source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @473   12 years toby # on 2001/10/31 19:24:11, toby did: unsuccessful Win95 fixes
(edit) @472   12 years toby # on 2001/10/19 19:27:58, toby did: Change use of $newhist(setnum) for …
(edit) @471   12 years toby # on 2001/10/19 19:27:09, toby did: remove string replace for 8.0 …
(edit) @470   12 years toby # on 2001/10/18 23:30:15, toby did: fix web page display problem in …
(edit) @469   12 years toby # on 2001/10/18 23:27:59, toby did: describe new archiving
(edit) @468   12 years toby # on 2001/10/18 23:27:12, toby did: remove unix support for compressed …
(edit) @467   12 years toby # on 2001/10/18 23:23:58, toby did: add new peak labeling options
(edit) @466   12 years toby # on 2001/10/18 23:22:57, toby did: update archiving
(edit) @465   12 years toby # on 2001/10/18 23:17:12, toby did: updates
(edit) @464   12 years toby # on 2001/10/18 23:17:12, toby did: new key bindings for reflection labels
(edit) @463   12 years toby # on 2001/10/18 23:17:12, toby did: update archiving
(edit) @462   12 years toby # on 2001/10/18 23:17:12, toby did: update archiving
(edit) @461   12 years toby # on 2001/10/18 23:17:12, toby did: update archiving
(edit) @460   12 years toby # on 2001/10/14 05:37:32, toby did: use dumpexp.tcl to import …
(edit) @459   12 years toby # on 2001/10/14 05:37:32, toby did: dump coordinates from a .EXP file
(edit) @458   12 years toby # on 2001/10/14 05:36:29, toby did: blank out dummy histogram ranges …
(edit) @457   12 years toby # on 2001/10/14 05:34:23, toby did: bug fix: fix so that new histogram …
(edit) @456   12 years toby # on 2001/10/14 05:33:15, toby did: plug mailing list
(edit) @455   12 years toby # on 2001/10/14 05:32:26, toby did: .EXP coord import
(edit) @454   12 years toby # on 2001/10/14 05:32:26, toby did: .EXP coord import
(edit) @453   12 years toby # on 2001/09/25 23:35:54, toby did: Add "D" to all dummy histogram …
(edit) @452   12 years toby # on 2001/09/25 23:35:04, toby did: resize all plot axes
(edit) @451   12 years toby # on 2001/09/25 23:34:32, toby did: list only allowed histograms on submenu
(edit) @450   12 years toby # on 2001/09/25 23:31:59, toby did: Add error highlight into …
(edit) @449   12 years toby # on 2001/09/25 23:30:11, toby did: Add citations, as suggested by …
(edit) @448   12 years toby # on 2001/09/25 23:28:58, toby did: add web error links list only …
(edit) @447   12 years toby # on 2001/09/25 23:25:21, toby did: add comments improve error message …
(edit) @446   12 years toby # on 2001/09/25 23:22:48, toby did: better web sequencing
(edit) @445   12 years toby # on 2001/09/25 23:21:52, toby did: more links
(edit) @444   12 years toby # on 2001/09/25 23:21:11, toby did: dummy histogram support Setting …
(edit) @443   12 years toby # on 2001/09/25 23:20:06, toby did: old GSAS warning new EXPTOOL
(edit) @442   12 years toby # on 2001/09/25 23:18:12, toby did: new GSAS website new EXPTOOL …
(edit) @441   12 years toby # on 2001/09/25 23:17:30, toby did: updates
(edit) @440   12 years toby # on 2001/09/25 23:16:40, toby did: document EXCLEDT and Dummy …
(edit) @439   12 years toby # on 2001/09/25 23:16:11, toby did: better integrate into progression …
(edit) @438   12 years toby # on 2001/09/25 23:15:31, toby did: update and shorten
(edit) @437   12 years toby # on 2001/09/25 23:13:18, toby did: improved
(edit) @436   12 years toby # on 2001/09/04 23:07:02, toby did: links to EXCLEDT & BKGEDIT spelling
(edit) @435   12 years toby # on 2001/09/04 23:06:17, toby did: spelling Data Range & Excluded Regions
(edit) @434   12 years toby # on 2001/09/04 23:05:49, toby did: Describes EXCLEDT
(edit) @433   12 years toby # on 2001/09/04 23:04:23, toby did: cleanup html select symbol/color/font
(edit) @432   12 years toby # on 2001/09/04 23:03:56, toby did: updated
(edit) @431   12 years toby # on 2001/09/04 22:58:36, toby did: add excledt
(edit) @430   12 years toby # on 2001/09/04 22:58:01, toby did: add excledt
(edit) @429   12 years toby # on 2001/09/04 22:57:16, toby did: set dmin set histogram file name …
(edit) @428   12 years toby # on 2001/09/04 22:56:15, toby did: Add Data Limits/Exclude? button
(edit) @427   12 years toby # on 2001/09/04 22:55:55, toby did: larger optional font
(edit) @426   12 years toby # on 2001/09/04 22:53:53, toby did: set colors/symbols adjust fonts …
(edit) @425   12 years toby # on 2001/09/04 22:46:08, toby did: Do a better job with BLT graphs
(edit) @424   12 years toby # on 2001/09/04 22:37:09, toby did: Excluded Region and Data Limit Editor
(edit) @423   12 years toby # on 2001/09/04 22:13:06, toby did: describe how to override the …
(edit) @422   12 years toby # on 2001/09/04 22:11:44, toby did: adjustable fonts
(edit) @421   12 years toby # on 2001/09/04 22:11:06, toby did: adjustable fonts
(edit) @420   12 years toby # on 2001/09/04 22:09:40, toby did: reset bkgedit zoom
(edit) @419   12 years toby # on 2001/09/04 22:08:10, toby did: adjustable font support
(edit) @418   12 years toby # on 2001/09/04 22:07:47, toby did: adjustable fonts
(edit) @417   12 years toby # on 2001/09/04 22:06:41, toby did: adjustable fonts
(edit) @416   12 years toby # on 2001/09/04 22:06:05, toby did: adjustable fonts
(edit) @415   12 years toby # on 2001/09/04 22:04:24, toby did: excluded region support bank & …
(edit) @414   12 years toby # on 2001/09/04 22:03:57, toby did: adjustable fonts
(edit) @413   12 years toby # on 2001/09/04 22:01:55, toby did: adjust font
(edit) @412   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @411   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @410   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @409   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @408   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @407   12 years toby # on 2001/08/24 18:56:30, toby did: updated
(edit) @406   12 years toby # on 2001/06/29 18:34:32, toby did: document bkgedit add cumulative …
(edit) @405   12 years toby # on 2001/06/29 18:29:04, toby did: liveplot links
(edit) @404   12 years toby # on 2001/06/29 18:28:04, toby did: add archived files access
(edit) @403   12 years toby # on 2001/06/29 18:26:19, toby did: relabel "forward" button
(edit) @402   12 years toby # on 2001/06/29 18:23:57, toby did: Add bkgedit button description
(edit) @401   12 years toby # on 2001/06/29 18:20:12, toby did: major expansion -- explain page …
(edit) @400   12 years toby # on 2001/06/29 18:10:45, toby did: Major revision: add bkgedit …
(edit) @399   12 years toby # on 2001/06/29 18:06:31, toby did: Add Marquardt, convergence, LeBail?
(edit) @398   12 years toby # on 2001/06/29 18:03:32, toby did: Add bkgedit command
(edit) @397   12 years toby # on 2001/06/29 18:00:06, toby did: add bkgedit program
(edit) @396   12 years toby # on 2001/06/29 17:54:33, toby did: brace expr's for better speed …
(edit) @395   12 years toby # on 2001/05/23 20:11:12, toby did: use …
(edit) @394   12 years toby # on 2001/05/23 20:06:32, toby did: Use TOF-min for default when …
(edit) @393   12 years toby # on 2001/05/23 20:02:11, toby did: allow help pages to be found on …
(edit) @392   12 years toby # on 2001/05/11 18:35:14, toby did: test histograms before sending …
(edit) @391   12 years toby # on 2001/05/11 18:32:34, toby did: Add support for WIF David's …
(edit) @390   12 years toby # on 2001/05/11 16:18:58, toby did: change in location of PGPLOT font …
(edit) @389   12 years toby # on 2001/05/11 16:17:36, toby did: Change max constrained atoms to 500
(edit) @388   12 years toby # on 2001/05/11 16:10:22, toby did: button to display gzip'ed input …
(edit) @387   12 years toby # on 2001/05/11 16:09:08, toby did: accomodate gzip'ed input files on Unix
(edit) @386   12 years toby # on 2001/05/11 04:15:34, toby did: LIVEPLOT documentation
(edit) @385   12 years toby # on 2001/04/17 22:51:20, toby did: Use CR/LF format files on all platforms
(edit) @384   12 years toby # on 2001/04/17 22:49:47, toby did: revise tk_dialog to MyMessage? box …
(edit) @383   12 years toby # on 2001/04/17 22:46:55, toby did: revise tk_dialog to MyMessage? box …
(edit) @382   12 years toby # on 2001/04/17 22:45:54, toby did: use same spelling for geometry …
(edit) @381   12 years toby # on 2001/04/17 22:44:59, toby did: revise to use CR/LF for all platforms
(edit) @380   12 years toby # on 2001/04/16 21:27:22, toby did: fix overwrite problem widen message box
(edit) @379   12 years toby # on 2001/04/16 21:25:33, toby did: Add atom sort feature
(edit) @378   12 years toby # on 2001/04/03 19:16:41, toby did: fix bug: if error occurs in adding …
(edit) @377   12 years toby # on 2001/04/03 19:13:29, toby did: support cifs w/o …
(edit) @376   12 years toby # on 2001/04/03 19:10:54, toby did: TEMPORARY FIX: for SGI use old T/F …
(edit) @375   12 years toby # on 2001/02/26 19:52:54, toby did: more stuff to do
(edit) @374   12 years toby # on 2001/02/26 19:52:54, toby did: long name warning
Note: See TracRevisionLog for help on using the revision log.
