# # ChangeLog for / # # Generated by Trac 1.0.13 # Jun 17, 2025 8:46:16 AM Fri, 04 Dec 2009 23:02:11 GMT toby [207] * trunk/tutorial1/nickel4.html (modified) # on 2000/06/09 03:57:42, toby did: incorporate many useful comments ... Fri, 04 Dec 2009 23:02:10 GMT toby [206] * trunk/tutorial1/nickel3.html (modified) # on 2000/06/09 03:57:42, toby did: incorporate many useful comments ... Fri, 04 Dec 2009 23:02:09 GMT toby [205] * trunk/tutorial1/nickel2.html (modified) # on 2000/06/09 03:57:42, toby did: incorporate many useful comments ... Fri, 04 Dec 2009 23:02:08 GMT toby [204] * trunk/tutorial1/index.html (modified) # on 2000/06/09 03:57:42, toby did: incorporate many useful comments ... Fri, 04 Dec 2009 23:02:07 GMT toby [203] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/06/09 03:54:23, toby did: Update to reflect new GSAS kit, ... Fri, 04 Dec 2009 23:02:06 GMT toby [202] * trunk/doc/expgui.html (modified) # on 2000/06/09 03:53:28, toby did: Add Pref Orientation Section ... Fri, 04 Dec 2009 23:02:05 GMT toby [201] * trunk/gsascmds.tcl (modified) # on 2000/06/09 03:52:16, toby did: Add warning when PGPLOT font ... Fri, 04 Dec 2009 23:02:04 GMT toby [200] * trunk/orient.tcl (modified) # on 2000/06/09 03:50:40, toby did: Minor cleanups loop on ... Fri, 04 Dec 2009 23:02:03 GMT toby [199] * trunk/expgui (modified) # on 2000/06/09 03:45:28, toby did: Change Reload msg as per ... Fri, 04 Dec 2009 23:02:02 GMT toby [198] * trunk/atomcons.tcl (modified) # on 2000/06/09 03:44:35, toby did: avoid error when sorting atoms ... Fri, 04 Dec 2009 23:02:01 GMT toby [197] * trunk/addcmds.tcl (modified) # on 2000/06/09 03:44:05, toby did: remove puts debugging commands Fri, 04 Dec 2009 23:02:00 GMT toby [196] * trunk/readexp.tcl (modified) # on 2000/06/09 03:41:16, toby did: Fix dropped character in titles ... Fri, 04 Dec 2009 23:01:59 GMT toby [195] * trunk/orient.tcl (added) # on 2000/06/06 03:04:09, toby did: Preferred Orientation routines Fri, 04 Dec 2009 23:01:58 GMT toby [194] * trunk/tutorial2/index.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:57 GMT toby [193] * trunk/tutorial2/garnet8.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:56 GMT toby [192] * trunk/tutorial2/garnet7.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:55 GMT toby [191] * trunk/tutorial2/garnet5.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:54 GMT toby [190] * trunk/tutorial2/garnet3.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:53 GMT toby [189] * trunk/tutorial2/garnet1.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:52 GMT toby [188] * trunk/tutorial1/nickelnotes.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:51 GMT toby [187] * trunk/tutorial1/nickel7.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:50 GMT toby [186] * trunk/tutorial1/nickel6.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:49 GMT toby [185] * trunk/tutorial1/nickel3.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:48 GMT toby [184] * trunk/tutorial1/nickel1.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:47 GMT toby [183] * trunk/tutorial1/index.html (modified) # on 2000/06/01 16:07:21, toby did: correct typos Fri, 04 Dec 2009 23:01:46 GMT toby [182] * trunk/gsascmds.tcl (modified) # on 2000/06/01 02:55:03, toby did: add concurrent arg to ... Fri, 04 Dec 2009 23:01:45 GMT toby [181] * trunk/expgui (modified) # on 2000/06/01 02:48:14, toby did: define default txtview(font) Fri, 04 Dec 2009 23:01:44 GMT toby [180] * trunk/atomcons.tcl (modified) # on 2000/06/01 02:47:26, toby did: fix XYZU bug Fri, 04 Dec 2009 23:01:43 GMT toby [179] * trunk/addcmds.tcl (modified) # on 2000/06/01 02:46:47, toby did: add more than one atom at a time Fri, 04 Dec 2009 23:01:42 GMT toby [178] * trunk/doc/expgui_intro.html (modified) # on 2000/06/01 02:42:49, toby did: add tutorial reference Fri, 04 Dec 2009 23:01:41 GMT toby [177] * trunk/tutorial2/index.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:40 GMT toby [176] * trunk/tutorial2/garnet9.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:39 GMT toby [175] * trunk/tutorial2/garnet8.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:38 GMT toby [174] * trunk/tutorial2/garnet7.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:37 GMT toby [173] * trunk/tutorial2/garnet6.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:36 GMT toby [172] * trunk/tutorial2/garnet5.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:35 GMT toby [171] * trunk/tutorial2/garnet4.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:34 GMT toby [170] * trunk/tutorial2/garnet3.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:33 GMT toby [169] * trunk/tutorial2/garnet2.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:32 GMT toby [168] * trunk/tutorial2 (added) * trunk/tutorial2/garnet1.html (added) # on 2000/05/30 22:22:38, toby did: Garnet tutorial Fri, 04 Dec 2009 23:01:31 GMT toby [167] * trunk/addcmds.tcl (modified) # on 2000/05/26 22:55:32, toby did: RUNPLOT & TOF on Add Histogram dialog Fri, 04 Dec 2009 23:01:30 GMT toby [166] * trunk/tutorial1/nickelnotes.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:29 GMT toby [165] * trunk/tutorial1/nickel9.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:28 GMT toby [164] * trunk/tutorial1/nickel8.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:27 GMT toby [163] * trunk/tutorial1/nickel7.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:26 GMT toby [162] * trunk/tutorial1/nickel6.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:25 GMT toby [161] * trunk/tutorial1/nickel5.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:24 GMT toby [160] * trunk/tutorial1/nickel4.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:23 GMT toby [159] * trunk/tutorial1/nickel3.html (added) # on 2000/05/26 16:08:48, toby did: Initial revision Fri, 04 Dec 2009 23:01:22 GMT toby [158] * trunk/tutorial1/nickel2.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:21 GMT toby [157] * trunk/tutorial1/nickel1.html (added) # on 2000/05/26 16:08:48, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:20 GMT toby [156] * trunk/tutorial1 (added) * trunk/tutorial1/index.html (added) # on 2000/05/26 16:08:16, toby did: GSAS Nickel tutorial in EXPGUI Fri, 04 Dec 2009 23:01:19 GMT toby [155] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/05/26 14:12:58, toby did: complete gsaskit.exe repoint Fri, 04 Dec 2009 23:01:18 GMT toby [154] * trunk/doc/expgui.html (modified) # on 2000/05/26 14:12:58, toby did: document revised liveplot ... Fri, 04 Dec 2009 23:01:17 GMT toby [153] * trunk/liveplot (modified) # on 2000/05/26 14:06:54, toby did: revise liveplot bindings so that ... Fri, 04 Dec 2009 23:01:16 GMT toby [152] * trunk/expgui (modified) # on 2000/05/18 15:58:18, toby did: Add constraints support move to ... Fri, 04 Dec 2009 23:01:15 GMT toby [151] * trunk/atomcons.tcl (modified) # on 2000/05/18 15:55:37, toby did: add revision string Fri, 04 Dec 2009 23:01:14 GMT toby [150] * trunk/atomcons.tcl (modified) # on 2000/05/18 15:54:08, toby did: fix bugs (already!) test for ... Fri, 04 Dec 2009 23:01:13 GMT toby [149] * trunk/gsasmenu.tcl (modified) # on 2000/05/18 15:43:24, toby did: shortcut for powpref Fri, 04 Dec 2009 23:01:12 GMT toby [148] * trunk/doc/expgui.html (modified) # on 2000/05/18 15:37:38, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:01:11 GMT toby [147] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing Fri, 04 Dec 2009 23:01:10 GMT toby [146] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing Fri, 04 Dec 2009 23:01:09 GMT toby [145] * trunk/doc/expgui_intro.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing Fri, 04 Dec 2009 23:01:08 GMT toby [144] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/18 15:32:42, toby did: add Tcl/tk logo, general editing ... Fri, 04 Dec 2009 23:01:07 GMT toby [143] * trunk/doc/expgui_cfg.html (modified) # on 2000/05/17 20:27:05, toby did: major edit Fri, 04 Dec 2009 23:01:06 GMT toby [142] * trunk/doc/expgui_intro.html (modified) # on 2000/05/17 20:23:13, toby did: cleanup Fri, 04 Dec 2009 23:01:05 GMT toby [141] * trunk/doc/expgui_Unix_readme.html (modified) # on 2000/05/17 20:11:07, toby did: cleanup & update Fri, 04 Dec 2009 23:01:04 GMT toby [140] * trunk/doc/expgui_Win_readme.html (modified) # on 2000/05/17 20:09:20, toby did: cleanup & update Fri, 04 Dec 2009 23:01:03 GMT toby [139] * trunk/expgui (modified) # on 2000/05/17 18:45:27, toby did: new option: allow a separate ... Fri, 04 Dec 2009 23:01:02 GMT toby [138] * trunk/gsascmds.tcl (modified) # on 2000/05/17 18:38:55, toby did: add force to rename add ... Fri, 04 Dec 2009 23:01:01 GMT toby [137] * trunk/gsasmenu.tcl (modified) # on 2000/05/17 18:37:18, toby did: add menubutton option line item ... Fri, 04 Dec 2009 23:01:00 GMT toby [136] * trunk/widplt (modified) # on 2000/05/17 16:30:57, toby did: change donewait to donewaitmsg ... Fri, 04 Dec 2009 23:00:59 GMT toby [135] * trunk/lstview (modified) # on 2000/05/17 16:30:57, toby did: change donewait to donewaitmsg ... Fri, 04 Dec 2009 23:00:58 GMT toby [134] * trunk/liveplot (modified) # on 2000/05/17 16:30:57, toby did: change donewait to donewaitmsg ... Fri, 04 Dec 2009 23:00:57 GMT toby [133] * trunk/expgui (modified) # on 2000/05/17 16:17:21, toby did: cleanup reading lowercase .exp ... Fri, 04 Dec 2009 23:00:56 GMT toby [132] * trunk/addcmds.tcl (modified) # on 2000/05/17 16:14:23, toby did: cleanup adding histograms to be ... Fri, 04 Dec 2009 23:00:55 GMT toby [131] * trunk/atomcons.tcl (added) # on 2000/05/17 00:22:54, toby did: routines for atom constraints Fri, 04 Dec 2009 23:00:54 GMT toby [130] * trunk/gsascmds.tcl (modified) # on 2000/05/16 21:57:44, toby did: ignore macromolecular phases ... Fri, 04 Dec 2009 23:00:53 GMT toby [129] * trunk/readexp.tcl (modified) # on 2000/05/16 21:53:20, toby did: add constrinfo for atom ... Fri, 04 Dec 2009 23:00:52 GMT toby [128] * trunk/readexp.tcl (modified) # on 2000/05/16 21:48:45, toby did: set expload return value to ... Fri, 04 Dec 2009 23:00:51 GMT toby [127] * trunk/opts.tcl (added) # on 2000/04/24 02:32:17, toby did: This sets the default fonts & ... Fri, 04 Dec 2009 23:00:50 GMT toby [126] * trunk/widplt (modified) # on 2000/04/10 20:07:43, toby did: revise BLT error for bad ... Fri, 04 Dec 2009 23:00:49 GMT toby [125] * trunk/liveplot (modified) # on 2000/04/10 20:07:43, toby did: revise BLT error for bad ... Fri, 04 Dec 2009 23:00:48 GMT toby [124] * trunk/readexp.tcl (modified) # on 2000/02/02 17:42:20, toby did: create HST xx EPHAS records if ... Fri, 04 Dec 2009 23:00:47 GMT toby [123] * trunk/expgui (modified) # on 1999/11/19 00:03:25, toby did: fixup Archive code for Windows ... Fri, 04 Dec 2009 23:00:46 GMT toby [122] * trunk/gsasmenu.tcl (modified) # on 1999/11/17 22:07:24, toby did: Add EraseHistory command Fri, 04 Dec 2009 23:00:45 GMT toby [121] * trunk/notebook.tcl (modified) # on 1999/11/17 22:06:21, toby did: define a -title configuration option Fri, 04 Dec 2009 23:00:44 GMT toby [120] * trunk/readexp.tcl (modified) # on 1999/11/17 22:05:04, toby did: Add routines to delete history ... Fri, 04 Dec 2009 23:00:43 GMT toby [119] * trunk/gsascmds.tcl (modified) # on 1999/11/17 22:02:36, toby did: Add routine to delete history ... Fri, 04 Dec 2009 23:00:42 GMT toby [118] * trunk/expgui (modified) # on 1999/11/16 15:59:22, toby did: Switch over to use of pure Tk ... Fri, 04 Dec 2009 23:00:41 GMT toby [117] * trunk/expgui (modified) # on 1999/11/16 15:45:40, toby did: add timing option for debug try ... Fri, 04 Dec 2009 23:00:40 GMT toby [116] * trunk/notebook.tcl (added) # on 1999/11/15 14:32:48, toby did: A standard Tcl/Tk notebook widget Fri, 04 Dec 2009 23:00:39 GMT toby [115] * trunk/doc/expgui.html (modified) # on 1999/10/11 20:27:39, toby did: document "Group Phases Together" ... Fri, 04 Dec 2009 23:00:38 GMT toby [114] * trunk/doc/expgui_cfg.html (modified) # on 1999/10/11 20:27:13, toby did: Customization examples Fri, 04 Dec 2009 23:00:37 GMT toby [113] * trunk/addcmds.tcl (modified) # on 1999/10/11 19:49:28, toby did: *** empty log message *** Fri, 04 Dec 2009 23:00:36 GMT toby [112] * trunk/expgui (modified) # on 1999/10/11 19:48:35, toby did: cleanup multiple histogram ... Fri, 04 Dec 2009 23:00:35 GMT toby [111] * trunk/widplt (modified) # on 1999/10/11 19:46:43, toby did: Define expgui(debug) Fri, 04 Dec 2009 23:00:34 GMT toby [110] * trunk/gsasmenu.tcl (modified) # on 1999/10/11 19:46:16, toby did: document new global modes ... Fri, 04 Dec 2009 23:00:33 GMT toby [109] * trunk/doc/expgui_intro.html (modified) # on 1999/09/16 15:44:26, toby did: add version reference to EXPGUI ... Fri, 04 Dec 2009 23:00:32 GMT toby [108] * trunk/doc/expgui.html (modified) # on 1999/09/16 15:43:44, toby did: update 2.gif and 3.gif and text ...
