658   12 years toby # on 2002/10/31 17:26:56, toby did: trap gsas_config errors prevent …
(edit) @657   12 years toby # on 2002/10/24 19:26:49, toby did: fix broken help link
(edit) @656   12 years toby # on 2002/10/24 19:26:20, toby did: .csv plotting
(edit) @655   12 years toby # on 2002/10/24 19:24:01, toby did: Add export capability to comma …
(edit) @654   12 years toby # on 2002/09/24 20:49:58, toby did: quote reserved "words" (DATA_ …
(edit) @653   12 years toby # on 2002/09/06 19:42:17, toby did: update with recent request & …
(edit) @652   12 years toby # on 2002/09/05 21:18:57, toby did: more updates
(edit) @651   12 years toby # on 2002/09/05 21:18:37, toby did: new msg
(edit) @650   12 years toby # on 2002/09/05 21:03:37, toby did: Major revision. Implement undo …
(edit) @649   12 years toby # on 2002/09/05 20:59:20, toby did: Revise to use updated browsecif: …
(edit) @648   12 years toby # on 2002/09/05 18:29:19, toby did: make sure a phase & histogram is …
(edit) @647   12 years toby # on 2002/09/05 18:28:06, toby did: comments
(edit) @646   12 years toby # on 2002/09/05 18:24:04, toby did: add categories to loops improve …
(edit) @645   12 years toby # on 2002/09/05 18:22:20, toby did: trap error in localconfig and …
(edit) @644   12 years toby # on 2002/09/05 18:21:33, toby did: minor update: eliminate reference …
(edit) @643   12 years toby # on 2002/09/05 18:17:58, toby did: Major rework to use text-based …
(edit) @642   12 years toby # on 2002/09/05 18:16:49, toby did: remove octave stuff
(edit) @641   12 years toby # on 2002/09/05 18:16:00, toby did: why did I do this? Deal with …
(edit) @640   12 years toby # on 2002/08/09 16:44:11, toby did: Used to select distances & angles …
(edit) @639   12 years toby # on 2002/08/09 16:43:35, toby did: Routine to fill ? fields in CIF …
(edit) @638   12 years toby # on 2002/08/09 16:43:07, toby did: CIF support library
(edit) @637   12 years toby # on 2002/08/09 16:40:59, toby did: fix table size sync. add …
(edit) @636   12 years toby # on 2002/08/09 16:39:59, toby did: correct labels on pref. orient. …
(edit) @635   12 years toby # on 2002/07/31 00:33:41, toby did: document CIFselect
(edit) @634   12 years toby # on 2002/07/18 20:52:41, toby did: fix excluded region read error (in …
(edit) @633   12 years toby # on 2002/07/18 20:51:26, toby did: remove iconify from excledt -- …
(edit) @632   12 years toby # on 2002/07/18 20:51:04, toby did: GSAS2CIF & FillCIF changes
(edit) @631   12 years toby # on 2002/07/18 20:50:45, toby did: GSAS2CIF & fillCIF changes
(edit) @630   12 years toby # on 2002/07/18 20:50:04, toby did: fix binding with yet newer …
(edit) @629   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @628   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @627   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @626   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @625   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @624   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @623   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @622   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @621   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @620   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @619   12 years toby # on 2002/07/18 20:45:10, toby did: NIST alumina tutorial
(edit) @618   12 years toby # on 2002/07/18 20:44:05, toby did: NIST alumina tutorial
(edit) @617   12 years toby # on 2002/07/18 20:44:05, toby did: NIST alumina tutorial
(edit) @616   12 years toby # on 2002/07/18 20:39:14, toby did: Export routine for FOX
(edit) @615   12 years toby # on 2002/07/18 20:27:39, toby did: new tutorial
(edit) @614   12 years toby # on 2002/07/18 20:21:51, toby did: spell out more
(edit) @613   12 years toby # on 2002/07/18 20:21:34, toby did: GSAS2CIF stuff
(edit) @612   12 years toby # on 2002/07/18 20:02:14, toby did: make gsas+expgui.exe more obvious
(edit) @611   12 years toby # on 2002/07/18 20:01:41, toby did: add gsas2cif reference
(edit) @610   12 years toby # on 2002/07/18 19:59:42, toby did: clean spelling change DISAGL flag …
(edit) @609   12 years toby # on 2002/07/18 19:59:03, toby did: Add gsas2cif into chain
(edit) @608   12 years toby # on 2002/07/15 17:38:48, toby did: guide to the GSAS2CIF process
(edit) @607   12 years toby # on 2002/07/03 21:06:49, toby did: Bug fix: cancel button was broken …
(edit) @606   12 years toby # on 2002/07/03 21:04:31, toby did: catch invalid .EXP file names
(edit) @605   12 years toby # on 2002/07/03 21:02:35, toby did: minor stuff: 1) networked path …
(edit) @604   12 years toby # on 2002/07/03 21:01:45, toby did: minor bug fix
(edit) @603   12 years toby # on 2002/07/03 21:00:19, toby did: place only 1 TITL line in file (as …
(edit) @602   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @601   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @600   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @599   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @598   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @597   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @596   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @595   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @594   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @593   12 years toby # on 2002/04/12 21:34:08, toby did: remove id info; update format
(edit) @592   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @591   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @590   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @589   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @588   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @587   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @586   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @585   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @584   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @583   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @582   12 years toby # on 2002/04/12 21:21:18, toby did: remove id info; update format
(edit) @581   12 years toby # on 2002/04/12 19:51:40, toby did: remove identification stuff
(edit) @580   12 years toby # on 2002/04/12 19:49:04, toby did: remove identification stuff
Note: See TracRevisionLog for help on using the revision log.
