# ChangeLog for /
# Generated by Trac 1.0.13
# Jun 17, 2025 8:09:41 PM
Fri, 04 Dec 2009 23:01:16 GMT toby [152]
	* trunk/expgui (modified)
	# on 2000/05/18 15:58:18, toby did:
	Add constraints support
	move to ...
Fri, 04 Dec 2009 23:01:15 GMT toby [151]
	* trunk/atomcons.tcl (modified)
	# on 2000/05/18 15:55:37, toby did:
	add revision string
Fri, 04 Dec 2009 23:01:14 GMT toby [150]
	# on 2000/05/18 15:54:08, toby did:
	fix bugs (already!)
	test for ...
Fri, 04 Dec 2009 23:01:13 GMT toby [149]
	* trunk/gsasmenu.tcl (modified)
	# on 2000/05/18 15:43:24, toby did:
	shortcut for powpref
Fri, 04 Dec 2009 23:01:12 GMT toby [148]
	* trunk/doc/expgui.html (modified)
	# on 2000/05/18 15:37:38, toby did:
	add Tcl/tk logo, general editing ...
Fri, 04 Dec 2009 23:01:11 GMT toby [147]
	* trunk/doc/expgui_Win_readme.html (modified)
	# on 2000/05/18 15:32:42, toby did:
Fri, 04 Dec 2009 23:01:10 GMT toby [146]
	* trunk/doc/expgui_Unix_readme.html (modified)
Fri, 04 Dec 2009 23:01:09 GMT toby [145]
	* trunk/doc/expgui_intro.html (modified)
Fri, 04 Dec 2009 23:01:08 GMT toby [144]
	* trunk/doc/expgui_cfg.html (modified)
Fri, 04 Dec 2009 23:01:07 GMT toby [143]
	# on 2000/05/17 20:27:05, toby did:
	major edit
Fri, 04 Dec 2009 23:01:06 GMT toby [142]
	# on 2000/05/17 20:23:13, toby did:
	cleanup
Fri, 04 Dec 2009 23:01:05 GMT toby [141]
	# on 2000/05/17 20:11:07, toby did:
	cleanup & update
Fri, 04 Dec 2009 23:01:04 GMT toby [140]
	# on 2000/05/17 20:09:20, toby did:
	cleanup & update
Fri, 04 Dec 2009 23:01:03 GMT toby [139]
	# on 2000/05/17 18:45:27, toby did:
	new option: allow a separate ...
Fri, 04 Dec 2009 23:01:02 GMT toby [138]
	* trunk/gsascmds.tcl (modified)
	# on 2000/05/17 18:38:55, toby did:
	add force to rename
	add ...
Fri, 04 Dec 2009 23:01:01 GMT toby [137]
	# on 2000/05/17 18:37:18, toby did:
	add menubutton option line item ...
Fri, 04 Dec 2009 23:01:00 GMT toby [136]
	* trunk/widplt (modified)
	# on 2000/05/17 16:30:57, toby did:
	change donewait to donewaitmsg ...
Fri, 04 Dec 2009 23:00:59 GMT toby [135]
	* trunk/lstview (modified)
Fri, 04 Dec 2009 23:00:58 GMT toby [134]
	* trunk/liveplot (modified)
Fri, 04 Dec 2009 23:00:57 GMT toby [133]
	# on 2000/05/17 16:17:21, toby did:
	cleanup reading lowercase .exp ...
Fri, 04 Dec 2009 23:00:56 GMT toby [132]
	* trunk/addcmds.tcl (modified)
	# on 2000/05/17 16:14:23, toby did:
	cleanup adding histograms to be ...
Fri, 04 Dec 2009 23:00:55 GMT toby [131]
	* trunk/atomcons.tcl (added)
	# on 2000/05/17 00:22:54, toby did:
	routines for atom constraints
Fri, 04 Dec 2009 23:00:54 GMT toby [130]
	# on 2000/05/16 21:57:44, toby did:
	ignore macromolecular phases ...
Fri, 04 Dec 2009 23:00:53 GMT toby [129]
	* trunk/readexp.tcl (modified)
	# on 2000/05/16 21:53:20, toby did:
	add constrinfo for atom ...
Fri, 04 Dec 2009 23:00:52 GMT toby [128]
	# on 2000/05/16 21:48:45, toby did:
	set expload return value to ...
Fri, 04 Dec 2009 23:00:51 GMT toby [127]
	* trunk/opts.tcl (added)
	# on 2000/04/24 02:32:17, toby did:
	This sets the default fonts & ...
Fri, 04 Dec 2009 23:00:50 GMT toby [126]
	# on 2000/04/10 20:07:43, toby did:
	revise BLT error for bad ...
Fri, 04 Dec 2009 23:00:49 GMT toby [125]
Fri, 04 Dec 2009 23:00:48 GMT toby [124]
	# on 2000/02/02 17:42:20, toby did:
	create HST xx EPHAS records if ...
Fri, 04 Dec 2009 23:00:47 GMT toby [123]
	# on 1999/11/19 00:03:25, toby did:
	fixup Archive code for Windows ...
Fri, 04 Dec 2009 23:00:46 GMT toby [122]
	# on 1999/11/17 22:07:24, toby did:
	Add EraseHistory command
Fri, 04 Dec 2009 23:00:45 GMT toby [121]
	* trunk/notebook.tcl (modified)
	# on 1999/11/17 22:06:21, toby did:
	define a -title configuration option
Fri, 04 Dec 2009 23:00:44 GMT toby [120]
	# on 1999/11/17 22:05:04, toby did:
	Add routines to delete history ...
Fri, 04 Dec 2009 23:00:43 GMT toby [119]
	# on 1999/11/17 22:02:36, toby did:
	Add routine to delete history ...
Fri, 04 Dec 2009 23:00:42 GMT toby [118]
	# on 1999/11/16 15:59:22, toby did:
	Switch over to use of pure Tk ...
Fri, 04 Dec 2009 23:00:41 GMT toby [117]
	# on 1999/11/16 15:45:40, toby did:
	add timing option for debug
	try ...
Fri, 04 Dec 2009 23:00:40 GMT toby [116]
	* trunk/notebook.tcl (added)
	# on 1999/11/15 14:32:48, toby did:
	A standard Tcl/Tk notebook widget
Fri, 04 Dec 2009 23:00:39 GMT toby [115]
	# on 1999/10/11 20:27:39, toby did:
	document "Group Phases Together" ...
Fri, 04 Dec 2009 23:00:38 GMT toby [114]
	# on 1999/10/11 20:27:13, toby did:
	Customization examples
Fri, 04 Dec 2009 23:00:37 GMT toby [113]
	# on 1999/10/11 19:49:28, toby did:
Fri, 04 Dec 2009 23:00:36 GMT toby [112]
	# on 1999/10/11 19:48:35, toby did:
	cleanup multiple histogram ...
Fri, 04 Dec 2009 23:00:35 GMT toby [111]
	# on 1999/10/11 19:46:43, toby did:
	Define expgui(debug)
Fri, 04 Dec 2009 23:00:34 GMT toby [110]
	# on 1999/10/11 19:46:16, toby did:
	document new global modes ...
Fri, 04 Dec 2009 23:00:33 GMT toby [109]
	# on 1999/09/16 15:44:26, toby did:
	add version reference to EXPGUI ...
Fri, 04 Dec 2009 23:00:32 GMT toby [108]
	# on 1999/09/16 15:43:44, toby did:
	update 2.gif and 3.gif and text ...
Fri, 04 Dec 2009 23:00:31 GMT toby [107]
	# on 1999/09/09 21:00:32, toby did:
	update for new WWW server
Fri, 04 Dec 2009 23:00:30 GMT toby [106]
Fri, 04 Dec 2009 23:00:29 GMT toby [105]
Fri, 04 Dec 2009 23:00:28 GMT toby [104]
	# on 1999/09/09 20:56:51, toby did:
Fri, 04 Dec 2009 23:00:27 GMT toby [103]
Fri, 04 Dec 2009 23:00:26 GMT toby [102]
	# on 1999/09/09 19:08:11, toby did:
	hide grab fail error messages
Fri, 04 Dec 2009 23:00:25 GMT toby [101]
	# on 1999/09/09 19:06:45, toby did:
	fix vrstplot call so that EXP ...
Fri, 04 Dec 2009 23:00:24 GMT toby [100]
	# on 1999/09/09 19:05:54, toby did:
	correct background window bug ...
Fri, 04 Dec 2009 23:00:23 GMT toby [99]
	# on 1999/07/22 20:08:20, toby did:
	revise for exptool that adds ...
Fri, 04 Dec 2009 23:00:22 GMT toby [98]
	# on 1999/07/22 20:07:37, toby did:
	Fix resize of ShowBigMessage
Fri, 04 Dec 2009 23:00:21 GMT toby [97]
	# on 1999/07/22 20:04:23, toby did:
	clear atom box etc when loading ...
Fri, 04 Dec 2009 23:00:20 GMT toby [96]
	# on 1999/07/21 18:39:52, toby did:
	bring to current release
	make ...
Fri, 04 Dec 2009 23:00:19 GMT toby [95]
	# on 1999/07/21 18:39:20, toby did:
	exptool updates
Fri, 04 Dec 2009 23:00:18 GMT toby [94]
	# on 1999/07/21 16:51:57, toby did:
	add phase... update
Fri, 04 Dec 2009 23:00:17 GMT toby [93]
	# on 1999/07/21 16:32:11, toby did:
	add autoload mode
	add support ...
Fri, 04 Dec 2009 23:00:16 GMT toby [92]
	* trunk/addcmds.tcl (added)
	# on 1999/07/21 16:29:57, toby did:
	These routines are used for ...
Fri, 04 Dec 2009 23:00:15 GMT toby [91]
	# on 1999/07/21 16:22:54, toby did:
	adopt putontop and afterputontop ...
Fri, 04 Dec 2009 23:00:14 GMT toby [90]
	# on 1999/07/21 16:19:34, toby did:
	fix bug in create blank exp file ...
Fri, 04 Dec 2009 23:00:13 GMT toby [89]
	# on 1999/07/21 15:12:53, toby did:
	fix windows archive error
Fri, 04 Dec 2009 23:00:12 GMT toby [88]
	# on 1999/07/21 15:12:10, toby did:
	fix error reading R(F2)
Fri, 04 Dec 2009 23:00:11 GMT toby [87]
	# on 1999/04/20 19:22:46, toby did:
	rearrange order of commands so ...
Fri, 04 Dec 2009 23:00:10 GMT toby [86]
	# on 1999/04/08 20:44:22, toby did:
	Add Id to header
Fri, 04 Dec 2009 23:00:09 GMT toby [85]
	Add Id to header
Fri, 04 Dec 2009 23:00:08 GMT toby [84]
	Add Id to header
Fri, 04 Dec 2009 23:00:07 GMT toby [83]
	define histogram slider to reach ...
Fri, 04 Dec 2009 23:00:06 GMT toby [82]
	# on 1999/04/08 20:43:10, toby did:
	Add Id to top of file
Fri, 04 Dec 2009 23:00:05 GMT toby [81]
	# on 1999/04/08 20:39:33, toby did:
	Add new liveplot features
	refer ...
Fri, 04 Dec 2009 23:00:04 GMT toby [80]
	# on 1999/04/08 20:37:28, toby did:
	minor cleanups
	refer to tcldump ...
Fri, 04 Dec 2009 23:00:03 GMT toby [79]
	# on 1999/04/08 20:33:23, toby did:
	add tick autoscaling
	deal with ...
Fri, 04 Dec 2009 23:00:02 GMT toby [78]
	# on 1999/04/06 22:27:03, toby did:
	add background subtraction ...
Fri, 04 Dec 2009 23:00:01 GMT toby [77]
	# on 1999/04/06 21:37:19, toby did:
	add Id
Fri, 04 Dec 2009 23:00:00 GMT toby [76]
	# on 1999/04/06 21:13:49, toby did:
	Add peak label dialog; delete ...
Fri, 04 Dec 2009 22:59:59 GMT toby [75]
	# on 1999/04/05 18:14:24, toby did:
	fix BLT element -show/-hide ...
Fri, 04 Dec 2009 22:59:58 GMT toby [74]
	# on 1999/03/30 16:18:11, toby did:
	Set expnam on command line to ...
Fri, 04 Dec 2009 22:59:57 GMT toby [73]
	# on 1999/03/19 17:07:59, toby did:
	major reworking -- implement ...
Fri, 04 Dec 2009 22:59:56 GMT toby [72]
	rename file directory routines ...
Fri, 04 Dec 2009 22:59:55 GMT toby [71]
	bug fixes for reading new .EXP files
Fri, 04 Dec 2009 22:59:54 GMT toby [70]
	# on 1999/03/19 16:58:39, toby did:
	shift to *.ncnr.nist.gov, new ...
Fri, 04 Dec 2009 22:59:53 GMT toby [69]
Fri, 04 Dec 2009 22:59:52 GMT toby [68]
Fri, 04 Dec 2009 22:59:51 GMT toby [67]
Fri, 04 Dec 2009 22:59:50 GMT toby [66]
Fri, 04 Dec 2009 22:59:49 GMT toby [65]
	# on 1999/03/19 16:55:10, toby did:
Fri, 04 Dec 2009 22:59:48 GMT toby [64]
Fri, 04 Dec 2009 22:59:47 GMT toby [63]
	# on 1999/02/22 20:03:00, toby did:
	save the selected atom list and ...
Fri, 04 Dec 2009 22:59:46 GMT toby [62]
	# on 1999/02/19 18:18:23, toby did:
	cleanup warnings
Fri, 04 Dec 2009 22:59:45 GMT toby [61]
	# on 1999/02/19 18:17:14, toby did:
	Cleanup warnings
Fri, 04 Dec 2009 22:59:44 GMT toby [60]
	# on 1999/02/19 16:02:23, toby did:
Fri, 04 Dec 2009 22:59:43 GMT toby [59]
	# on 1999/02/19 16:01:46, toby did:
	Clean up file input dialogs for ...
Fri, 04 Dec 2009 22:59:42 GMT toby [58]
	# on 1999/02/19 15:51:21, toby did:
	Add composition and exp2xtl ...
Fri, 04 Dec 2009 22:59:41 GMT toby [57]
	# on 1999/02/18 23:28:46, toby did:
	Fix U aniso order
Fri, 04 Dec 2009 22:59:40 GMT toby [56]
	# on 1999/02/18 22:50:03, toby did:
	add space group to phase info
Fri, 04 Dec 2009 22:59:39 GMT toby [55]
	# on 1999/02/18 21:07:19, toby did:
	Add support for atom multiplicity
Fri, 04 Dec 2009 22:59:38 GMT toby [54]
	# on 1999/02/16 18:37:38, toby did:
	bug fixed
Fri, 04 Dec 2009 22:59:37 GMT toby [53]
	# on 1999/02/16 18:05:57, toby did:
	1. better error messages
	2. ...
