# ChangeLog for /
# Generated by Trac 1.0.13
# Jun 17, 2025 8:19:48 PM
Fri, 04 Dec 2009 23:03:36 GMT toby [291]
	* trunk/doc/expgui.html (modified)
	# on 2000/10/03 23:27:17, toby did:
	Add the NIST required ALT= tags ...
Fri, 04 Dec 2009 23:03:35 GMT toby [290]
	* trunk/expgui_zip.bat (added)
	# on 2000/10/03 23:18:57, toby did:
	A batch file used to create a ...
Fri, 04 Dec 2009 23:03:34 GMT toby [289]
	* trunk/expgui (modified)
	# on 2000/10/02 16:54:10, toby did:
	remove unneeded raise command in ...
Fri, 04 Dec 2009 23:03:33 GMT toby [288]
	* trunk/odf.tcl (modified)
	# on 2000/10/02 16:52:08, toby did:
	make phase buttons/title like on ...
Fri, 04 Dec 2009 23:03:32 GMT toby [287]
	* trunk/readexp.tcl (modified)
	# on 2000/10/02 16:50:47, toby did:
Fri, 04 Dec 2009 23:03:31 GMT toby [286]
	* trunk/import_cif.tcl (modified)
	# on 2000/09/26 17:57:10, toby did:
	change processing of ' & " for ...
Fri, 04 Dec 2009 23:03:30 GMT toby [285]
	# on 2000/09/26 14:51:04, toby did:
	Various fixes: change data names ...
Fri, 04 Dec 2009 23:03:29 GMT toby [284]
	* trunk/addcmds.tcl (modified)
	# on 2000/09/25 20:09:50, toby did:
	Display a message returned by ...
Fri, 04 Dec 2009 23:03:28 GMT toby [283]
	# on 2000/09/25 20:08:45, toby did:
	Add texture index
Fri, 04 Dec 2009 23:03:27 GMT toby [282]
	* trunk/doc/expgui_cfg.html (modified)
	# on 2000/09/25 20:07:22, toby did:
	Add CIF import documentation
Fri, 04 Dec 2009 23:03:26 GMT toby [281]
	* trunk/doc/expgui2.html (modified)
Fri, 04 Dec 2009 23:03:25 GMT toby [280]
	* trunk/import_cif.tcl (added)
	# on 2000/09/24 04:41:00, toby did:
	CIF coordinate import routine, ...
Fri, 04 Dec 2009 23:03:24 GMT toby [279]
	* trunk/doc/expgui0.html (modified)
	# on 2000/08/21 19:37:35, toby did:
	pretty up page with a table of links
Fri, 04 Dec 2009 23:03:23 GMT toby [278]
	* trunk/doc/expguic.html (modified)
	# on 2000/08/21 19:37:09, toby did:
	pretty up page with table of links
Fri, 04 Dec 2009 23:03:22 GMT toby [277]
	* trunk/doc/expgui7.html (modified)
	# on 2000/08/21 19:36:29, toby did:
Fri, 04 Dec 2009 23:03:21 GMT toby [276]
	* trunk/doc/expgui6.html (modified)
Fri, 04 Dec 2009 23:03:20 GMT toby [275]
	* trunk/doc/expgui5.html (modified)
Fri, 04 Dec 2009 23:03:19 GMT toby [274]
	* trunk/doc/expgui4.html (modified)
Fri, 04 Dec 2009 23:03:18 GMT toby [273]
	* trunk/doc/expgui3.html (modified)
Fri, 04 Dec 2009 23:03:17 GMT toby [272]
	* trunk/doc/expgui1.html (modified)
Fri, 04 Dec 2009 23:03:16 GMT toby [271]
	* trunk/doc/wishlist.html (modified)
	# on 2000/08/21 19:35:43, toby did:
	update to reflect current progress
Fri, 04 Dec 2009 23:03:15 GMT toby [270]
	# on 2000/08/21 19:33:31, toby did:
	describe coordinate import ...
Fri, 04 Dec 2009 23:03:14 GMT toby [269]
	# on 2000/08/21 19:27:43, toby did:
Fri, 04 Dec 2009 23:03:13 GMT toby [268]
	# on 2000/08/17 23:49:20, toby did:
	reformat dialogs for Import ...
Fri, 04 Dec 2009 23:03:12 GMT toby [267]
	# on 2000/08/17 23:48:03, toby did:
	implement Replace Phase
	error ...
Fri, 04 Dec 2009 23:03:11 GMT toby [266]
	* trunk/import_cell.tcl (modified)
	# on 2000/08/17 23:46:23, toby did:
	perform origin shifts for Origin ...
Fri, 04 Dec 2009 23:03:10 GMT toby [265]
	# on 2000/08/17 23:44:52, toby did:
	Fix bug setting gamma
Fri, 04 Dec 2009 23:03:09 GMT toby [264]
	* trunk/spacegrp.ref (added)
	# on 2000/08/17 23:40:38, toby did:
	space group table for .CEL ...
Fri, 04 Dec 2009 23:03:08 GMT toby [263]
	* trunk/import_cell.tcl (added)
	# on 2000/08/14 21:09:21, toby did:
	Routine to read PowderCell ...
Fri, 04 Dec 2009 23:03:07 GMT toby [262]
	# on 2000/08/14 16:28:34, toby did:
	eliminate phase flag box if only ...
Fri, 04 Dec 2009 23:03:06 GMT toby [261]
	# on 2000/08/08 23:21:55, toby did:
	Correct creation of off-diagonal ...
Fri, 04 Dec 2009 23:03:05 GMT toby [260]
	# on 2000/08/04 19:26:00, toby did:
	document phase flags
Fri, 04 Dec 2009 23:03:04 GMT toby [259]
	# on 2000/08/04 19:25:35, toby did:
	document atom xform/global set
Fri, 04 Dec 2009 23:03:03 GMT toby [258]
	* trunk/doc/expgui_Unix_readme.html (modified)
	# on 2000/08/04 19:24:50, toby did:
	expand "shortcut" discussion
Fri, 04 Dec 2009 23:03:02 GMT toby [257]
	# on 2000/08/04 19:24:21, toby did:
	sort by occ.
Fri, 04 Dec 2009 23:03:01 GMT toby [256]
	# on 2000/08/04 19:23:57, toby did:
	update with latest
Fri, 04 Dec 2009 23:03:00 GMT toby [255]
	# on 2000/08/04 18:29:16, toby did:
	Change phase buttons, add "Add ...
Fri, 04 Dec 2009 23:02:59 GMT toby [254]
	# on 2000/08/04 18:26:37, toby did:
	new procs: MakeXformAtomsBox, ...
Fri, 04 Dec 2009 23:02:57 GMT toby [253]
	# on 2000/08/04 18:25:05, toby did:
	document that  temptype can be ...
Fri, 04 Dec 2009 23:02:56 GMT toby [252]
	# on 2000/08/04 18:19:37, toby did:
	redo error msgs
	phaseinfo: ...
Fri, 04 Dec 2009 23:02:55 GMT toby [251]
	* trunk/gsasmenu.tcl (modified)
	# on 2000/08/04 18:18:18, toby did:
	add commands to single xtal ...
Fri, 04 Dec 2009 23:02:54 GMT toby [250]
	# on 2000/07/28 20:29:34, toby did:
	add phase flag box to histogram ...
Fri, 04 Dec 2009 23:02:53 GMT toby [249]
	* trunk/gsascmds.tcl (modified)
	# on 2000/07/28 20:28:25, toby did:
	remove unneeded ref to Win98 for ...
Fri, 04 Dec 2009 23:02:52 GMT toby [248]
	* trunk/doc/expgui_intro.html (modified)
	# on 2000/07/28 20:27:10, toby did:
	note latest
Fri, 04 Dec 2009 23:02:51 GMT toby [247]
	# on 2000/07/28 20:20:03, toby did:
	document profile constraints
Fri, 04 Dec 2009 23:02:50 GMT toby [246]
	# on 2000/07/28 20:18:20, toby did:
	document change in profile button
Fri, 04 Dec 2009 23:02:49 GMT toby [245]
	# on 2000/07/28 20:17:40, toby did:
	note sort on header
Fri, 04 Dec 2009 23:02:48 GMT toby [244]
	# on 2000/07/28 20:16:33, toby did:
	document ODF
Fri, 04 Dec 2009 23:02:47 GMT toby [243]
	* trunk/doc/expgui_Win_readme.html (modified)
	# on 2000/07/28 20:15:14, toby did:
	add CCP14 mirrors for gsas dist.
Fri, 04 Dec 2009 23:02:46 GMT toby [242]
	pretty it up
Fri, 04 Dec 2009 23:02:45 GMT toby [241]
	# on 2000/07/28 20:14:41, toby did:
	new additions andf ideas
Fri, 04 Dec 2009 23:02:44 GMT toby [240]
	* trunk/orient.tcl (modified)
	# on 2000/07/20 22:13:40, toby did:
	move MDprefinfo into readexp.tcl
Fri, 04 Dec 2009 23:02:43 GMT toby [239]
	correct use R settings in  ...
Fri, 04 Dec 2009 23:02:42 GMT toby [238]
	use file join on notebook.tcl ...
Fri, 04 Dec 2009 23:02:41 GMT toby [237]
	# on 2000/07/20 22:12:18, toby did:
	select new phase after a phase ...
Fri, 04 Dec 2009 23:02:40 GMT toby [236]
	# on 2000/07/20 22:09:56, toby did:
	Add odf (spherical harmonic) ...
Fri, 04 Dec 2009 23:02:39 GMT toby [235]
	* trunk/odf.tcl (added)
	# on 2000/07/20 22:03:39, toby did:
	Spherical Harmonic implementation
Fri, 04 Dec 2009 23:02:38 GMT toby [234]
	# on 2000/07/06 22:43:40, toby did:
	Change profile term labeling to ...
Fri, 04 Dec 2009 23:02:37 GMT toby [233]
	* trunk/atomcons.tcl (modified)
	# on 2000/07/06 21:36:22, toby did:
	add profile constraint subpage ...
Fri, 04 Dec 2009 23:02:36 GMT toby [232]
	# on 2000/07/06 21:31:38, toby did:
	use short DOS names for adding ...
Fri, 04 Dec 2009 23:02:35 GMT toby [231]
	# on 2000/07/06 21:29:24, toby did:
	Add GetProfileTerms, GetLaue, ...
Fri, 04 Dec 2009 23:02:34 GMT toby [230]
	# on 2000/07/06 21:28:01, toby did:
	use MakeHistBox for histogram ...
Fri, 04 Dec 2009 23:02:33 GMT toby [229]
	# on 2000/07/06 20:35:35, toby did:
	delete the old expmap (except ...
Fri, 04 Dec 2009 23:02:32 GMT toby [228]
	* trunk/profcons.tcl (added)
	# on 2000/07/06 20:33:55, toby did:
	alpha test version of the ...
Fri, 04 Dec 2009 23:02:31 GMT toby [227]
	# on 2000/07/03 21:50:35, toby did:
	fix aniso atoms in exp2xtl
Fri, 04 Dec 2009 23:02:30 GMT toby [226]
	# on 2000/07/03 21:44:27, toby did:
	make into multiple pages
Fri, 04 Dec 2009 23:02:29 GMT toby [225]
	* trunk/doc/expguic.html (added)
	# on 2000/07/03 21:43:33, toby did:
	Menu Contents
Fri, 04 Dec 2009 23:02:28 GMT toby [224]
	* trunk/doc/expgui7.html (added)
	# on 2000/07/03 21:41:08, toby did:
	Preferential Orientation Pane
Fri, 04 Dec 2009 23:02:27 GMT toby [223]
	* trunk/doc/expgui6.html (added)
	Constraints pane
Fri, 04 Dec 2009 23:02:26 GMT toby [222]
	* trunk/doc/expgui5.html (added)
	Profile pane
Fri, 04 Dec 2009 23:02:25 GMT toby [221]
	* trunk/doc/expgui4.html (added)
	Scaling pane
Fri, 04 Dec 2009 23:02:24 GMT toby [220]
	* trunk/doc/expgui3.html (added)
	Histogram pane
Fri, 04 Dec 2009 23:02:23 GMT toby [219]
	* trunk/doc/expgui2.html (added)
	Phase Pane
Fri, 04 Dec 2009 23:02:22 GMT toby [218]
	* trunk/doc/expgui1.html (added)
	Least Squares (LS) Controls Pane
Fri, 04 Dec 2009 23:02:21 GMT toby [217]
	* trunk/doc/expgui0.html (added)
	template
Fri, 04 Dec 2009 23:02:20 GMT toby [216]
	# on 2000/07/03 21:36:05, toby did:
	add more environment space
Fri, 04 Dec 2009 23:02:19 GMT toby [215]
	# on 2000/07/03 21:35:33, toby did:
	add multiplicity
Fri, 04 Dec 2009 23:02:18 GMT toby [214]
	# on 2000/06/09 04:27:36, toby did:
	Pref orientation in whats new
Fri, 04 Dec 2009 23:02:17 GMT toby [213]
	* trunk/doc/wishlist.html (added)
	# on 2000/06/09 04:04:56, toby did:
	Whats happening in EXPGUI
Fri, 04 Dec 2009 23:02:16 GMT toby [212]
	* trunk/tutorial1/nickel9.html (modified)
	# on 2000/06/09 03:57:42, toby did:
	incorporate many useful comments ...
Fri, 04 Dec 2009 23:02:15 GMT toby [211]
	* trunk/tutorial1/nickel8.html (modified)
Fri, 04 Dec 2009 23:02:14 GMT toby [210]
	* trunk/tutorial1/nickel7.html (modified)
Fri, 04 Dec 2009 23:02:13 GMT toby [209]
	* trunk/tutorial1/nickel6.html (modified)
Fri, 04 Dec 2009 23:02:12 GMT toby [208]
	* trunk/tutorial1/nickel5.html (modified)
Fri, 04 Dec 2009 23:02:11 GMT toby [207]
	* trunk/tutorial1/nickel4.html (modified)
Fri, 04 Dec 2009 23:02:10 GMT toby [206]
	* trunk/tutorial1/nickel3.html (modified)
Fri, 04 Dec 2009 23:02:09 GMT toby [205]
	* trunk/tutorial1/nickel2.html (modified)
Fri, 04 Dec 2009 23:02:08 GMT toby [204]
	* trunk/tutorial1/index.html (modified)
Fri, 04 Dec 2009 23:02:07 GMT toby [203]
	# on 2000/06/09 03:54:23, toby did:
	Update to reflect new GSAS kit, ...
Fri, 04 Dec 2009 23:02:06 GMT toby [202]
	# on 2000/06/09 03:53:28, toby did:
	Add Pref Orientation Section ...
Fri, 04 Dec 2009 23:02:05 GMT toby [201]
	# on 2000/06/09 03:52:16, toby did:
	Add warning when PGPLOT font ...
Fri, 04 Dec 2009 23:02:04 GMT toby [200]
	# on 2000/06/09 03:50:40, toby did:
	Minor cleanups
	loop on ...
Fri, 04 Dec 2009 23:02:03 GMT toby [199]
	# on 2000/06/09 03:45:28, toby did:
	Change Reload msg as per ...
Fri, 04 Dec 2009 23:02:02 GMT toby [198]
	# on 2000/06/09 03:44:35, toby did:
	avoid error when sorting atoms ...
Fri, 04 Dec 2009 23:02:01 GMT toby [197]
	# on 2000/06/09 03:44:05, toby did:
	remove puts debugging commands
Fri, 04 Dec 2009 23:02:00 GMT toby [196]
	# on 2000/06/09 03:41:16, toby did:
	Fix dropped character in titles ...
Fri, 04 Dec 2009 23:01:59 GMT toby [195]
	* trunk/orient.tcl (added)
	# on 2000/06/06 03:04:09, toby did:
	Preferred Orientation routines
Fri, 04 Dec 2009 23:01:58 GMT toby [194]
	* trunk/tutorial2/index.html (modified)
	# on 2000/06/01 16:07:21, toby did:
	correct typos
Fri, 04 Dec 2009 23:01:57 GMT toby [193]
	* trunk/tutorial2/garnet8.html (modified)
	correct typos
Fri, 04 Dec 2009 23:01:56 GMT toby [192]
	* trunk/tutorial2/garnet7.html (modified)
	correct typos
