source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @425   12 years toby # on 2001/09/04 22:46:08, toby did: Do a better job with BLT graphs
(edit) @424   12 years toby # on 2001/09/04 22:37:09, toby did: Excluded Region and Data Limit Editor
(edit) @423   12 years toby # on 2001/09/04 22:13:06, toby did: describe how to override the …
(edit) @422   12 years toby # on 2001/09/04 22:11:44, toby did: adjustable fonts
(edit) @421   12 years toby # on 2001/09/04 22:11:06, toby did: adjustable fonts
(edit) @420   12 years toby # on 2001/09/04 22:09:40, toby did: reset bkgedit zoom
(edit) @419   12 years toby # on 2001/09/04 22:08:10, toby did: adjustable font support
(edit) @418   12 years toby # on 2001/09/04 22:07:47, toby did: adjustable fonts
(edit) @417   12 years toby # on 2001/09/04 22:06:41, toby did: adjustable fonts
(edit) @416   12 years toby # on 2001/09/04 22:06:05, toby did: adjustable fonts
(edit) @415   12 years toby # on 2001/09/04 22:04:24, toby did: excluded region support bank & …
(edit) @414   12 years toby # on 2001/09/04 22:03:57, toby did: adjustable fonts
(edit) @413   12 years toby # on 2001/09/04 22:01:55, toby did: adjust font
(edit) @412   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @411   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @410   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @409   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @408   12 years toby # on 2001/08/24 18:56:53, toby did: updates
(edit) @407   12 years toby # on 2001/08/24 18:56:30, toby did: updated
(edit) @406   12 years toby # on 2001/06/29 18:34:32, toby did: document bkgedit add cumulative …
(edit) @405   12 years toby # on 2001/06/29 18:29:04, toby did: liveplot links
(edit) @404   12 years toby # on 2001/06/29 18:28:04, toby did: add archived files access
(edit) @403   12 years toby # on 2001/06/29 18:26:19, toby did: relabel "forward" button
(edit) @402   12 years toby # on 2001/06/29 18:23:57, toby did: Add bkgedit button description
(edit) @401   12 years toby # on 2001/06/29 18:20:12, toby did: major expansion -- explain page …
(edit) @400   12 years toby # on 2001/06/29 18:10:45, toby did: Major revision: add bkgedit …
(edit) @399   12 years toby # on 2001/06/29 18:06:31, toby did: Add Marquardt, convergence, LeBail?
(edit) @398   12 years toby # on 2001/06/29 18:03:32, toby did: Add bkgedit command
(edit) @397   12 years toby # on 2001/06/29 18:00:06, toby did: add bkgedit program
(edit) @396   12 years toby # on 2001/06/29 17:54:33, toby did: brace expr's for better speed …
(edit) @395   12 years toby # on 2001/05/23 20:11:12, toby did: use …
(edit) @394   12 years toby # on 2001/05/23 20:06:32, toby did: Use TOF-min for default when …
(edit) @393   12 years toby # on 2001/05/23 20:02:11, toby did: allow help pages to be found on …
(edit) @392   12 years toby # on 2001/05/11 18:35:14, toby did: test histograms before sending …
(edit) @391   12 years toby # on 2001/05/11 18:32:34, toby did: Add support for WIF David's …
(edit) @390   12 years toby # on 2001/05/11 16:18:58, toby did: change in location of PGPLOT font …
(edit) @389   12 years toby # on 2001/05/11 16:17:36, toby did: Change max constrained atoms to 500
(edit) @388   12 years toby # on 2001/05/11 16:10:22, toby did: button to display gzip'ed input …
(edit) @387   12 years toby # on 2001/05/11 16:09:08, toby did: accomodate gzip'ed input files on Unix
(edit) @386   12 years toby # on 2001/05/11 04:15:34, toby did: LIVEPLOT documentation
(edit) @385   12 years toby # on 2001/04/17 22:51:20, toby did: Use CR/LF format files on all platforms
(edit) @384   12 years toby # on 2001/04/17 22:49:47, toby did: revise tk_dialog to MyMessage? box …
(edit) @383   12 years toby # on 2001/04/17 22:46:55, toby did: revise tk_dialog to MyMessage? box …
(edit) @382   12 years toby # on 2001/04/17 22:45:54, toby did: use same spelling for geometry …
(edit) @381   12 years toby # on 2001/04/17 22:44:59, toby did: revise to use CR/LF for all platforms
(edit) @380   12 years toby # on 2001/04/16 21:27:22, toby did: fix overwrite problem widen message box
(edit) @379   12 years toby # on 2001/04/16 21:25:33, toby did: Add atom sort feature
(edit) @378   12 years toby # on 2001/04/03 19:16:41, toby did: fix bug: if error occurs in adding …
(edit) @377   12 years toby # on 2001/04/03 19:13:29, toby did: support cifs w/o …
(edit) @376   12 years toby # on 2001/04/03 19:10:54, toby did: TEMPORARY FIX: for SGI use old T/F …
(edit) @375   12 years toby # on 2001/02/26 19:52:54, toby did: more stuff to do
(edit) @374   12 years toby # on 2001/02/26 19:52:54, toby did: long name warning
(edit) @373   12 years toby # on 2001/02/26 19:37:17, toby did: Change EPHAS (Fobs extraction) to …
(edit) @372   12 years toby # on 2001/02/22 18:28:06, toby did: fix weird bug?
(edit) @371   12 years toby # on 2000/12/22 21:31:48, toby did: show sample font sizes
(edit) @370   12 years toby # on 2000/12/22 21:31:48, toby did: produce error message in DISAGL if …
(edit) @369   12 years toby # on 2000/12/22 21:14:32, toby did: expand descriptions new sections …
(edit) @368   12 years toby # on 2000/12/22 21:14:32, toby did: expand archive documentation to …
(edit) @367   12 years toby # on 2000/12/22 21:14:32, toby did: minor edits, recommend tcl 8.2 now
(edit) @366   12 years toby # on 2000/12/22 21:14:32, toby did: Tcl/Tk? test section revised
(edit) @365   12 years toby # on 2000/12/22 21:14:32, toby did: document new option: autoraise in …
(edit) @364   12 years toby # on 2000/12/22 21:14:32, toby did: document error highlighting new …
(edit) @363   12 years toby # on 2000/12/22 19:44:07, toby did: fix expload error for DOS format …
(edit) @362   12 years toby # on 2000/12/22 19:44:07, toby did: Implement autoraise detect …
(edit) @361   12 years toby # on 2000/12/22 19:44:07, toby did: make POWPLOT a background program
(edit) @360   12 years toby # on 2000/12/22 19:44:07, toby did: Major reworking of routines to run …
(edit) @359   12 years toby # on 2000/12/22 19:44:07, toby did: add autoiconify option require …
(edit) @358   12 years toby # on 2000/12/22 19:37:02, toby did: fix call to RAWPLOT in data load. …
(edit) @357   12 years toby # on 2000/12/22 19:17:42, toby did: testing Tcl/Tk? FAQ added
(edit) @356   12 years toby # on 2000/11/27 21:10:45, toby did: define XYZU+-F
(edit) @355   12 years toby # on 2000/11/27 21:05:56, toby did: define type of XYZU+-F set phase …
(edit) @354   12 years toby # on 2000/11/27 21:05:56, toby did: line up >10 banks in Hist add set …
(edit) @353   12 years toby # on 2000/11/26 17:53:28, toby did: fix grab for choose block window
(edit) @352   12 years toby # on 2000/11/21 21:26:37, toby did: add "open" (same as "expnam")
(edit) @351   12 years toby # on 2000/11/21 21:25:31, toby did: fix font use for customization
(edit) @350   12 years toby # on 2000/11/21 21:25:31, toby did: fix that geometry is spelled …
(edit) @349   12 years toby # on 2000/11/21 21:23:45, toby did: change appearance of negative …
(edit) @348   12 years toby # on 2000/11/21 21:21:57, toby did: more ideas
(edit) @347   12 years toby # on 2000/11/21 21:21:57, toby did: doc how to change fonts
(edit) @346   12 years toby # on 2000/11/21 21:21:57, toby did: use beige for neg contraints
(edit) @345   12 years toby # on 2000/10/23 14:41:11, toby did: more ideas from Lachlan
(edit) @344   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @343   12 years toby # on 2000/10/18 00:11:17, toby did: move utilites organize
(edit) @342   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @341   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @340   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @339   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @338   12 years toby # on 2000/10/18 00:11:17, toby did: new error msg fixup formatting
(edit) @337   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @336   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @335   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @334   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @333   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @332   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @331   12 years toby # on 2000/10/18 00:11:17, toby did: fixup formatting
(edit) @330   12 years toby # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup …
(edit) @329   12 years toby # on 2000/10/18 00:11:17, toby did: add more utilities docs fixup …
(edit) @328   12 years toby # on 2000/10/18 00:03:58, toby did: Major change in order of routines! …
(edit) @327   12 years toby # on 2000/10/18 00:00:05, toby did: move platform-specific runtime …
(edit) @326   12 years toby # on 2000/10/17 23:59:32, toby did: correct comments w/r focus
Note: See TracRevisionLog for help on using the revision log.
