# ChangeLog for /
# Generated by Trac 1.0.13
# Jun 17, 2025 8:36:44 AM
Fri, 04 Dec 2009 23:08:14 GMT toby [561]
	* trunk/import_cif.tcl (modified)
	# on 2002/02/11 17:33:41, toby did:
	Change quote processing of CIF's ...
Fri, 04 Dec 2009 23:08:13 GMT toby [560]
	* trunk/lstview (modified)
	# on 2002/02/11 17:32:15, toby did:
	Bug fix -- repeat is was not set ...
Fri, 04 Dec 2009 23:08:12 GMT toby [559]
	* trunk/readexp.tcl (modified)
	# on 2002/01/25 21:30:39, toby did:
	more absorption correction terms
Fri, 04 Dec 2009 23:08:11 GMT toby [558]
	* trunk/widplt (modified)
	# on 2002/01/25 21:30:17, toby did:
	neaten
Fri, 04 Dec 2009 23:08:10 GMT toby [557]
	* trunk/expgui (modified)
	# on 2002/01/25 21:26:41, toby did:
	Add absorption correction to ...
Fri, 04 Dec 2009 23:08:09 GMT toby [556]
	* trunk/doc/expgui3.html (modified)
	# on 2002/01/25 21:17:48, toby did:
	add absorption & reorganize page
Fri, 04 Dec 2009 23:08:08 GMT toby [555]
	* trunk/doc/wishlist.html (modified)
	# on 2002/01/25 21:17:16, toby did:
	add absorption box
Fri, 04 Dec 2009 23:08:07 GMT toby [554]
	# on 2002/01/24 15:34:43, toby did:
	bug fix: update plot after ...
Fri, 04 Dec 2009 23:08:06 GMT toby [553]
	* trunk/addcmds.tcl (modified)
	# on 2002/01/23 20:53:36, toby did:
	fix bugs related to adding ...
Fri, 04 Dec 2009 23:08:05 GMT toby [552]
	* trunk/doc/liveplot.html (modified)
	# on 2002/01/23 20:00:50, toby did:
	clean up font references
Fri, 04 Dec 2009 23:08:04 GMT toby [551]
	* trunk/doc/expguierr.html (modified)
Fri, 04 Dec 2009 23:08:03 GMT toby [550]
	* trunk/doc/expgui_cfg.html (modified)
Fri, 04 Dec 2009 23:08:02 GMT toby [549]
	* trunk/doc/expgui_Win_readme.html (modified)
	# on 2002/01/23 19:59:56, toby did:
	reference the self-installer ...
Fri, 04 Dec 2009 23:08:01 GMT toby [548]
	* trunk/doc/expgui_Unix_readme.html (modified)
	# on 2002/01/23 19:59:22, toby did:
	reference the RPM file
	cleanup ...
Fri, 04 Dec 2009 23:08:00 GMT toby [547]
	* trunk/doc/expgui.html (modified)
	# on 2002/01/23 19:59:05, toby did:
	thanks John!
Fri, 04 Dec 2009 23:07:59 GMT toby [546]
	# on 2002/01/23 19:58:35, toby did:
	note reflection labeling request
Fri, 04 Dec 2009 23:07:58 GMT toby [545]
	* trunk/dumpexp.tcl (modified)
	# on 2002/01/22 23:12:36, toby did:
	don't dump mm phases
Fri, 04 Dec 2009 23:07:57 GMT toby [544]
	# on 2002/01/22 23:02:55, toby did:
	writing of real values: if a ...
Fri, 04 Dec 2009 23:07:56 GMT toby [543]
	* trunk/atomcons.tcl (modified)
	# on 2002/01/22 22:55:35, toby did:
	Major changes to add MM ...
Fri, 04 Dec 2009 23:07:55 GMT toby [542]
	* trunk/gsascmds.tcl (modified)
	# on 2002/01/22 22:53:34, toby did:
	support absplt in widplt routine ...
Fri, 04 Dec 2009 23:07:54 GMT toby [541]
	* trunk/gsasmenu.tcl (modified)
	# on 2002/01/22 22:50:33, toby did:
	add absplt, remove export ...
Fri, 04 Dec 2009 23:07:53 GMT toby [540]
	# on 2002/01/22 22:45:19, toby did:
	Major revision
	  Add ABSPLT ...
Fri, 04 Dec 2009 23:07:52 GMT toby [539]
	# on 2002/01/22 22:29:18, toby did:
	Significant change in display of ...
Fri, 04 Dec 2009 23:07:51 GMT toby [538]
	# on 2002/01/22 22:28:53, toby did:
	more complete space group checking
Fri, 04 Dec 2009 23:07:50 GMT toby [537]
	* trunk/liveplot (modified)
	# on 2002/01/22 22:16:51, toby did:
	Major revision:
	  export to ...
Fri, 04 Dec 2009 23:07:49 GMT toby [536]
	# on 2002/01/22 22:10:48, toby did:
	support changes MM phases (where ...
Fri, 04 Dec 2009 23:07:48 GMT toby [535]
	# on 2002/01/22 21:52:22, toby did:
	Major revisions
	add plot of R's ...
Fri, 04 Dec 2009 23:07:47 GMT toby [534]
	* trunk/opts.tcl (modified)
	# on 2002/01/22 21:51:33, toby did:
	Add small checkbutton font for ...
Fri, 04 Dec 2009 23:07:46 GMT toby [533]
	* trunk/import_xtl.tcl (added)
	# on 2002/01/22 21:45:59, toby did:
	import coordinates from MSI .xtl ...
Fri, 04 Dec 2009 23:07:45 GMT toby [532]
	* trunk/import_spf.tcl (added)
	import coordinates from PLATON ...
Fri, 04 Dec 2009 23:07:44 GMT toby [531]
	* trunk/graceexport.tcl (added)
	Export plots to GRACE (aka xmgr ...
Fri, 04 Dec 2009 23:07:43 GMT toby [530]
	* trunk/export_xtl.tcl (added)
	Export  coordinates in MSI .xtl ...
Fri, 04 Dec 2009 23:07:42 GMT toby [529]
	* trunk/export_spf.tcl (added)
	export coordinates in PLATON ...
Fri, 04 Dec 2009 23:07:41 GMT toby [528]
	* trunk/export_shelx.tcl (added)
	export coordinates in SHELX .INS ...
Fri, 04 Dec 2009 23:07:40 GMT toby [527]
	* trunk/export_example.example (added)
	example coordinate export routine
Fri, 04 Dec 2009 23:07:38 GMT toby [526]
	* trunk/doc/expgui2.html (modified)
	# on 2002/01/22 21:12:22, toby did:
	reference coordinate import ...
Fri, 04 Dec 2009 23:07:37 GMT toby [525]
	# on 2002/01/22 21:11:44, toby did:
	lots of additions
Fri, 04 Dec 2009 23:07:36 GMT toby [524]
	# on 2002/01/22 21:08:12, toby did:
	add coordinate export section ...
Fri, 04 Dec 2009 23:07:35 GMT toby [523]
	# on 2002/01/22 21:06:17, toby did:
	ABSPLT
	improve utility section ...
Fri, 04 Dec 2009 23:07:34 GMT toby [522]
	* trunk/doc/expguic.html (modified)
	# on 2002/01/22 21:05:34, toby did:
	add newer (mostly MM) programs
Fri, 04 Dec 2009 23:07:33 GMT toby [521]
	* trunk/doc/expgui6.html (modified)
	# on 2002/01/22 21:05:10, toby did:
	MM constraints
Fri, 04 Dec 2009 23:07:32 GMT toby [520]
	# on 2002/01/22 21:02:55, toby did:
	l-s in BKGEDT & support for ...
Fri, 04 Dec 2009 23:07:31 GMT toby [519]
	# on 2001/12/19 18:55:42, toby did:
	reformat to match NCNR style
Fri, 04 Dec 2009 23:07:30 GMT toby [518]
Fri, 04 Dec 2009 23:07:29 GMT toby [517]
Fri, 04 Dec 2009 23:07:28 GMT toby [516]
Fri, 04 Dec 2009 23:07:27 GMT toby [515]
Fri, 04 Dec 2009 23:07:26 GMT toby [514]
Fri, 04 Dec 2009 23:07:25 GMT toby [513]
	* trunk/doc/expgui_intro.html (modified)
Fri, 04 Dec 2009 23:07:24 GMT toby [512]
Fri, 04 Dec 2009 23:07:23 GMT toby [511]
	* trunk/doc/expgui7.html (modified)
Fri, 04 Dec 2009 23:07:22 GMT toby [510]
Fri, 04 Dec 2009 23:07:21 GMT toby [509]
	* trunk/doc/expgui5.html (modified)
Fri, 04 Dec 2009 23:07:20 GMT toby [508]
	* trunk/doc/expgui4.html (modified)
Fri, 04 Dec 2009 23:07:19 GMT toby [507]
Fri, 04 Dec 2009 23:07:18 GMT toby [506]
Fri, 04 Dec 2009 23:07:17 GMT toby [505]
	* trunk/doc/expgui1.html (modified)
Fri, 04 Dec 2009 23:07:16 GMT toby [504]
	* trunk/doc/expgui0.html (modified)
Fri, 04 Dec 2009 23:07:15 GMT toby [503]
Fri, 04 Dec 2009 23:07:14 GMT toby [502]
	* trunk/doc/excledt.html (modified)
Fri, 04 Dec 2009 23:07:13 GMT toby [501]
	# on 2001/12/16 20:13:10, toby did:
	make top of window a bit smaller
Fri, 04 Dec 2009 23:07:12 GMT toby [500]
Fri, 04 Dec 2009 23:07:11 GMT toby [499]
	# on 2001/12/16 19:40:06, toby did:
	don't check for excledt file -- ...
Fri, 04 Dec 2009 23:07:10 GMT toby [498]
	# on 2001/12/16 19:38:52, toby did:
	bug fix: ignore update if .EXP ...
Fri, 04 Dec 2009 23:07:09 GMT toby [497]
	# on 2001/12/16 18:17:32, toby did:
	change GSAS version reference ...
Fri, 04 Dec 2009 23:07:08 GMT toby [496]
	# on 2001/12/16 18:16:37, toby did:
	note showing .EXP status
Fri, 04 Dec 2009 23:07:07 GMT toby [495]
	# on 2001/12/16 18:15:31, toby did:
	liveplot: explain the "FORTRAN" error
Fri, 04 Dec 2009 23:07:06 GMT toby [494]
	# on 2001/12/16 18:09:18, toby did:
	Major revisions:
	        add ...
Fri, 04 Dec 2009 23:07:05 GMT toby [493]
	# on 2001/12/16 18:08:28, toby did:
	Add "D" as a valid element type
Fri, 04 Dec 2009 23:07:04 GMT toby [492]
	* trunk/excledt.tcl (modified)
	# on 2001/12/16 18:06:53, toby did:
	make -outline BLT version ...
Fri, 04 Dec 2009 23:07:03 GMT toby [491]
	# on 2001/12/16 17:31:47, toby did:
	fix fileinfobox error in open ...
Fri, 04 Dec 2009 23:07:02 GMT toby [490]
	# on 2001/11/19 19:50:58, toby did:
	include Rfactors on file lookup
Fri, 04 Dec 2009 23:07:01 GMT toby [489]
	# on 2001/11/19 19:50:05, toby did:
	improve error message
	deal with ...
Fri, 04 Dec 2009 23:07:00 GMT toby [488]
	# on 2001/11/19 19:49:33, toby did:
	new smallfont default
Fri, 04 Dec 2009 23:06:59 GMT toby [487]
	# on 2001/11/08 16:00:44, toby did:
	fix update flag after ...
Fri, 04 Dec 2009 23:06:58 GMT toby [486]
	# on 2001/11/07 19:02:53, toby did:
	new release (1.51)
Fri, 04 Dec 2009 23:06:57 GMT toby [485]
	# on 2001/11/07 18:22:57, toby did:
	remove echo in archive
	add get ...
Fri, 04 Dec 2009 23:06:56 GMT toby [484]
	# on 2001/11/07 18:17:37, toby did:
	get rid of echo command
Fri, 04 Dec 2009 23:06:55 GMT toby [483]
	# on 2001/11/07 18:12:46, toby did:
	change filename to avoid ...
Fri, 04 Dec 2009 23:06:54 GMT toby [482]
	# on 2001/10/31 20:13:17, toby did:
	new shortcuts: next histogram ...
Fri, 04 Dec 2009 23:06:53 GMT toby [481]
	# on 2001/10/31 20:12:15, toby did:
	major revision for in-line routine
Fri, 04 Dec 2009 23:06:52 GMT toby [480]
	# on 2001/10/31 20:08:54, toby did:
	support excledt
Fri, 04 Dec 2009 23:06:51 GMT toby [479]
	# on 2001/10/31 20:07:41, toby did:
	change excledt to run "in-line"
Fri, 04 Dec 2009 23:06:50 GMT toby [478]
	# on 2001/10/31 20:06:10, toby did:
	fix .Oxx bug when no files are ...
Fri, 04 Dec 2009 23:06:49 GMT toby [477]
	# on 2001/10/31 20:04:21, toby did:
	add next histogram feature
Fri, 04 Dec 2009 23:06:48 GMT toby [476]
	# on 2001/10/31 20:02:37, toby did:
	manual zoom option
Fri, 04 Dec 2009 23:06:47 GMT toby [475]
	# on 2001/10/31 19:28:03, toby did:
	Very major rewrite
	  make ...
Fri, 04 Dec 2009 23:06:46 GMT toby [474]
	* trunk/exclinit.tcl (added)
	# on 2001/10/31 19:25:44, toby did:
	initialization routine for EXCLEDT
Fri, 04 Dec 2009 23:06:45 GMT toby [473]
	# on 2001/10/31 19:24:11, toby did:
	unsuccessful Win95 fixes
Fri, 04 Dec 2009 23:06:44 GMT toby [472]
	# on 2001/10/19 19:27:58, toby did:
	Change use of $newhist(setnum) ...
Fri, 04 Dec 2009 23:06:43 GMT toby [471]
	# on 2001/10/19 19:27:09, toby did:
	remove string replace for 8.0 ...
Fri, 04 Dec 2009 23:06:42 GMT toby [470]
	# on 2001/10/18 23:30:15, toby did:
	fix web page display problem in ...
Fri, 04 Dec 2009 23:06:41 GMT toby [469]
	# on 2001/10/18 23:27:59, toby did:
	describe new archiving
Fri, 04 Dec 2009 23:06:40 GMT toby [468]
	# on 2001/10/18 23:27:12, toby did:
	remove unix support for ...
Fri, 04 Dec 2009 23:06:39 GMT toby [467]
	# on 2001/10/18 23:23:58, toby did:
	add new peak labeling options
Fri, 04 Dec 2009 23:06:38 GMT toby [466]
	# on 2001/10/18 23:22:57, toby did:
	update archiving
Fri, 04 Dec 2009 23:06:37 GMT toby [465]
	# on 2001/10/18 23:17:12, toby did:
	updates
Fri, 04 Dec 2009 23:06:36 GMT toby [464]
	new key bindings for reflection ...
Fri, 04 Dec 2009 23:06:35 GMT toby [463]
	update archiving
Fri, 04 Dec 2009 23:06:34 GMT toby [462]
	update archiving
