source:
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Diff Rev Age Author Log Message
(edit) @188   12 years toby # on 2000/06/01 16:07:21, toby did: correct typos
(edit) @187   12 years toby # on 2000/06/01 16:07:21, toby did: correct typos
(edit) @186   12 years toby # on 2000/06/01 16:07:21, toby did: correct typos
(edit) @185   12 years toby # on 2000/06/01 16:07:21, toby did: correct typos
(edit) @184   12 years toby # on 2000/06/01 16:07:21, toby did: correct typos
(edit) @183   12 years toby # on 2000/06/01 16:07:21, toby did: correct typos
(edit) @182   12 years toby # on 2000/06/01 02:55:03, toby did: add concurrent arg to runGSASwEXP …
(edit) @181   12 years toby # on 2000/06/01 02:48:14, toby did: define default txtview(font)
(edit) @180   12 years toby # on 2000/06/01 02:47:26, toby did: fix XYZU bug
(edit) @179   12 years toby # on 2000/06/01 02:46:47, toby did: add more than one atom at a time
(edit) @178   12 years toby # on 2000/06/01 02:42:49, toby did: add tutorial reference
(edit) @177   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @176   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @175   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @174   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @173   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @172   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @171   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @170   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @169   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @168   12 years toby # on 2000/05/30 22:22:38, toby did: Garnet tutorial
(edit) @167   12 years toby # on 2000/05/26 22:55:32, toby did: RUNPLOT & TOF on Add Histogram dialog
(edit) @166   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @165   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @164   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @163   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @162   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @161   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @160   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @159   12 years toby # on 2000/05/26 16:08:48, toby did: Initial revision
(edit) @158   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @157   12 years toby # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @156   12 years toby # on 2000/05/26 16:08:16, toby did: GSAS Nickel tutorial in EXPGUI
(edit) @155   12 years toby # on 2000/05/26 14:12:58, toby did: complete gsaskit.exe repoint
(edit) @154   12 years toby # on 2000/05/26 14:12:58, toby did: document revised liveplot bindings …
(edit) @153   12 years toby # on 2000/05/26 14:06:54, toby did: revise liveplot bindings so that …
(edit) @152   12 years toby # on 2000/05/18 15:58:18, toby did: Add constraints support move to …
(edit) @151   12 years toby # on 2000/05/18 15:55:37, toby did: add revision string
(edit) @150   12 years toby # on 2000/05/18 15:54:08, toby did: fix bugs (already!) test for more …
(edit) @149   12 years toby # on 2000/05/18 15:43:24, toby did: shortcut for powpref
(edit) @148   12 years toby # on 2000/05/18 15:37:38, toby did: add Tcl/tk logo, general editing …
(edit) @147   12 years toby # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing
(edit) @146   12 years toby # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing
(edit) @145   12 years toby # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing
(edit) @144   12 years toby # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing …
(edit) @143   12 years toby # on 2000/05/17 20:27:05, toby did: major edit
(edit) @142   12 years toby # on 2000/05/17 20:23:13, toby did: cleanup
(edit) @141   12 years toby # on 2000/05/17 20:11:07, toby did: cleanup & update
(edit) @140   12 years toby # on 2000/05/17 20:09:20, toby did: cleanup & update
(edit) @139   12 years toby # on 2000/05/17 18:45:27, toby did: new option: allow a separate …
(edit) @138   12 years toby # on 2000/05/17 18:38:55, toby did: add force to rename add rundisagl …
(edit) @137   12 years toby # on 2000/05/17 18:37:18, toby did: add menubutton option line item to …
(edit) @136   12 years toby # on 2000/05/17 16:30:57, toby did: change donewait to donewaitmsg to …
(edit) @135   12 years toby # on 2000/05/17 16:30:57, toby did: change donewait to donewaitmsg to …
(edit) @134   12 years toby # on 2000/05/17 16:30:57, toby did: change donewait to donewaitmsg to …
(edit) @133   12 years toby # on 2000/05/17 16:17:21, toby did: cleanup reading lowercase .exp …
(edit) @132   12 years toby # on 2000/05/17 16:14:23, toby did: cleanup adding histograms to be …
(edit) @131   12 years toby # on 2000/05/17 00:22:54, toby did: routines for atom constraints
(edit) @130   12 years toby # on 2000/05/16 21:57:44, toby did: ignore macromolecular phases …
(edit) @129   12 years toby # on 2000/05/16 21:53:20, toby did: add constrinfo for atom constraint …
(edit) @128   12 years toby # on 2000/05/16 21:48:45, toby did: set expload return value to …
(edit) @127   12 years toby # on 2000/04/24 02:32:17, toby did: This sets the default fonts & …
(edit) @126   12 years toby # on 2000/04/10 20:07:43, toby did: revise BLT error for bad …
(edit) @125   12 years toby # on 2000/04/10 20:07:43, toby did: revise BLT error for bad …
(edit) @124   12 years toby # on 2000/02/02 17:42:20, toby did: create HST xx EPHAS records if missing
(edit) @123   12 years toby # on 1999/11/19 00:03:25, toby did: fixup Archive code for Windows (as …
(edit) @122   12 years toby # on 1999/11/17 22:07:24, toby did: Add EraseHistory? command
(edit) @121   12 years toby # on 1999/11/17 22:06:21, toby did: define a -title configuration option
(edit) @120   12 years toby # on 1999/11/17 22:05:04, toby did: Add routines to delete history records
(edit) @119   12 years toby # on 1999/11/17 22:02:36, toby did: Add routine to delete history …
(edit) @118   12 years toby # on 1999/11/16 15:59:22, toby did: Switch over to use of pure Tk …
(edit) @117   12 years toby # on 1999/11/16 15:45:40, toby did: add timing option for debug try …
(edit) @116   12 years toby # on 1999/11/15 14:32:48, toby did: A standard Tcl/Tk? notebook widget
(edit) @115   12 years toby # on 1999/10/11 20:27:39, toby did: document "Group Phases Together" option
(edit) @114   12 years toby # on 1999/10/11 20:27:13, toby did: Customization examples
(edit) @113   12 years toby # on 1999/10/11 19:49:28, toby did: * empty log message *
(edit) @112   12 years toby # on 1999/10/11 19:48:35, toby did: cleanup multiple histogram …
(edit) @111   12 years toby # on 1999/10/11 19:46:43, toby did: Define expgui(debug)
(edit) @110   12 years toby # on 1999/10/11 19:46:16, toby did: document new global modes ("Group …
(edit) @109   12 years toby # on 1999/09/16 15:44:26, toby did: add version reference to EXPGUI …
(edit) @108   12 years toby # on 1999/09/16 15:43:44, toby did: update 2.gif and 3.gif and text …
(edit) @107   12 years toby # on 1999/09/09 21:00:32, toby did: update for new WWW server
(edit) @106   12 years toby # on 1999/09/09 21:00:32, toby did: update for new WWW server
(edit) @105   12 years toby # on 1999/09/09 21:00:32, toby did: update for new WWW server
(edit) @104   12 years toby # on 1999/09/09 20:56:51, toby did: update for new WWW server
(edit) @103   12 years toby # on 1999/09/09 20:56:51, toby did: update for new WWW server
(edit) @102   12 years toby # on 1999/09/09 19:08:11, toby did: hide grab fail error messages ,
(edit) @101   12 years toby # on 1999/09/09 19:06:45, toby did: fix vrstplot call so that EXP name …
(edit) @100   12 years toby # on 1999/09/09 19:05:54, toby did: correct background window bug …
(edit) @99   12 years toby # on 1999/07/22 20:08:20, toby did: revise for exptool that adds …
(edit) @98   12 years toby # on 1999/07/22 20:07:37, toby did: Fix resize of ShowBigMessage?
(edit) @97   12 years toby # on 1999/07/22 20:04:23, toby did: clear atom box etc when loading an …
(edit) @96   12 years toby # on 1999/07/21 18:39:52, toby did: bring to current release make …
(edit) @95   12 years toby # on 1999/07/21 18:39:20, toby did: exptool updates
(edit) @94   12 years toby # on 1999/07/21 16:51:57, toby did: add phase... update
(edit) @93   12 years toby # on 1999/07/21 16:32:11, toby did: add autoload mode add support for …
(edit) @92   12 years toby # on 1999/07/21 16:29:57, toby did: These routines are used for adding …
(edit) @91   12 years toby # on 1999/07/21 16:22:54, toby did: adopt putontop and afterputontop …
(edit) @90   12 years toby # on 1999/07/21 16:19:34, toby did: fix bug in create blank exp file …
(edit) @89   12 years toby # on 1999/07/21 15:12:53, toby did: fix windows archive error
Note: See TracRevisionLog for help on using the revision log.
